Sponsored by BimmerWorld
Old 03-03-2013, 01:48 PM   #1
Dave1027
My Ride: '06 IR zhp coupe
How do you remove the caster locator pins?
Since replacing the entire front suspension, I need to take the car in for a good alignment. I want all aspects tweaked in as close a possible.
There is a pin on the strut mounts that needs to be removed so the shop can make slight camber adjustments. How is the pin removed? Do you use a punch and hammer? Would that bend the mount? How about drilling it out?
Old 03-03-2013, 01:51 PM   #2
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
I have seen this pin drilled out before. I would think you'd need a pretty heavy-duty punch to remove it.
Old 03-03-2013, 01:51 PM   #3
johntrhodes81
My Ride: 2004 325i Wagon
Just use a hack saw. Or if m3 they can be pushed out.
John
Sent from my PC36100 using Bimmer App
John
DIY BMW Performance Style Extra Air Intake
http://forum.e46fanatics.com/showthr...6523&highlight
johntrhodes81 is offline   Reply With Quote
Old 03-03-2013, 01:59 PM   #4
Dave1027
I was hoping to do it without removing the struts. I guess I'll drill them out.
Old 03-04-2013, 08:19 PM   #5
subieworx
My Ride: ZHP, 335, E53, E30
They unthread kind of. Grab them with pliers are twist. They will come right out.
And they are pins to limit adjustment of camber, not caster.
subieworx is offline   Reply With Quote
Old 03-07-2013, 01:19 PM   #6
mystert
My Ride: 2003 330Ci
I have aftermarket ones in my car, by lemforder I think. I just used a 6" ratchet extension as a punch and a big hammer. The thing popped out easily on the 2nd hit.
MysterT Huntington Beach, CA
mystert is offline   Reply With Quote
Old 03-07-2013, 02:00 PM   #7
EvilPeanut88
My Ride: 4Dr 325i --> ///m
Send a message via AIM to EvilPeanut88
Knock out with punch and hammer no need to remove strut. Would recommend jacking up and slightly loosen the three mount bolts.
When I die, I want to go peacefully like my Grandfather did, in his sleep...
not screaming, like the passengers in his car!!!
EvilPeanut88 is offline   Reply With Quote
