Sponsored by BAVSOUND
Old 02-20-2013, 06:02 PM   #1
soul786
My Ride: 2003 325xi
New Battery Terminal or Just Use a Ring Terminal straight to battery?
I'm installing a new audio system. Complete everything from 2 amps and a sub to all the speakers also.
The way I've got it set up in a drawing, a 0 gauge wire will go into a distribution block, 2 4ga wires come out to each amplifier. The 0 gauge wire is the issue though.
Should I just terminate with a ring terminal bolted to the battery? Or look into a whole new aftermarket battery terminal? What gauge is the stock power wire anyway and there's a second wire there too (on the +ve side). I'd need the same on the -ve side too (0 gauge is also going to a dist block, 2 4ga out).
Any help is appreciated. I'd like to keep this as clean as possible.
soul786 is offline   Reply With Quote
Old 02-20-2013, 09:40 PM   #2
TurnersInOz
My Ride: 2004 325i
A ring terminal on the 0GA going to the positive battery terminal is fine. Make sure it is fused as well.
Don't ground straight back to the battery, you can wind up with ground loops doing that. You'd be better off grounding the amps directly to the frame.
TurnersInOz is offline   Reply With Quote
Old 02-21-2013, 12:04 AM   #3
soul786
My Ride: 2003 325xi
Yep, for the 0awg wire I'll be using a 300A fuse.
And for the ground would it be better to go from the distro block then to the chassis on a well grounded point?
Old 02-21-2013, 08:45 PM   #4
TurnersInOz
My Ride: 2004 325i
I grounded my amps directly to the chassis with no distro block.
Depending on what you are running from your amps (i.e. subs, mids, highs), using the same ground could also induce noise. It would be best to keep them separate.
4GA is a lot easier to terminate than 0GA anyway.
Here's one article that has good recommendations: http://www.termpro.com/asp/pubs.asp?ID=121
Old 02-21-2013, 11:07 PM   #5
soul786
My Ride: 2003 325xi
Thanks for the link.
So would you suggest not to use a distro block for the 4awg grounds from the amp and just draw those directly to a chassis ground?
Old 02-23-2013, 02:31 AM   #6
TurnersInOz
My Ride: 2004 325i
Sure. Here's some more good reading:
http://www.polkaudio.com/forums/arch...p/t-50193.html
http://www.caraudio.com/forums/wirin...tor-whine.html
I would ground each amp individually.
