Closed Thread
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 1.00 average. Display Modes
Old 02-18-2013, 01:53 PM   #1
Sweetness
My Ride: '01 325i
Let's Talk: Heating Blankets for E46
Hey guys; after having the cold come back after a week or two of decent weather, I have become inspired and driven to get a heating blanket for the E46. Let me start off by saying a couple things:
1) BMW did make a block heater; but after hours of searching, I'm pretty sure they are discontinued, or are basically non-existent.
2) I don't want a pad that "sticks" inside the oil pan, or on the outside...that seems dangerous for the car at first, and I don't want this thing to be on my car year round.
3)I have become interested in the actual heating blankets that you just drape on top of the engine when you need to, and then plug it in. Close the hood while heating. This seems great. Just take it out, heat it up, remove, and then go on my way.
So what are my options? A quick search netted me a couple blankets from $250 up to $1,000, which is ridiculous. My price range is less than $200...ideally, around $100. Can anyone help out? I'd love to be the test subject and let everyone know how it goes.
Thanks.
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline
Old 02-18-2013, 01:56 PM   #2
cposk
My Ride: 08' E90 M3
Hmm seems like a lot of work for little gain. The car is designed to be started in cold weather, just let it warm up or be gentle until it is warm. I think a remote start system would be a better investment. 5-10 minutes before you want to leave, hit the button and she will be warm when you are ready to go.
cposk is offline
Old 02-18-2013, 02:00 PM   #3
Sweetness
My Ride: '01 325i
You cannot be more wrong.
There is no work at all. I buy it, it shows up to my door, and when it gets cold, I put on my car and warms engine and all the fluids to normal temp. Starting engine at 5 degrees is not "normal". It's bad for the bearings, and pretty much all the engine components. In a perfect world, engines run in temperatures of 72 degrees outside at all times. And remote start? This isn't a E90 M3. In our cars, they will stall out, if not run rough for at least 5 minutes. It's in the owner's manual to start driving right away after engine ignition.
Sorry man, but that post has zero credibility. This is not a '72 Chevy. A lot of people can back me on this.
2001 325i ZCW, ZPP
Old 02-18-2013, 02:01 PM   #4
lmr2wil
My Ride: '00 328Ci
Non existent? Maybe not:
http://www.ebay.com/itm/GENUINE-BMW-...3b87b9bb8#shId
Although it is slightly more than your stated budget (after shipping), it's the correct part for the job.
Luke
lmr2wil is offline
Old 02-18-2013, 02:02 PM   #5
Sweetness
My Ride: '01 325i
Luke
Those pictures were taken off a DIY post from here at E46Fanatics. So that credibility is shaky as well.
2001 325i ZCW, ZPP
Old 02-18-2013, 02:03 PM   #6
Kubica
My Ride: 2003 325xi
Op- you live in Pittsburgh, not the Yukon. You don't need this. Use a thinner oil and stop worrying.
Kubica is offline
Old 02-18-2013, 02:04 PM   #7
cposk
My Ride: 08' E90 M3
What I meant was having to put the blanket under there, plug it in, then remove it before starting the car. And I agree that it is not "ideal" to start the car in 5 degrees, it was taken into account when the engine was designed.
And I'm very aware of the car stalling out. I have to keep my foot on the gas to stop my E46 from stalling out at a stop in the morning (but I thought doing the vanos seals would fix it).
cposk is offline
Old 02-18-2013, 02:09 PM   #8
lmr2wil
My Ride: '00 328Ci
That's true. However, there was this - http://forum.e46fanatics.com/showpos...9&postcount=17. It may be worth contacting someone to find out if its a scam. In any event, my point is this: if you're going to do this (regardless of whether or not you need to), do it right.
Luke
lmr2wil is offline
Old 02-18-2013, 02:10 PM   #9
wildirish317
My Ride: 2004 325Ci vert
So, did you start this thread just so you can flame on people, or are you just having a bad Monday morning?
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline
Old 02-18-2013, 02:16 PM   #10
cposk
My Ride: 08' E90 M3
I got flamed for thinking remote start would be easier than walking outside in the morning, putting a blanket on my motor, plugging it in, then going back inside, then going back outside, unplugging the blanket, removing the blanket, putting the blanket away, and starting my car.
cposk is offline
Old 02-18-2013, 02:17 PM   #11
Jesse M
My Ride: 05' ZHP
You have more problems than you're aware of. I'd get that sorted out asap.
Jesse M is offline
Old 02-18-2013, 02:21 PM   #12
cposk
My Ride: 08' E90 M3
Idle that drops and bounces back every 10 seconds or so when motor is cold? I was under the impression that was vanos. But disa, IAC, CCV will be done soon too.
cposk is offline
Old 02-18-2013, 02:27 PM   #13
Surrept
My Ride: 2002 330ci
You live in Pittsburgh. Just let it be. It doesn't get that cold there.
Surrept is offline
Old 02-18-2013, 02:44 PM   #14
lcoleman
My Ride: '79 Massey Ferguson
Then don't get one. The blanket idea is silly.
OP starts post asking for opinions, then argues with the ones he gets. <3 this forum.
lcoleman is offline
Old 02-18-2013, 02:50 PM   #15
Surrept
My Ride: 2002 330ci
I mean you COULD just get a cheapo warming blanket that you would normally sleep under. I would imagine that it will keep the engine a tad bit warmer than without it. Certainly wouldn't cost you 200 bucks.
Surrept is offline
Old 02-18-2013, 02:59 PM   #16
98bimmer
My Ride: E90 330i, E36 328i
In the cold what i usually do is, turn the key, the vehicle starts and idle for a few moments and then i fly away.
Its colder here in Toronto than where you are. You dont need a block heater or a blanket.
98bimmer is offline
Old 02-18-2013, 03:02 PM   #17
Surrept
My Ride: 2002 330ci
Agreed. It gets subzero here where I'm at in Ohio in the winter sometimes. Tdot is about 5 hours NORTH of where I am and if he doesn't need one, neither do you.
Surrept is offline
Old 02-18-2013, 03:16 PM   #18
jonesenberg
My Ride: '04 330i ZHP 6spd
An electric blanket will warm your oil, engine, and coolant to 95C? If not, what's the point? What could possibly warm these three things faster than combustion of gasoline inside the engine with these fluids being pumped through it?
Have you thought about how much power would be required to overcome the thermal inefficiency of warming a blanket, then the layer of air between it and the motor (along with plastic engine cover, etc etc), and finally the block itself? How about the potential fire hazard? An electrical short if you close the hood on it the wrong way and shear the wire?
jonesenberg is offline
Old 02-18-2013, 03:19 PM   #19
jmillsner
My Ride: 330Ci 6 Spd, 335Cic
hahah seriously! if you dont want the help dont ask!
no but seriously OP, i take my engine out, tuck it into bed at night, then when im ready to set off on a cold Chicago morning, i pop it back in and im on my way!
no, but seriously, not hard feelings, but you dont need some silly blanket, as some have said, use thinner oil and dont drive hard until its warm.. i start my car in below 0 temps often and im fine
jmillsner is offline
Old 02-18-2013, 03:21 PM   #20
Surrept
My Ride: 2002 330ci
People do use warming blankets for their vehicles here in Toledo and they DO work. My GF's car and her brothers truck both have issues starting when its less than 10 degrees F. He uses a warming blanket on his truck and it works great for him. The point is with these cars, you don't frickin need it where hes living.
Surrept is offline
Closed Thread
snuggie for bmws
