General Off-Topic
Everything not about BMWs. Posts must be "primetime" safe and in good taste. You must be logged in to see sub-forums. Click here to browse all new posts. |
#1 |
macbook charger
My boss's macbook charger won't charge anymore, and she doesn't want to pay the $75 for a new one. So I took a look at it, and saw some wire sticking out of the insulation. I stripped the insulation off around the area and looked at the wire, and it's all just 1 coil, no separate wire insulated in the middle. So, can I just twist this up really tight and wrap some electrical tape on it to fix it?
#2 |
'a certain moderator'
ask her if $75 is worth a fire in her home/office
what if you 'fix it' and it starts a fire in her home. who fixed it?
#3 |
Are they really $75?
#4 |
have you tried ebay or craigslist for a working one?
#5 |
You're probably right Sim. I have no idea if they really are $75, that's what she told me when she was looking for a replacement.
#6 |
or monoprice.com
#7 |
The ones on Amazon and eBay are mostly counterfeit. No, it is not one wire. You are going to fry her computer or worse, start a fire.
Look on youtube for Magsafe repair. There are plenty of guides. 9/10 times Apple will give you a new charger if you go in with the busted one. It has to be less than a year old, but they don't really have any way to keep track (unless it is the very old style).
#8 |
make sure you know if it requires a magsafe1 plug tip or magsafe2 plugtip. The newer retina display mac pros require magsafe2 tips
2010 Acura TSX
#9 |
Ok after looking at the youtube vid I went back and pulled apart the outer layer of wire some more and found the inner wire. That one's insulation is still completely intact. I can't do the fix on the youtube vids tho because that would leave her with a 1.5 foot long cord lol. I guess I'll have her try to get a free replacement.
#10 | |
Does it have the L shaped, aluminum end? Or the old white end?
#11 |
L shape aluminum
#12 |
You've got a shot. But that stripped wire is going to be very hard to explain.
#13 |
Lol how so? Just say I tried to fix it myself but was unable to. The insulation is cleanly cut off, it doesn't look worn or torn.
#14 |
Über-Geek
My Ride: '01 Topaz Blue 330ci
seriously if the inner conductors jacketing is still intact just solder the braid back together and cover it with either electrical tape or shrink tubing..
#15 | |
#16 |
just go to genius bar and bitch about, theyll give you a new one
#17 |
why is this your responsibility?
-Mike
** Removed ** Ask an Insurance Adjuster Anything Cup of Joe for a Joe! http://www.greenbeanscoffee.com/coj/ buy my car! |
#18 |
#19 | |
Go to the Genius Bar. Make sure you make an appointment before you go. I had that happen to me. I think I read something about how you wrap up the charger and the manufacture poor insulation on the charger. Mine caught a fire once. Luckily it didn't burn down my home http://blogs.courant.com/connecticut...ptop-char.html |
#20 |
I had mine replaced for free a while back. I'd try the apple store first.
http://support.apple.com/kb/TS4127 |
