Old 02-22-2013, 01:27 PM   #21
smooth1
My Ride: BMW FTW
I'm on a Mac. Elevation?
smooth1 is offline   Reply With Quote
Old 02-22-2013, 01:31 PM   #22
basketthis
My Ride: state to state
Lol. Been editing my previous post before realizing that you responded on page 2 about 4 mins ago.
approx 12 feet above sea level...
basketthis is offline   Reply With Quote
Old 02-22-2013, 02:38 PM   #23
smooth1
My Ride: BMW FTW
It's possible your MAF is reading high or your idle control is not doing its job. I'd still suggest you look at some of those logs for reference. They're much easier to look at than what you're currently using.
Old 02-22-2013, 03:49 PM   #24
basketthis
After going through this, I'm considering buying a different scan tool. I know you recommended another software initially. Right now, I'm looking into OBDPros USB model here. And the OBD 2007 software possibly? Here. I will probably pair it with an old toughbook or laptop.
This seems to be the legitimate and most reliable software, includes future updates, and covers every vehicle. Appears it will monitor every system in real-time. Can you advise on this software/hardware combination?
Old 02-22-2013, 04:41 PM   #25
smooth1
My Ride: BMW FTW
I only suggested you playback some logs from another 325 to compare to.
That software is going to be very slow. It's up to you what you decide to pursue.
Old 02-22-2013, 04:50 PM   #26
basketthis
Yes. I have played back logs. They seem that the MAF isn't reporting properly on my setup.
Why do you say that software will be slow? I don't have any experience with software and am not sure what to look for so any help is great. Also, does the scanner itself seem nice?
More info on the MAF: gonna grab the one locally for 40 and try it in a couple hours. Will report back on that.
So, back to square one. The guy was claiming the MAF was oem Siemens type. Tried to pass off some aftermarket piece on me... Looks like I'll be ordering one.
Old 02-22-2013, 10:03 PM   #27
smooth1
My Ride: BMW FTW
Any OBD2 standard software will be slow because it is limited to OBD2 standards.
Old 02-22-2013, 10:06 PM   #28
basketthis
I'm trying not to read into what you are saying, but I think you're saying that I can buy the cord I choose, either obdpro or obdcom, and get the software that you linked earlier and I will get the results I am looking for?
Old 02-22-2013, 11:04 PM   #29
smooth1
My Ride: BMW FTW
No, what I said was any standard OBD2 software, which is what you've posted so far, will be slow because it is using the standard slow OBD2 protocols. I'm not sure how you derived that from what I said. If you're looking into the software I posted the links to the cable you need are right on the website. If you're happy with standard OBD2 software then I've given you some things to look at already in your logging.
Old 02-23-2013, 02:05 PM   #30
basketthis
Thanks for your help. Gonna have another look at that link. Missed it the first time.
My main thing is to be sure the cable will work with other vehicles that i own.
Old 02-24-2013, 12:56 AM   #31
smooth1
My Ride: BMW FTW
Most softwares are made by lazy people who would rather use an interpreter like the ELM327 than learn the real protocols and support a direct connection. That means you're pretty limited. Good luck.
Old 02-24-2013, 09:44 AM   #32
basketthis
Looking at inpa now. And getting a serial port to obd2 connector. I've read a couple writeups and they seem to be the best. No drivers needed and I can still do abs, airbag, etc... (which is the big thing you lose with alot of those softwares)
Old 02-24-2013, 09:59 AM   #33
smooth1
My Ride: BMW FTW
That will also be super slow, but you can connect to every module. Very useful.
Old 02-24-2013, 10:16 AM   #34
basketthis
Lol. I'm trying to avoid slow here. Would a change in software fix this? And would the software you recommended work with this type of cord? Apparently this is "the way BMW connects to the cars". Why would they use slow graphs?
Old 02-24-2013, 11:00 AM   #35
smooth1
My Ride: BMW FTW
Unfortunately the way the factory software is designed it requests an entire packet full of information to pick out one single item, like RPM. To get two items you've moved a huge amount of data. The factory software also operates at the slowest baud rate that the DME supports. You want to have it anyway, so I'd suggest you try it out.
Yes, you can use that software and INPA with a simple FTDI based USB to K-Line cable. They're about $10 for the cable.
Old 02-24-2013, 11:05 AM   #36
basketthis
I'm pretty much convinced I'm going to get the serial port to obd2 connector. Unless there is a major reason why not. So I guess my question is, will the software work with that cord?
Old 02-24-2013, 12:51 PM   #37
smooth1
My Ride: BMW FTW
Already answered that.
Old 02-24-2013, 01:11 PM   #38
basketthis
Didn't realize it was FTDI. Thanks
Old 02-24-2013, 02:02 PM   #39
smooth1
My Ride: BMW FTW
INPA will work with any cable that creates a COM port. USB to Serial adapters will create a virtual COM port that will work. The other software uses direct USB so only FTDI devices are supported.
Old 02-24-2013, 02:34 PM   #40
basketthis
INPA will work with any cable a COM port. USB to Serial adapters will create a virtual COM port that will work. The other software uses direct USB so only FTDI devices are supported.
I think it's starting to make sense.
For accessing all systems, serial port to obd2 connector with inpa.
For reading sensors and putting everything into a quality graph, kline usb to obd2 with the software you recommended.
I realize I am dragging this out. This is very informative and getting little bits and pieces from other threads clearly hasn't helped to this point! Lol. I have never seen any comments on how fast or slow the software reads/graphs. Thanks again. And if this is the case, I will probably end up with multiple cords.
