Old 02-22-2013, 05:15 PM   #1
Bino5150
My Ride: 99 323i
Question Anybody running single 2.5" exhaust?
From my experience with engines in this size and power range (Mazda KLZE; Nissan VG30), it just seems to me that 3" is a bit too big, and while it may net some peak hp way up top for the dyno queens, you will suffer mid to low torque. Usually on these size engines (2.5L, 6 cyl, 165-225 hp range) a single 2.5" is optimal, and we have actually suffered with too large of an exhaust. I know all engines are different, and I see a lot of people running these single 3" "race" exhausts, but I was curious to hear if anyone is running single 2.5"? Hell, I even see dual 2.5" exhausts, which should technically be way too big; that's what I ran on my twin turbo 300zx and my small block Chevy's.
I did the math on it, and a single 2.5" pipe will outflow (CFM) dual 1.75" pipes (stock, right?), and support ~275hp or so, plenty for my 323i, and I shouldn't lose my low-midrange torque.
Bino5150 is offline   Reply With Quote
Old 02-23-2013, 10:39 AM   #2
lcoleman
My Ride: '79 Massey Ferguson
I am on the e30...I think with good extractors/headers, you'll be fine.
Old 02-24-2013, 02:15 AM   #3
HakenTT
My Ride: 323i with S54
Your 1999 323i already has 2.5 inch single exhaust
Siemens MS43 tuning master
HakenTT is offline   Reply With Quote
Old 02-24-2013, 04:28 PM   #4
Bino5150
My Ride: 99 323i
Ah really, I guess I should go check... I just got the car and haven't crawled under it, but I thought all the E46's had the dual exhaust with a single muffler? If I do have the 2.5" single, then cool, I'll just change the muffler and resonator.
Old 02-24-2013, 04:36 PM   #5
325CiMaN
My Ride: 01 BMW 325ci 3.0L
I ran it on my 325Ci for a while and it was a big difference over stock, well according to butt dyno at least. I am now running headers with the full uuc tse3 exhaust, with a catco dual in dual out in place of the first set of resonators and boy it sounds mean as hell. But is also a 330 swap now so it's a little deeper tone
325CiMaN is offline   Reply With Quote
