Old 02-20-2013, 08:51 AM   #1
BMW-Diaz
My Ride: 2003 325i
Is this an Aux in?
Recently I found what seems to be an aux input, it is to the left of my steering wheel, above the light controls on the side of the panel there is a cable that comes out and has tape on it, it is like a stand for a gps or something and on the side it says aux in, not sure if this can be used as an aux in or not
BMW-Diaz is offline   Reply With Quote
Old 02-20-2013, 11:09 AM   #2
basketthis
My Ride: state to state
Sounds like you are describing a power cord...
basketthis is offline   Reply With Quote
Old 02-21-2013, 09:00 AM   #3
BMW-Diaz
My Ride: 2003 325i
What exactly is that? The thing says aux in on it
Old 02-21-2013, 09:09 AM   #4
basketthis
A picture would help. If it says "aux" it probably is an audio input. We are only speculating at this point. So let's see this thing!
Old 02-21-2013, 10:46 AM   #5
BMW-Diaz
My Ride: 2003 325i
here
Old 02-21-2013, 06:10 PM   #6
basketthis
Satellite radio mount. Nothing will play through your stereo... Unless you mounted a satellite radio there. That is an aux output, not input to the radio. How that makes sense
Old 02-21-2013, 06:47 PM   #7
BMW-Diaz
My Ride: 2003 325i
So it is an aux, so if I plug my iPod into the aux will it connect to stereo
Old 02-21-2013, 06:47 PM   #8
Japanrot_325i
My Ride: 03 325i
Try it
Japanrot_325i is offline   Reply With Quote
Old 02-21-2013, 06:48 PM   #9
BMW-Diaz
My Ride: 2003 325i
Yeah I'm trying to find out first before I go out and buy an aux cord
Old 02-21-2013, 07:15 PM   #10
basketthis
No. It won't. Sorry if I didn't make that clear enough.
Old 02-21-2013, 07:21 PM   #11
BMW-Diaz
My Ride: 2003 325i
Damn what is that thing good for then
Old 02-21-2013, 07:30 PM   #12
basketthis
It's a satellite radio docking station. You need the satellite radio.
EDIT: and you would only use it if you have an existing aux port in the car...
Old 02-21-2013, 07:47 PM   #13
Japanrot_325i
My Ride: 03 325i
If there is aux cord run from that to your stereo it shouldn't matter what you plug in it you should hear it.
Old 02-21-2013, 08:14 PM   #14
basketthis
There's no aux cord run from that to his stereo.
What that is designed to do is take the satellite radio audio signal and send it through a 3.5mm cord into the "aux" port INPUT if it already exists in the vehicle.
Like this:
Satellite radio antenna -----> Satellite radio audio ------> aux input in vehicle
The other option (which was used in this particular case; hence, no existing aux port) is the wireless broadcast option:
Satellite radio antenna -----> Satellite radio audio ------> wireless broadcast to an FM station which the existing FM receiver will pickup.
EDIT:
You can go to Best Buy or any car audio shop and have an aux port put in. My recommendation: search around. There are great guides on how to use the cd changer input to get high quality aux input although it does take a little work on the installer's part. And good luck.
Old 02-21-2013, 09:06 PM   #15
Japanrot_325i
My Ride: 03 325i
You shouldn't have to go through the cd changer. You can order an aux install kit from bavauto. It plugs right into the back of your stereo.
Old 02-21-2013, 09:20 PM   #16
basketthis
I didn't say "through the cd changer"...
This is working great for me!
Old 02-21-2013, 09:56 PM   #17
Japanrot_325i
My Ride: 03 325i
You said through the cd changer input. Unless that's the same as the aux in on the back my bad lol
