Old 02-22-2013, 02:40 AM   #1
mkodama
mkodama's Avatar
Question What to build compression ratio to?
How do you determine what the static compression ratio should be when designing and building an engine?
Old 02-22-2013, 03:08 AM   #2
mkodama
mkodama's Avatar
My order of operations would be something like:
0. Decide budget.
1. Determine what RPM to make peak power.
2. Find or have a camshaft made that will make peak power at that RPM.
3. Determine what type of fuel will be used find an appropriate dynamic compression ratio to run with that fuel.
4. Use camshaft specs and desired dynamic compression ratio to get the correction static compression ratio.
Thoughts?
Old 02-24-2013, 03:36 AM   #3
mkodama
mkodama's Avatar
Old 02-24-2013, 01:09 PM   #4
jared_wiesner
My Ride: 1999 328i (M54b30)
Sounds like a good way to plan an engine build.... You've got the main points covered
jared_wiesner is offline   Reply With Quote
