E46 Xi Forum
Old 02-21-2014, 07:28 PM   #1
Diok
My Ride: 330XI
Gear symbol with exclamation dot after replace oil and filter
Why i got a Gear symbol with exclamation dot after replace oil and filter? I pt th original oil take at BMW garage!
Diok is offline   Reply With Quote
Old 02-21-2014, 07:30 PM   #2
Diok
My Ride: 330XI
On my 330xi 2003
Old 02-21-2014, 08:27 PM   #3
sbiggi
My Ride: 325Xi
That is for the transmission. You sure you drained the engine and not the transmission?
-Seth
2002 325Xi
2003 F250 Super Duty
2013 Volt
sbiggi is offline   Reply With Quote
Old 02-21-2014, 11:11 PM   #4
Diok
My Ride: 330XI
Yes... I'ts for the transmission !
I drain the oil, replace the transmission filter and the gasket!
Old 02-22-2014, 12:40 AM   #5
Justinz
My Ride: N54
Check your MAF sensor.
Leaving it unplugged causes this light as well.
Justinz is offline   Reply With Quote
Old 02-22-2014, 12:41 AM   #6
Justinz
My Ride: N54
Old 02-22-2014, 03:46 PM   #7
tomoyer
My Ride: 03 325xi, 01 325xi
Send a message via Yahoo to tomoyer
Did you completely refill the transmission with the CORRECT ATF? once filled, did you have the car completely off the ground, start it and shift thru all the gears and then turned the car off and re-checked the transmission fluid level and it low, topped it off? That light is telling you that something is wrong and the transmission is stuck in emergency mode; 3rd and 4th gear only for "limping" home or to nearest service center.
Not sure why you would discount the MAF (Mass Air Sensor) to change the transmission fluid?
tomoyer is offline   Reply With Quote
