E46 Convertible
Old 02-21-2013, 04:07 PM   #1
taylor192
My Ride: 2003.5 M3
Hard top coding?
My car came with the hardtop kit installed, yet I don't have a hardtop so I removed the kit (when repairing the main lift hydraulic cylinders) and sold it.
Now that I finally repaired the main lift cylinders I am getting an error:
0049 Switch, hard top, short circuit to ground or open circuit
I am wondering why I am getting this error without the hardtop kit installed. I found someone else who had this same problem, yet no resolution.
http://forum.e46fanatics.com/showpos...25&postcount=6
I guess I could use a resistor to simulate the switch that senses the hardtop is installed or not.
Old 02-21-2013, 04:24 PM   #2
taylor192
My Ride: 2003.5 M3
Found another member claiming the same problem after removing the hard top install kit. I should have never sold it
http://forum.e46fanatics.com/showpos...3&postcount=10
Old 02-21-2013, 05:09 PM   #3
E46-Cabrio
My Ride: E46 330CI Cabrio
Hardtop preparation is a codable option, so when you remove the kit from the car, you also need to remove option $380 or $982 from the vehicle order, otherwise you will get a faultcode.
E46-Cabrio is offline   Reply With Quote
Old 02-21-2013, 05:44 PM   #4
taylor192
My Ride: 2003.5 M3
Big thanks!
I asked my local independent and they said this wasn't a programmable option. I'll ask again, otherwise I may have to break down and have the deal do it... or buy another hardtop install kit is that's cheaper than the stealership.
Old 02-21-2013, 06:28 PM   #5
E46-Cabrio
Yes, if you retrofit a hardtop preparation kit then coding is also required.
The car must know if it has a hardtop. (It's not save to close the softtop while the hardtop is installed)
Name:	Hardtop Retrofit.jpg
Old 03-08-2013, 11:17 AM   #6
taylor192
My Ride: 2003.5 M3
The car didn't have $982, just $380, and removing it didn't help.
With the help of a local member we confirmed after removing $380 that the hardtop detection fault code is still being registered. So I'm just going to ask the dealer how much they will charge to reprogram it and see if that's cheaper than buying another hardtop install kit.
