Sponsored by BimmerWorld
Old 02-22-2013, 01:36 AM   #1
325CiMaN
My Ride: 01 BMW 325ci 3.0L
Rear Differential bushing MOUNT broke...
I have no idea how this is possible.. Maybe too much power? Its a 325ci with 330 swap and Trans with headers intake, uuc tse3 , and AA tune. I'm going to fix it in the morning and gusset the mount so it won't ever happen again.. I'm just at a total loss on this one. Any one else have/seen this happen?
ID:	491852   Click image for larger version
ID:	491853   Click image for larger version
ID:	491854   Click image for larger version
325CiMaN is offline   Reply With Quote
Old 02-22-2013, 01:42 AM   #2
My Ride: Lexus
That diff doesn't look normal. what kind of diff/diff cover is that? and whats up with the control arms? seems like you have a lot of stiffening mods done. didn't something else unusual in your car break? tranny or something??
Old 02-22-2013, 01:50 AM   #3
325CiMaN
That's factory as far as I know, I never changed that and the control arms are from bav auto, eibach sells them under there name buy made by another company can't remember the name starts with a S, an is a 3 letter acronym. And ya the Trans broke but it was a getrag now I have a ZF. And ya it its way stiff but I would think my subframe mounting locations would crack first, but they are solid no cracks. I have a reinforcement kit I was waiting to put on when i do a M3 rear end swap but I guess I will do it now. Still don't know how that mount would break. Its kind of an awkward spot don't you think?
Old 02-22-2013, 01:52 AM   #4
My Ride: Lexus
indeed it is awkward. you sure everything is installed correctly? were you drop clutch launching when this happened?
you planning on welding it back?
Old 02-22-2013, 01:59 AM   #5
325CiMaN
Ya everything is installed correctly I checked and double checked. And no launch. At first I thought it was I needed new bushing cause they were ripped so I ordered thos, then I noticed the clunking got worse so I inspected again I saw that it was resting on my sway bar but it wasn't doing that before. So I don't know when it happened. Have you ever seen anything like this before?
Old 02-22-2013, 02:03 AM   #6
My Ride: Lexus
never. first time. maybe just a freak incident. theres people running superchargers. i wonder if the m3 subframe is beefed up for the extra power? yours should have never cracked in the first place but your car seems to like to break stuff
Old 02-22-2013, 02:12 AM   #7
325CiMaN
Ya it does like to break stuff...allot lol. And I was wondering the same thing. Oh and ya I do plan on welding it back after I drop the subframe and remove diff, I'm going to push it back clamp it grind to fresh metal and weld and then gusset the top and bottom of it so its connected to the top of the mount as well making it more ridged and less likely to flex and break again, I'll post picks of the fix and welding and the gussets I plan on making. I already have it drawn up... I figured out my new license plate... ANGUISH.... cause that's all my car causes me when it breaks... Which its to often... But hey at least this is the last thing that could go wrong...besides the diff grenading. but if that happens me and my car are going to have a nice long talk..
Old 02-22-2013, 02:16 AM   #8
MJLavelle
My Ride: 2001 BMW 330ci
When you swapped out the transmissions, did you have any trouble installing the driveshaft? Did you have to force it into place, or anything like that? Are the driveshafts all the same length, regardless of transmission? I honestly am not sure about that particular detail. It certainly looks like something was pressing the rear end towards the back of the car.
I really don't think it was from the added power from a M54B30 swap, even with an AA tune.
This is a strange thing to break. But something was clearly under stress in there.
Old 02-22-2013, 02:21 AM   #9
325CiMaN
No issue at all during install. People said I might need a new one but I didn't it fit perfectly. I had to shorten the drive shaft a little by loosening the collar nut near the center bearing and pushing it in. But after that it fit perfectly. So I don't know where the stress came from
Old 02-22-2013, 03:39 AM   #10
325CiMaN
I think this failure belongs in the wall of shame and wall of things that should not break, break or something to that effect... I love my car I love my car I love my car....I love my...nope I pretty much want a divorce...
Old 02-22-2013, 04:17 AM   #11
Andy2108
My Ride: SpecE46 & E46 M3
Yeah man that's a pretty crazy break. I guess its a good thing that you have the know how to fix it. Might as well do that M3 rear end conversion right now. You're going to be in there anyway. I wouldn't drive it at all, especially if its resting on the rear sway bar. It turns out the mount for that sway bar isn't all that strong either. ask me how I know
^That's my M3.
De gustibus non est disputandum.
Old 02-22-2013, 04:27 AM   #12
325CiMaN
^That's my M3.
Oh sh/t! Ya its parked I'm going to fix it tomorrow... And ya I would but I need my car running I'm going to look for a M3 rear end aka whole assembly. But then I would have to get a custom made drive shaft if I don't do a 6 speed swap. So I think I can wait. but ya gnarly isn't it? I'm quite proud of my self for being the first person to break this... Then again also wondering why? what caused it? And why me? Lol
Old 02-22-2013, 04:31 AM   #13
Andy2108
Same story with me and that sway bar mount. I'm pretty sure it didn't happen at the track... it just started clucking one day while driving around normally on the street.
Old 02-22-2013, 04:43 AM   #14
Alex323Ci
My Ride: M3 & 323Ci (sold)
No I haven't seen that before. But can see that happening if it was fractured earlier in its life when someone replaced that rear diff bushing. if someone was hammering on the bushing to press in or off I can see it cracking in its lifetime.
Old 02-22-2013, 04:48 AM   #15
325CiMaN
Same here! I have bad bushings so it cluncked lightly and then just during driving it got really loud. So I looked underneath it's split in half
Maybe but I frequent the track regularly over the past 3 years so I'm pretty sure it would have broken then and not all of the sudden while driving home from a concert tonight. And as far as I can tell those are the originals I've personally never replaced then cause they weren't bad till now
Old 02-22-2013, 02:10 PM   #16
325CiMaN
Anyone else seen anything like this ?
Old 02-22-2013, 07:02 PM   #17
325CiMaN
Didn't have time to pull subframe out but I have time to inspect more and saw that the bottom of the mount was also cracking ...
Old 02-22-2013, 10:00 PM   #18
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
That is appalling...and I have not heard of it. Thanks for sharing
Chris
dreamdrivedrift is offline   Reply With Quote
Old 02-22-2013, 10:07 PM   #19
325CiMaN
Ya interesting right?
Old 02-23-2013, 05:18 PM   #20
325CiMaN
Oh mango I found who makes the rear lower control arms it's SPC
