Wheels and Tires
Old 02-25-2013, 06:43 PM   #1
gorgerax
My Ride: 2004 M3
FS: Complete Wurth German Wheel Restoration Kit $40 obo
Part # GWK-100. Brand new kit. Never opened or used. From their website:
The German Wheel Restoration Kit is a four-part refinishing kit for bare metal wheels. Start with bare metal and create a durable wheel finish that replicates the silver color used by major European auto makers, like Mercedes, BMW, Audi, Porsche, and Volkswagen. No one will ever know the difference!
The German Wheel Restoration Kit is comprised of products by two German companies, 1Z Einszett and Wurth. Both companies are specialists in the area of European car care. That's why you can trust the authentic look of the wheel finish created by the German Wheel Restoration Kit.
Note: This kit is intended to refinish bare metal wheels. Do not use the primer included in this kit on coated wheels. If you wish to touch up scuffed wheels, use the kit without the primer, or see our German Wheel Scuff Repair Kit.
The German Wheel Restoration Kit includes:
17 oz. Wurth Clean-Solve
Wurth Clean-Solve is a fast acting cleaner and solvent that will not leave a film residue of any kind. This cleaner will quickly remove wax, tar, gum, grease, paint overspray, adhesive, oil, and silicone. Clean-Solve removes anything that might interfere with the bonding of the primer or paint to the wheel.
12 oz. Wurth Self Etch Primer
Wurth Self Etch Primer prepares automotive surfaces for a fresh coat of paint. This fast drying formula has excellent sanding properties and strong adhesion to all metals and other surfaces. Wurth Self Etch Primer also fills in small scratches and blemishes on the surface being refinished.
13.5 oz. 1Z Einszett Silber Spray Wheel Paint
1Z Einszett Silber Spray Wheel Paint is an acrylic lacquer resin paint that contains high-quality paint components tested to provide outstanding coverage and durable protection against corrosion, rock chips and road salt. The silver paint color matches original European car and motorcycle standard wheels by manufacturers such as Audi, BMW, Mercedes, Porsche, SEAT and VW. 1Z Einszett Silver Spray Wheel Paint also restores silver body components and automotive trim. Spray multiple thin coats of paint for the best coverage.
13.5 oz. Wurth High Gloss Clear Lacquer
Wurth High Gloss Clear Lacquer is formulated to match the original factory luster of your wheels. It is permanent lacquer paint, not a dressing. After you have repainted your wheels and allowed them to completely dry, spray Wurth High Gloss Clear Lacquer in light, sweeping strokes over the entire wheel face. Apply two or three coats for the best protection of your silver paint and the most attractive shine.
2 Wolfgang Finger Pockets
Wolfgang Finger Pockets are the easiest way to clean or polish tight places. These foam pockets fit over three or four fingers so you can maneuver in small spots. The foam has light cutting power so its perfect for polishing metal components. Finger Pockets allow you to reach between the slats in your vehicle's grill or between spokes. The foam is more absorbent than a towel so it's great for product application.
16 x 16 inch All Purpose Microfiber Towel (color may vary)
This microfiber towel is designed to perform all your cleaning, polishing and buffing jobs. This towel has a double-sided structure: one side has tight loops for cleaning and polishing, the other side is feathery soft for buffing.
Before refinishing wheels, ideally you should remove them from the vehicle. This is the safest way to avoid overspray. If you leave them on the vehicle, tape off tires and body panels. Remember, these are paints.
Next, clean each wheel with Wurth Clean-Solve. Use the Wolfgang Finger Pockets to clean between spokes. Wipe dry with the included Cobra Mango Breeze Microfiber Towel.
Prime the clean wheel with Wurth Self Etch Primer. Allow it to dry completely before applying paint.
Now apply multiple, thin coats of Einszett Silver Wheel Spray Paint. Allow about a half hour between coats. If you apply paint too heavily, it will run.
After the paint is sufficiently dry, apply two or three coats of Wurth High Gloss Clear Lacquer. Again, use multiple, even coats.
The German Wheel Restoration Kit will completely refinish two wheels.
Refinish your wheels with the same silver color used by major European auto makers. The German Wheel Restoration Kit is a complete refinishing kit for bare metal wheels.
Kit includes:
13.5 oz. 1Z Einszett Silver Wheel Spray Paint
16 x 16 inch Cobra Mango Breeze Microfiber Towel (color may vary)
A total retail value of $85.93.
gorgerax is offline   Reply With Quote
