Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 02-19-2013, 04:22 PM   #21
Grand Superpatriot
My Ride: M54B30
something is bent, just gotta find out what
Cooling | Maintenance | Vacuum | Suspension | Costs
"Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs
Old 02-19-2013, 04:34 PM   #22
Alex323Ci
My Ride: M3 & 323Ci (sold)
here is a photo of when i did my bushings showing the bracket and arms too. although M3 still similar. you can see the bracket and the arms for reference to my above earlier post.
http://forum.e46fanatics.com/showpos...&postcount=219
OEM CSL WHEELS - OEM CSL BRAKES - OEM AUTOFOLD MIRRORS - CSL TRUNK - CSL DIFFUSER - AA SPORT TUNE - AA PULLEYS - BILSTEIN PSS9s - AUTOSOLUTIONS SSK
CF CSL RACE LIP - NAVI HU - BMW PERFORMANCE CF STRUT BAR - BMW GROUP-N MTRMTS - UUC SS BRAKELINES, TRANS MOUNTS, RTABs - 4.10 BMW M-SPORT DIFF
Old 02-19-2013, 04:47 PM   #23
bmwdav
My Ride: 2001 BMW 330Ci
I'll take a look and get back to you guys asap
bmwdav is offline   Reply With Quote
Old 02-20-2013, 03:08 PM   #24
bmwdav
Took these pictures of the right RTAand RTA bracket/bushing. From comparing them left to right, the right bracket seems to be off center, and not lining up with its holes a at least 2 bolts. Could this be causing my problems?
ID:	491621   Click image for larger version
Old 02-20-2013, 03:10 PM   #25
bmwdav
This is the left, which sits perfectly
Old 02-20-2013, 03:16 PM   #26
Grand Superpatriot
My Ride: M54B30
No that's just toe setting. looks like your bushings are tired. i forgot.. did you replace them yet?
Old 02-20-2013, 03:25 PM   #27
bmwdav
No, those bushings are original
Old 02-21-2013, 02:08 PM   #28
bmwdav
Any thoughts on that?
Old 02-21-2013, 02:12 PM   #29
Grand Superpatriot
My Ride: M54B30
Yes. Replace them.
Now that I think about it, worn RTABs may also cause camber change as well as obvious toe change. It's the single most important bushing back there. The more your trailing arm moves around, the more the rear wheel moves around. this will likely accelerate wear on the remaining 8 control arm-related mounts back there.
Elasto-kinematics. This is a term you guys will start hearing me say more and more. pretty cool term!
Old 02-21-2013, 03:34 PM   #30
bmwdav
Ok lol thanks. What other mounts are you talking about that are being increasingly worn?
Old 02-21-2013, 03:41 PM   #31
Grand Superpatriot
My Ride: M54B30
See sig, suspension link. The BMW suspension has an incredible amount of mounts and rubber in the rear that need replacing at some point. It's an extremely massive job, see CPOSK's thread on it
Old 02-21-2013, 09:16 PM   #32
nike001
My Ride: 2004 330i ZHP
RTABs are a b!tch and a half. Don't pay a dealer to do it, there are plenty of other fellas out there that have the right tool that can do them easily.
330i ZHP 6MT | H&R Sport Cup | BMW Performance Intake & SSK | OEM Clears | WeissLicht Angel Eyes | Coby Wheel
nike001 is offline   Reply With Quote
Old 02-22-2013, 12:51 AM   #33
Grand Superpatriot
My Ride: M54B30
+1 you ABSOLUTELY NEED the MIS RTAB tool. no two ways about it. do not attempt to do this job without the proper tool. believe me... that's a day of my life i'll never get back.
Old 02-22-2013, 03:51 AM   #34
Andy2108
My Ride: E46M3E92M3'67Cobra
Replace your Rear Trailing Arm BUSHING!
De gustibus non est disputandum.
Old 02-22-2013, 03:54 AM   #35
Andy2108
Here: http://store.bimmerworld.com/meyle-h...rtab-p572.aspx
or
You could do a oem RTAB with "limiters" which limit the movement, increasing performance and the life of the bushing: http://store.bimmerworld.com/e36e46z...age-p1429.aspx
Old 04-30-2013, 09:29 AM   #36
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
Are you sure you did both rear control arms? I think you're mixing them up with camber arms. There are 'upper control arms' which act as spring perches, and there are the 'lower control arms' that we know as camber arms. I have a bent one now and it really threw off my camber and toe.
hi its me alec is offline   Reply With Quote
Old 05-01-2013, 09:12 AM   #37
teamdfl
Lemony Fresh
My Ride: 325it
Originally Posted by hummer View Post
RTAB carrier is the toe adjustment, lower control arm excentric is the camber adjustment. The shocks don't have any influence on either of these adjustments. Is the ride height the same both sides? Is the upper control arm damaged or spring broken?
This. The RTAB has jack squat to do with camber. One of the three control arms is bent and/or control arm bushings are shot (other than the RTAB). The rear subframe could be tweaked as well.
Mod the driver first. Participate in your local BMWCCA driving school. Have you joined BMWCCA yet?
My Track Schedule
The solution to the lack of headroom in the X6
teamdfl is offline   Reply With Quote
arm, bushing, camber, negative, trailing
