Old 02-18-2013, 04:51 PM   #1
xpro
My Ride: 04 325XI
a hose broke while changing the valve cover gasket
So I just finished changing my valve cover gasket. And when I was closing everything up one of the hoses was very brittle and it snapped in half. I have posted pictures. Can you tell me how important that hose is and what its function is? Can I drive the car fit a while until I fix it?
ID:	491263   Click image for larger version
xpro is offline   Reply With Quote
Old 02-18-2013, 05:11 PM   #2
wildirish317
My Ride: 2004 325Ci vert
It's part of your air pump system. It will probably cause a vacuum leak and throw some codes. Not sure how it will affect your drivability. Plug both open ends. You can get some vacuum tubing at your local parts store and fix it in a few minutes.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 02-18-2013, 05:15 PM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Suggest you check out the SAP section in the first link below in my signature.
Old 02-18-2013, 05:20 PM   #4
///MPR77
My Ride: 02 ///M3 Tri-Ped
It will cause rough idle on start up.
Mine broke too, and I just walked a couple of blocks to auto zone and picked up 3' for cheap.
Old 02-18-2013, 05:43 PM   #5
jfoj
You can drive the car, it will likely trigger a CEL at some point, may make cold start rough for up to 90 seconds.
Since you changed the valve cover gasket, the hard part of the hose along the valve cover is likely broken and will need to be replaced all the way a back to the underside rear of the intake.
Old 02-18-2013, 05:51 PM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Get a new hose and you'll be set.
Old 02-18-2013, 06:00 PM   #7
MCM97
My Ride: 01 325Ci
This x287989038727
MCM97 is offline   Reply With Quote
Old 02-18-2013, 06:30 PM   #8
El Barto
My Ride: 330 CI
I did the same thing MPR77 did. I brought a piece, sized it up about right, and replace the small couple once segment. It worked fine. I did not start the car with the hose broken so I have no ideas of the codes that would be thrown if started while broken.
El Barto is offline   Reply With Quote
Old 02-18-2013, 07:20 PM   #9
325xiSLEEPER
My Ride: BMW 325xi
i had to replace mine because it was dry rotted i went to autozone matched it up with a generic vacumm hose and it worked fine it was like 1.30 for a foot. simple fix..
325xiSLEEPER is offline   Reply With Quote
Old 02-18-2013, 10:13 PM   #10
seigi009
My Ride: 03 325i
I think I am the only one here but when I purchased a normal vacuum hose from Autozone, it melted within a few days. So this is what I did when I broke my vacuum hose... I grabbed part number 11657803732 from the dealership. It is just long enough to run around the engine. With this, you don't need the rubber connectors since it is one long rubber piece that is high temp resistant due to the fabric wrapping. P.S.-I didn't need to zip tie it but I though the red looked cool.
seigi009 is offline   Reply With Quote
Old 02-19-2013, 02:16 AM   #11
jonesenberg
My Ride: '04 330i ZHP 6spd
^-- The zip tie isn't choking the line off?
jonesenberg is offline   Reply With Quote
Old 02-19-2013, 02:33 AM   #12
MJLavelle
My Ride: 2001 BMW 330ci
I did something similar. I replaced the solid section and the flexible sections with a single piece of Teflon hose covered with braided stainless steel, that was rated to 400 degrees. It was a bit of overkill, but it got the job done, and I paid less than the $36 that a replacement solid section would have cost me. It is still working 2 years later. I liked the idea of eliminating the connections to the solid line, since it is just one more place to develop a leak.
@OP - You can't replace that solid piece with rubber hose, and still leave it routed along the valve cover, because the heat from the exhaust will melt it.
Old 02-24-2013, 12:38 AM   #13
seigi009
My Ride: 03 325i
No, the zip tie is on there very loose. It doesn't need the zip tie, I just put it there cause I thought it looked cool.
