Engine block coffee table - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
General Off-Topic
View Poll Results: block color
White 4 10.81%
Red 1 2.70%
Dark Blue 0 0%
Gun metal 32 86.49%
Voters: 37. You may not vote on this poll
Old 02-19-2013, 01:45 PM   #1
-Ross-
My Ride: Jeep JK/Yamaha FZ1
Hey all,
I'm starting to build my coffee table and having some issues finding legs for it. I wanted something a little different so I went with a Volvo 5 cylinder out of a S70. Problem is, it's a little narrow to leave supporting itself. Any one have suggestions on some kind of legs that would kinda arch out from under it to stabalize it better?
Second question is what color to paint it. I googled it and saw some cool ones in white, black, red, blue, ect. Thoughts?
Originally Posted by NFRs2000nyc View Post
Shut up and drink your snow from your plastic cup you hungry homeless homosexual.
-Ross- is offline   Reply With Quote
Old 02-19-2013, 01:47 PM   #2
217Bimmer
My Ride: Dodge Durango
** Political signature removed - Tim330i **
I always have to laugh when I see a thread described as "Not Work Safe." Is there anything on the OT forum that's really "work safe"? If I were your boss, I'd be mad if you spent any time on this forum at work at all. How is a picture of a naked girl any less work safe than, say, a picture of a matador getting gored in the *** by an angry bull? - VaderDave
217Bimmer is offline   Reply With Quote
Old 02-19-2013, 01:51 PM   #3
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
repurpose some cam shafts
-Brendan
Old 02-19-2013, 01:52 PM   #4
IdahoToyo
My Ride: 4WD Tundra / GS500F
Could you do something like this with the engine itself being the base and then "legs" supporting the glass or surface top? Similar to below? I goggled that engine and couldn't seem to find a decent image out of the car.
-- Kyle --
The difference between school and life? In school, you're taught a lesson and then given a test. In life, you're given a test that teaches you a lesson.
IdahoToyo is offline   Reply With Quote
Old 02-19-2013, 01:55 PM   #5
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
haha, no woman would let that fly
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 02-19-2013, 01:56 PM   #6
-Ross-
Originally Posted by 217Bimmer View Post
http://www.ebay.com/itm/170789492522...84.m1439.l2649
Old 02-19-2013, 01:57 PM   #7
-Ross-
Here's the block I got. I don't think the whole piston and rod idea would work
Looking for something to raise it up a few inches and stabalize it with it being a narrow block, and not a v8.
Old 02-19-2013, 02:46 PM   #8
T R E
My Ride: 2000 328ci
it has to be polished like the V8, not painted. otherwise it could be wood or cardboard.
maybe aluminum conduit for legs or a base. It should look mechanical also, like the pistons do. the next best option is a wood base, holding it up like a trophy of sorts.
2000-328-Ci (Sold after 10 years and 40k miles)
T R E is offline   Reply With Quote
Old 02-19-2013, 02:53 PM   #9
-Ross-
Thanks. I was thinking of taking some 1'' pipe and bolting two long pieces to the bottom, then 45 degree elbows down,ect kind of like a compressed hanger shape.
Old 02-19-2013, 02:55 PM   #10
-Ross-
I will be putting red or blue led's in it so that's why I'm thinking outside the usual metal colors.
Old 02-19-2013, 03:41 PM   #11
Fisch330ciTopasBlau
Yes...I do think I hate you
Fisch330ciTopasBlau's Avatar
My Ride: E46 Dinan 330ci
get some triangle brackets cut then welded?
-8/21/2007 RIP Grandma
-pessimum genus inimicorum laudantes: flatterers are the worst type of enemies
Fisch330ciTopasBlau is offline   Reply With Quote
Old 02-19-2013, 03:55 PM   #12
evilstar
My Ride: 633csi & 325i
you could just bolt some large flat metal bars to the bottom and top to stablize it.
evilstar is offline   Reply With Quote
Old 02-19-2013, 04:17 PM   #13
-Ross-
Might do something like this. Just want to do something original than just straight pipe across the bottom. I have some heavy tempered glass so not to worry about the top.
Old 02-19-2013, 05:28 PM   #14
SamDoe1
My Ride: 4cyl of fury
I have an inline 6 cylinder engine block out of an E30 that's waiting to get dip coated. I originally planned on using some steel bars for the bottom, welding them at an angle that would be more pleasing than straight, and grinding them to shape. Because I lack a welder and also because wood isn't terribly expensive, I decided to make the same shapes out of sanded and stained wood.
What method did you use to get the block cleaned up? Did you get it hot tanked or media blasted?
Old 02-19-2013, 05:49 PM   #15
-Ross-
I haven't cleaned it yet till I figure out what I want to do with the legs. I'll probably use a ton of brake cleaner, then some kind of stripper and power washer. I'm going to leave all tha polished parts raw and polish the top of the block.
Sent from my HTC One X using Bimmer App
Old 02-19-2013, 06:03 PM   #16
SamDoe1
Ah ok. I was thinking about getting mine media blasted and then spray paint it to give it some gloss but I think I'll try your way first of hitting it with brake cleaner and see what happens.
This, of course, will have to happen when it finally gets warm outside again. That and after I figure out how to take the fvcking crankshaft out of the block.
Old 02-19-2013, 07:17 PM   #17
-Ross-
I was going to go the media blast but I don't feel like paying someone. I can't wait for the weather to warm up, just going to use a space heater in the garage and wing it.
Old 02-19-2013, 08:31 PM   #18
M3Inline6
aka...Dark Snow
My Ride: '17 Nardo Grey M4
I like them. They always catch my attention at various dealerships/events.
Originally Posted by Qwel on "Manhattan Project"
You heard of me.....burgandy and outlines like murder scenes; Germany..took ferns and flat whites for blurring greens.
M3Inline6 is offline   Reply With Quote
Old 02-19-2013, 11:35 PM   #19
jwm5
My Ride: station wagon
stick with auto oriented item utilize some other part from a volvo to use as the base/legs.... one thought is a few control arms, but I am not sure if they are good looking, a quick yahoo search of volvo control arms wasnt great looking imo, but since it is an engine use another part from the car if you can modify/adapt it to work...
jwm5 is offline   Reply With Quote
Old 02-20-2013, 07:19 AM   #20
Rubenk
My Ride: M35A2
Definitely get the block hot tanked, blasted, or otherwise thoroughly clean, then clear coat it. Otherwise it will eventually oxidize.
As for supporting it, you could still use pistons as "feet" on a flat bar going underneath the block. Perhaps use a camshaft instead of flat bar?
Rubenk is offline   Reply With Quote
