Sponsored by BimmerWorld
Old 02-19-2013, 10:01 PM   #1
123Shift
My Ride: 2001 325i
Control arm and bushing advice
Planning on doing control arms. Seems the Meyle hd is the way to go from what I've read. Question is do I go with the meyle HD kit for $335 or get the control arms for $147 each and get the powerflex bushings for $150? Total cost of about $450. Just wondering if its worth the extra 100 plus bucks for powerflex or are the Meyle bushings good enough? Thanks for your advice!
123Shift is offline   Reply With Quote
Old 02-20-2013, 12:12 AM   #2
123Shift
My Ride: 2001 325i
What about URO parts. Way cheaper then I could also do the tie rods and other stuff.
Never mind on the UROs. I found a thread and everyone was bashing them. Sometimes you get what you pay for.
Old 02-20-2013, 12:44 AM   #3
Zell
Zell's Avatar
My Ride: so turbo wow
Go powerflex, you can reuse them.
Old 02-20-2013, 12:46 AM   #4
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
I have some meyle hd fcabs if that's what you decide
Old 02-20-2013, 07:34 AM   #5
WDE46
My Ride: '13 128i, '04 330Ci
Agreed. I've never heard anything good about them. I only use their jack pads (you can't possibly **** that up) and the aluminum WP pulley.
I have PF. They're alright, but I wouldn't get them because they're reusable. They will last longer than anything, that's for sure though. I think the Meyle HD FCABs are fine and won't give you as much road noise as the PF.
I currently have Meyle HD control arms with PowerFlex FCABs and it is perfectly suitable for the street. If I ever replace the PF, I will probably use Meyle HD to reduce NVH.
Old 02-20-2013, 07:37 AM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
URO is garbage.
Go with Meyle for everything.
Old 03-16-2013, 08:17 AM   #7
sling
My Ride: 2004 330cic
I put PF on my 2002 330cic at 60k miles. They were still great at 134k miles when i traded it in for a 2004 330cic. Btw just now ordered a set of PF for that car. Never a squeak.
sling is offline   Reply With Quote
