Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Old 02-18-2013, 07:32 PM   #1
Eniaro
My Ride: 05-330XI 03-325i RIP
Annoying problem
Whenever I try to start my car temp gage hits red and sits there from 30 seconds to 7 minutes, cold start or warm. Any idea what's causing this.
Key fob doesn't work when buttons are pressed. I'm not sure if it may be the cause. (I locked the doors manually once and all the Windows rolled down)Click image for larger version
Stealership says the dme box needs to be changed
(E46 325i 2003 manual 5s)
Sent from my HTC One X using Bimmer App
Eniaro is offline   Reply With Quote
Old 02-18-2013, 07:34 PM   #2
Prock35
My Ride: 04 330ci convertible
Thermostat could be shut n then open to normal. Had it happen to me in a Honda accord.
Prock35 is offline   Reply With Quote
Old 02-18-2013, 07:37 PM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Have the car scanned for codes using a BMW diagnostic tool. If you have to replace anything it will probably have to the best thermostat.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 02-18-2013, 07:51 PM   #4
Eniaro
Oh and most important... Car won't start until it goes down and all those other pretty lights stay on. Even after the car finally let me start it.
Had a read out only thing I got was ****airflow low
Old 03-07-2013, 04:27 AM   #5
Eniaro
Exclamation Bump
Before I get burned, I'm a noob I know little about cars but I can fix with instructions
Bought a scanner of eBay but I need help could someone translate, and point me to the possible bad parts.
# ERRORS IN UNITS
Unit BMWTNR HW SW-FSW ERRORS / SHADOW-MEMORY
DME -> 7.519.308 19 50 1 error / 6 errors
EWS -> 6.905.670 03 08 no errors
ABS* -> 6.759.045 03 0.0.89 5 errors
LEW -> 6.760.232 04 04 1 error
A/C -> 6.931.602 34 13 no errors
SRS -> 6.912.755 10 32 no errors / 5 errors
IKE -> 6.931.251 22 32 4 errors
LCM -> 6.923.491 16 31 no errors / no errors
ZKE -> 6.924.250 10 30 2 errors / no errors
MFL -> 0.000.000 01 10 no data
RAD -> 6.921.963 45 50 no errors
# ERRORS DETAILS - DTC(hex)/PARAM(hex)
DME -> 08/F2 - Air mass flow sensor signal, short circuit to negative or open circuit
Shadow-memory:
5A/12 - Exhaust temperature before catalyst, bank 1, signal line, short circuit to negative
5B/12 - Exhaust temperature before catalyst, bank 2, signal line, short circuit to negative
5D/12 - Exhaust temperature after catalyst, bank 2, signal line, short circuit to negative
34/02 - Solenoid valve, exhaust flap, short circuit to negative or open circuit
53/14 - Crankshaft sensor, no signal
ABS* -> 5E38/A0 - Yaw rate sensor electrical faulty.
5DF4/20 - Vehicle power < 9 Volt.
5D97/A0 - Sensor cluster Supply voltage out of range.
5DF7/A0 - Vehicle power > 18 Volt.
5E14/A0 - CAN Timeout DME/DDE
LEW -> 09/9D - No CAN message (ASC)
SRS -> Shadow-memory:
06/40 - Side airbag, front right door, resistance too high
70/20 - Seat occupancy detector, break of seat mat
50/20 - Power supply, undervoltage
02/08 - Driver's belt tensioner, short circuit to negative
05/40 - Side airbag, front left door, resistance too high
IKE -> 11/64 - Thermal oil-level sensor
F4/88 - No CAN message
F5/88 - No CAN message (ASC1)
F7/88 - No CAN message (DME2)
ZKE -> 07/21 - Anti-theft alarm system: Siren, Radio interior protection, Tilt alarm sensor or Wire STDWA Short circuit to ground or Open circuit (Car does not have alarm system -Pre-wired (yes)/removed by previous owner (IDK)
45/02 - Central locking system: Lock contact Driver's door (had the door open)
Old 03-07-2013, 05:43 AM   #6
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Not sure what you mean about the 'won't start until it goes down.'
