Old 02-18-2013, 11:07 PM   #1
sjacoby112
My Ride: 2002 325ci
Question Help changing headlight lenses!!
Hey so long story short, I am unable to take out my corner light on the passenger side . My lenses are getting pretty beat and I'd love to buy replacements, but seeing as I can't take out the one corner light am I just S.O.L. on changing it? Or is it possible to get the lens off without taking the corner out??? Any help would be great, thanks guys!
sjacoby112 is offline   Reply With Quote
Old 02-19-2013, 12:28 AM   #2
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Yes, you have to takeout your turn signal before taking off the lens. Take long thin screwdriver push the tab down and then pull out your turn signal.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 02-19-2013, 10:04 AM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
You probably have the corner lights that need to be pushed down to come out. Look at the hole above the corner light and you will probably see a flat piece of plastic, press down on it with a screwdriver and you will be able to slide it out.
When you re-install the headlight lenses make sure not to pinch in the black guides on the headlight itself inwards.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 02-19-2013, 11:14 AM   #4
BMWCaptain
That's right. You just push down the tab with a screwdriver and pull it out. Sometimes the tab can be broken off. Find the end of it and push down with your screw driver.
BMWCaptainE46.com
Old 02-19-2013, 10:05 PM   #5
sjacoby112
My Ride: 2002 325ci
thanks guys, they are actually screw in type and i know how to take them out. my issue is the tab on the headlight that it all clamps to mysteriously broke off and i only had one option to fix it instead of replacing the whole headlight (which now i just might do). so that was a more permanent fix so that the corner wont come off unless i break it off lol... stupid i know but it was what needed to be done. so thats why i was looking for a loophole on getting the lens off without taking the corner off.
headlight, lens, replacement
