Australia
Old 02-21-2013, 09:24 AM   #1
f4n4tik
My Ride: M-Sport 320Ci e46
Bmw vs audi!
So I'm seriously considering getting rid of my 04 320ci m sport coupe to possibly get an audi a4 b7 s-line Quattro. What do you guys think? How do they stack up against each other? Pros and cons for both.
f4n4tik is offline   Reply With Quote
Old 02-21-2013, 04:51 PM   #2
Ballistic325
My Ride: slow and steady
2 completely different cars. Manual / CVT / auto? What engine?
Obviously the driving dynamics and road feel are going to be unique to each car...
Why areyou changing?
Sent from my V9 using Bimmer App
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 02-21-2013, 06:29 PM   #3
f4n4tik
I want to get a 2.0t manual, my BM is just an auto and I dunno it's a really nice car I'm just bored of it. Have you ever known anyone to switch and not like audi?
Old 02-21-2013, 07:44 PM   #4
dan_1337
My Ride: 330CiC
It'll be less fun to drive than the BM and doesn't look anywhere near as nice as a two door coupe.
dan_1337 is offline   Reply With Quote
Old 02-21-2013, 07:45 PM   #5
trive2
My Ride: 1989 BMW 535i
Apparently the 2.0 litre engine is a bit of a trashheap. Where the 1.8 has a huge cult following, the 2.0 seems shunned.
The Quattro system is indestructible, the manual boxes are very strong and the cars are more reliable than you might think. I'm getting a B5 A4 1.8T Quattro myself.
trive2 is offline   Reply With Quote
Old 02-21-2013, 08:02 PM   #6
f4n4tik
I've been looking into a few mods for the b7, they can actually look really good. Hate to say it but... its quite slow, not 'fun'. I'd put it more in the nice to cruise around in category. Dont get me wrong I love the car, but i just think the Audi has more potential.
Old 02-21-2013, 08:05 PM   #7
JTripper
My Ride: 3dirtyci
If you thought bimmers gave electric problems! Haaa! Wait till you get that audi (some pronounce it: aweedy) lol
Two things that scared me away: #1 someone i know had to change a starter on an 05 a4 and it was against the damn firewall! And #2 another homie of mine has an 09 a6 and to change brakes u have to use an obd one that you have enter the vin for the car for the calipers to retract and slip the mew pads in!! WTFF?! Lol i'll roll with the older Germans plz!
@BMWorNADA
BMWCCA
///MPIREBOYZ#239
1st Gen. AC Schnitzer Strut Bar, M3 Face, Gunmetal VMR V710FF 18x8.5/9.5 , AEM Logger & longtube CAI, H&R Sport Cup Springs and Front Struts, Koni Rears, Reinforced Towers, Int. Trim Wrapped, Custom FX-R Retrofit , 3k Fogs, Frosted WeissLichts, 8 Track Player with Dolby.
JTripper is offline   Reply With Quote
Old 02-21-2013, 08:15 PM   #8
f4n4tik
Yeah I know a few mechanics that say the Audi's are better built, particularly the newer b7's and b8's. I don't really mind if its a 1.8T or 2.0T but just has to be a quattro with a manual box. Also another reason why I'm thinking about buying an Audi is that you can actually find one in a manual, they are virtually non existent in an e46 m sport coupe and with decent milage
Old 02-21-2013, 08:28 PM   #9
f4n4tik
Iv never had electrical problems with either of my 2 BM's. Its not like there is a specific defect in the electrics in Audi's. How often do you have to do that though.. and also I don't think thats the case with the pads on an a4 b7.
Old 02-21-2013, 10:05 PM   #10
DesiredM
My Ride: E46 M3
personally i almost made the swap to audi not to long ago, was looking at their 10-11 S3 models but just couldnt get away from BMW. Audi make good cars, but generally a bi**h to work on. What turned me off was how common it was for their timing chain to snap and how much cost/effort was involved in repairing that. Then again my M3 screwed me with my subframe
not sure what it would be like to drive but dont think you will notice a massive difference between the two, personal preference i guess is what it comes down to.
DesiredM is offline   Reply With Quote
Old 02-21-2013, 10:40 PM   #11
f4n4tik
Is the timing chain a problem on all Audi's including the a4? And when you say a lot of money, how much are we talkin?? should really invesigate audizine forums hey haha. Btw just on the subframe issue... How much is it costing you to fix and other than getting it inspected were there any other obvious signs of it beginning to crack?
Old 02-21-2013, 10:47 PM   #12
DesiredM
My Ride: E46 M3
not sure about all audis you would have to investigate but it looks to be a common problem on some of them but it usually costs around $4k to repair depending on the damage caused when it breaks.
My subframe wasnt bad, had 3 cracks that were all relatively small (1-3cm) and i had it welded, epoxied and reinforcement plates installed along with a custom bar the guy designed for it as well for 3500 in total. Not bad considering he did a fantastic job and got BMW to inspect it after it was done and they said it was perfect and were even impressed themselves with the job. In terms on signs of it about to start there arent really any, basically you just have to catch the cracks when they start as the grow very quickly. The guy who repaired it for me said he had a customer come in with 2 hairline cracks under 10mm and encouraged him to do the repair however he said no he will take his chances...came but 6 months later and the cracks were 10-15cm long and the subframe was basically hanging from the back of his car. Obviously an extreme example but it can happen.
Old 02-21-2013, 10:53 PM   #13
zander271
My Ride: 6spd ZHP/5sp XI
The 2.0 is a trash heap? Early 1.8's and 2.0's had issues but those have been worked out now. The biggest issues you will run into is PVC failure and some poorly placed vacuum lines which are a total pain in the ass to change. Trust me I have done it for a couple friends and my sisters car.
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 02-21-2013, 11:02 PM   #14
f4n4tik
Thanks for the info man.
Old 02-21-2013, 11:10 PM   #15
f4n4tik
Seems like your on the fence about Audi's....
Old 02-22-2013, 12:52 AM   #16
Ballistic325
If you like to cruise, use a little boost and enjoy the feeling of the AWD you'll enjoy the Audi.
For me, I like a more engaging drive and I like road feel that the E46 (with M-Sport II suspension) gives. I test drove an A4 2.0 Quattro and didn't like it. It felt vague, disconnected and under powered.
These are just my comments and your perspective may be different so you should definitely drive it and get your own feel for it
I can help with
* RTABs
Old 02-22-2013, 03:52 AM   #17
BMW E465
My Ride: 1dirty5
Buy my b8 a4! Low kms and manual trans (1.8t fwd though)
BMW E465 is offline   Reply With Quote
Old 02-22-2013, 04:09 AM   #18
f4n4tik
How much!!
Old 02-22-2013, 04:51 AM   #19
BMW E465
My Ride: 1dirty5
How much!!
PM sent.
Old 02-22-2013, 05:06 AM   #20
postal
My Ride: E46
whenever I think about buying an Audi, I simply remind myself of this picture:
That's the back of the engine (you know, up against the firewall). Good luck servicing that. (to be fair, it's the V12)
postal is offline   Reply With Quote