Of the codes you listed, one that stands out is the lack of signal from crank sensor. Check into that more.
Sounds like you have an airleak too, but that might be from a bad sensor.
Not saying your sensor has failed, though. Clear codes and see if it returns. Might have been a momentary glitch...stuff like that happens...but 'no signal' is a significant enough signal to look into more.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 03-07-2013, 06:19 AM   #7
Surrept
My Ride: 2002 330ci
Stick with the stealerships recommendation. Sounds like the dme with all that going on at once.
Surrept is offline   Reply With Quote
Old 03-07-2013, 06:24 AM   #8
drlph25
My Ride: 04 m3, 05 zhp
I had the same problem about a month ago, my car would also stall out after about 30 seconds when it was cold outside...anyway I got the dme replaced and all has been well since then
Instagram----> @dylanrlph
drlph25 is offline   Reply With Quote
Old 03-07-2013, 11:37 AM   #9
trj
My Ride: 325Ci
Shadow-memory:
Out of these codes, You should only be concerned with Crankshaft sensor. Change it.
For Mass Airflow Sensor, clean it with MAF cleaner and clean the electrical connection as well. Do you have aftermarket air filter? This might throw the sensor off balance.
Exhaust temperature codes are engineering codes, and will always remain. Do not worry about it.
Solenoid valve code is for VANOS exhaust solenoid. It will not make your car "NOT START". Do not worry about that too.
I would bleed the coolant first, check Mango's thread on cooling system. I suspect air pocket and thermostat issue.
Clean the crankshaft sensor and connection with MAF cleaner as well and try starting the car.
I am pretty sure you have a BMW scanner 1.4, there is a way to reset DME adaptations. I think I posted the screenshots in Kmoy2002's BMW scanner thread. Do that first.
PS: DME shouldnt be the issue for your key fob. First rectify the mechanical issues in your car. You can test the keyfob battery in any auto parts store. And if the battery is good check if the key is initialized to the car with BMW scanner. If not code the car to accept it and then sync the key with the car. You can search for the steps, there plenty of threads on it.
Old 04-09-2013, 07:38 AM   #10
Eniaro
Tried changing it cant get to it
For Mass Airflow Sensor, clean it with MAF cleaner and clean the electrical connection as well. This might throw the sensor off balance.
Cleaned it = No change I'm assuming I have to change it
The car is completely stock
Car smokes not severely but idle for too long its noticeable however switching to Shell gas seems to decrees it over a time
Trying to get time to do it.
I do, I and I did The crank sensor error went away, in fact most went away
Key was dead -Replaced
Had hole in the Air intake boot, I replaced it.
UPDATE: Car left me stranded wont start, same temp no start. While waiting on a I friend I noticed a rapid ticking/clicking noise coming from the DME/Fuse/Relay Enclosure. Fast forward friend arrives we open the box found what appears to be a relay with #61.36-6 915 327 making the noise gonna run to the stealership get it and replace it I'm hoping this is my only problem.
