What parts for m20 flywheel/clutch conversion on m54? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-22-2013, 08:02 AM   #1
Jocke_from_Sweden
My Ride: 325 Touring -02
Hello!
What parts do I need for a m20 flywheel/clutch converison on a 325 Touring -02 (M54 engine)?
Is all bolt-on? Or do I need to modify anything?
Im so tired of my stock dualmass flywheel and thinks this is the cheapest solution for a dailydriven car
Kind regards from Sweden!
//Jocke
Jocke_from_Sweden is offline   Reply With Quote
Old 02-23-2013, 10:28 AM   #2
lcoleman
My Ride: '79 Massey Ferguson
Why not the Valeo single-mass flywheel conversion? I don't think the m20 parts are really desirable, or offer any great advantage. I'm also not sure the input shaft splines are the same.
Old 02-24-2013, 04:25 AM   #3
Jocke_from_Sweden
Cant get that in sweden. And order from the states gets so expensive with taxes and delivery costs :-/
Old 02-25-2013, 02:07 PM   #4
TerraPhantm
My Ride: M3 & ZHP
Don't think it'd be worth it. Based on what it takes to use an m20 flywheel on an m50, you'd need to run an m20 starter -- who knows if that'd fit on an m54. M20 starter is also pretty weak compared to more modern ones. Beyond that, the m20 clutch has nowhere near the capacity of an m54 clutch.
I can't find much info on it, but an e28 flywheel might work
Old 02-27-2013, 08:22 PM   #5
Eurofreak13
My Ride: 325xiT, 318is, 318ic
An e28 flywheel might work huh? Would that be a single mass 83 528e flywheel that works with an m54 & it's starter?
Eurofreak13 is offline   Reply With Quote
Old 02-27-2013, 09:22 PM   #6
Iceman00
Banned User
My Ride: E90 6MT
Go home E30, you're drunk.
Old 02-27-2013, 09:23 PM   #7
Iceman00
Banned User
My Ride: E90 6MT
Oh...you have an E46. Well nevermind.
Old 02-27-2013, 10:00 PM   #8
Eurofreak13
Spoken like a true r3vlimited member! Haha care to explain why that flywheel wouldn't work in an e46?
Old 02-28-2013, 09:38 AM   #9
GGray
My Ride: 00 330it Wagonator
Works fine...
You need the following
E30 or e28 flywheel, machine the weighted ring off back on E30, E28 528's have the ring off, so do E30M3's, they all use the same basic flywheel.
E30M3 clutch kit
E30 euro 323 throw out bearing
E30 starter
Bolt in for a LTW steel single mass flywheel...
V 2.0
E28 535i flywheel (240mm)
E34 M5 clutch disk, pressure plate T/O bearing
E36 ring gear to press on flywheel
stock starter.
Gary
Need parts, or a race shop?
email us - info@simod.net
Follow us on facebook
If you can take it apart you can make it faster
GGray is offline   Reply With Quote
