Sponsored by BimmerWorld
Old 02-24-2013, 05:13 PM   #1
AndrewCross
My Ride: 2000 323Ci
E46 Subframe and Differential Bushing Part Numbers
Hi everyone, I plan on replacing the subframe and differential bushings on my 2000 323Ci, and I just wanted confirmation on the part numbers. The part numbers and quantities I found were:
33171093175 (2)
33311092517 (2)
33316757393 (1)
33316757394 (1)
Are these all the bushings I need for both the differential and the subframe? Also, on Tischer, when I look up the part numbers, it says the number was superceded and it directs me to a new part number. For instance, 33171093175 (old part #) becomes 33176770788 (new part #). Will these still fit? Also, from what I've heard, the parking brake cable goes through the subframe carrier. Do I have to remove the entire rear subframe assembly because of this, or is there a way to remove the subframe carrier without damaging the parking brake cables? Also, what grease should I use when putting the new bushings in? Sorry for all the questions, and thanks in advance everyone.
AndrewCross is offline   Reply With Quote
Old 02-24-2013, 05:21 PM   #2
Nerdy46
My Ride: 328i
looking forward to seeing this answer
Daily: 1999 328i (202k)- Sport and winter package, 5speed, Jet Black, hellbeige, e60 Short throw, cross drilled rotors, koni, H&R, ASA AR1, Vibrant stealth, basslink
Track: 1995 Mustang GT (230k)- 306ci, 5 speed, MGW shifter, Trickflow Heads, Trickflow intake, street cam, shaved and tucked engine bay, slammed, 1 3/4'' long tubes, tuned with moates.
On the Water: 7' Boneyard Retro Quad Fish
Nerdy46 is offline   Reply With Quote
Old 02-25-2013, 10:21 AM   #3
AndrewCross
My Ride: 2000 323Ci
Bump
Old 02-25-2013, 10:56 AM   #4
My Ride: Lexus
33171093175 (2)
33311092517 (2)
33316757393 (1)
33316757394 (1)
That copy/paste looks like you got it from my thread. If the part #s have been superceded, then use the new part#s. Did you check realoem? RMeuropean?
As far as grease, no grease on any bushing ever
Old 02-25-2013, 12:34 PM   #5
HallisterJ1
My Ride: 2001 325i, 2003 M3
It's by far the hardest thing I've ever tried to DIY myself, luckily I had a BMW Master Tech on hand to help a lot.
Don't be afraid to bang the **** out of the rear diff bushing, if you can get it out under 2 hours then hats off to you.
As you can see, to get my old one out. We first incinerated the rubber, and that barely worked. So then we used a drill to drill the rubber out and get the metal out. Then once that was done, we turned the old bushing into a bullet (see pic) and the bushing came out easier then pie.
I hope this helps, and good luck! The difference you will feel is immense.
HallisterJ1 is offline   Reply With Quote
Old 02-25-2013, 01:18 PM   #6
ryannel2003
My Ride: '04 Cadillac Deville
The best way to tackle the rear diff bushing is by using the tool or making one of your own. I am renting one at the moment and should be tackling this job on Wednesday or Sunday depending on the weather.
ryannel2003 is offline   Reply With Quote
Old 02-25-2013, 04:31 PM   #7
Nerdy46
My Ride: 328i
Are you serious??? Every poly bushing i have ever installed i have greased....
Old 02-25-2013, 05:56 PM   #8
My Ride: Lexus
I'm not talking about poly bushings. I'd never install them on my car. as far as I'm concerned, they don't exist!
Old 02-25-2013, 06:08 PM   #9
Nerdy46
My Ride: 328i
Old 02-25-2013, 06:11 PM   #10
My Ride: Lexus
OP listed OE part #s--those are the parts referenced in context. Stop being silly
Old 02-25-2013, 08:51 PM   #11
AndrewCross
My Ride: 2000 323Ci
Thanks for all the help guys. How can I get around the parking brake cables? Do I have to take out the entire rear subframe assembly or can i just remove the subframe carrier?