Old 04-09-2013, 09:35 AM   #11
pppham
My Ride: 740il S500 330CiC
Eniaro, if car won't start and you do have error code for crank sensor (thought you might cleared it now), I would change it if I were you. CPS is relatively inexpensive and easy to change (accept for the Sonata that I help a friend with last week - it is a PITA). You don't want to get stuck somewhere and a toweling bill. Now, for the the temp gauge pegged all the way to red zone when you first starting the car - quick and inexpensive way is to double check to make sure your pos and neg post on your battery seated properly. Why not do a CPU reset! It happened to me on my 740iL before. If the temp gauge fluctuate (middle to red) then I would say you need to bleed your cooling system properly (as dmax an trj mentioned before) and if it stay in RED zone all the time (please do not drive the car until it fix) then I would change T-stat. Hope this will help
pppham is offline   Reply With Quote
Old 04-09-2013, 10:13 AM   #12
jaymemaurice
Location: Anchorage Alaska or Kitchener, Ontario, Canada
My Ride: 01 330ci, 03 Passat
I doubt the DME is actually bad. One cheap thing you can do is clean all the electrical connectors and properly re-apply the white grease (where appropriate) to prevent future corrosion
Rain Sensor Retrofit: Here
Coupe Headline Replacement: Here
jaymemaurice is offline   Reply With Quote
Old 04-09-2013, 10:53 AM   #13
scarede46er
My Ride: 2001 BMW 325i ZSP
No, the crankshaft error is in shadow memory, which is just a way of tracking the history of the car.. Your no start symptom along with the electrical glitches makes me believe that your ignition switch is at fault. Very common and a number of members have reported similar issues that have gone after replacement. The CANBUS errors can also be caused by that. I had the same errors when my ignition switch started acting weird.
Old 04-09-2013, 11:56 AM   #14
NumbaOneNewb
My Ride: 2003 330CI Silver
Yeah dme rarely if ever go bad. You'd have to pour water over it. That can timeout dme error can occur if you're not able to start your car. I've had it happen due to many other issues related to no starting. I'd unplug the maf sensor and try running your car.
Sent from my SPH-L710 using Bimmer App
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 04-09-2013, 03:13 PM   #15
Eniaro
Change the relay Car still wont start Guess I gotta getit towed
I tried changing the crank sensor three times I couldn't get to it.
Temp gage doesn't fluctuate just stays in the redzone until its ready to allow me to start it, the EML light flashes for a brief second just before the temp Gage goes down
Both cables a firmly seated checked too many times.
No corrosion/dirt/water etc anywhere inside the enclosure its pretty clean actually.
The stealership changed the ignition switch.
Id have till later to try that.
Changed the relay -> same $#!+ ticking/clicking no start. sound like a wound up toy that ticks/clicks as it moves
Can a dying/bad battery cause this?
Old 04-09-2013, 03:54 PM   #16
wildirish317
My Ride: 2004 325Ci vert
For some reason, I feel like this will end up being a battery issue..... How old is your battery? I've heard that, when they start to fail, they cause strange electrical problems.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 04-09-2013, 04:09 PM   #17
mxchris727
My Ride: E39, E93 335
Send a message via ICQ to mxchris727 Send a message via AIM to mxchris727 Send a message via MSN to mxchris727
This is a DME issue. The temperature gauge going to the red immediately means that the DME is in programming/safe mode. Your EEPROM is most likely corrupted and you will need to get the DME replaced.
-Chris
I have a computer set up with DIS, TIS, SSS Progman, INPA, NCS Expert, WinKFP, and Tool32 with an EDIABAS interface; PM me if you want to stop by and code your car.
ISTA/P & /D is up and running!
mxchris727 is offline   Reply With Quote
Old 04-09-2013, 04:16 PM   #18
pppham
Eniaro, right now the car will crank but won't start, right? Or it is not cranking at all?
I am no mechanic here, but if ur car crank and won't start, then I would go back to the basic if you have fuel and sparks. If you do then I would bet on the crank sensor. If is not crank then you might have another issues with the immobilizer system (you can verify by using another key).
Old 04-09-2013, 04:22 PM   #19
Eniaro
I'm honestly not sure I'd have to go back and check. I'd buy a new one but I have no cash its either tow or battery.
Would that cause the relay to tick like a machine gun? Place I bought the car from has been giving me a run around. They tried reprogramming a used one didn't work.
Crank no Start.
Temp gage drops and the EML light flashes it used to start
Old 04-09-2013, 04:25 PM   #20
pppham
Forgot to ask you about using PAsoft. Did you run EWS-DME adaptation function in DME?
