///M3 Forum
Old 02-27-2013, 11:24 AM   #21
das9125
My Ride: 2006 M3 JB Vert
Unhappy
46smg, what were your symptoms?
Ok guys, update:
We have checked all of the following and everything is working as it should.
- Ignition switch
- Starter
- EWS
- Battery
- Key
- Battery cables
- Hydraulic fluid level
Does anyone think that my symptoms are SMG related? Could it be the actuator or the pump itself? Remember, that once the car does turn on the car works perfectly, no missed gears or noise, delay, etc.
I really don't want to order thousands$ in SMG parts and have the problem remain. But I am practically out of options.
Black/Black 2006 M3 Manual
das9125 is offline   Reply With Quote
Old 02-27-2013, 09:02 PM   #22
46smg
My Ride: 2003 M3
Honestly, I didn't have any symptoms. My car drove normal, didn't miss any gears, I could hear the pump working when I unlocked the doors, I replaced the salmon relay once. But, the smg light was appearing often. I didn't want to risk it, so I gave in and took it to the dealership. I gave them $3000 and they gave me a new pump. Yes...Ouch! But the light has not come on since, and my car has been running fine. I hope it's not your pump. Sorry I couldn't help more. Good Luck
46smg is offline   Reply With Quote
Old 02-27-2013, 09:15 PM   #23
lsbmatt
My Ride: 2002 vert m3 lsb smg
Ok guys, update:
- Ignition switch
- Starter
- EWS
- Battery
- Key
- Battery cables
Once your car starts acting up again - Probably a long shot, but once you start your car, of course its in 0/neutral, OK now toggle the DSC button, let it go on, wait 30 seconds then press the button again. Try shifting when its on then off, both ways after toggling it.
Have you unhooked your power to your battery for 30 minutes then plug it back in?
lsbmatt is offline   Reply With Quote
Old 02-27-2013, 10:02 PM   #24
Ballerbrian4u
My Ride: 2004 BMW m3
Originally Posted by M3driv3r View Post
Smg pump? They overheat and that's why they fail, it's hit and miss, I have a 140k mile car with the original pump, track and daily, I've also seen low mile cars go! Maybe you got a bad pump, they have a recall check your local dealer to see if any chance of coverage good luck! Lots of ???? But I still love my smg!!
There's a recall for our cars?
Ballerbrian4u is offline   Reply With Quote
Old 02-28-2013, 12:02 PM   #25
das9125
Will try this Matt. Let you know.
My love for the M3 is seriously struck
Old 02-28-2013, 12:48 PM   #26
das9125
Unhappy
Guys
We are still at it, cannot find the fault. We are now using the electrical diagrams on the bentley manual to identify the signals and possibly try to identify the problem.
Last night the car really did not want to start for a while. We could start it from a direct cable to the starter but that's it.
Below are some of the screens from the computer connected to the car.
Software is in spanish, so I can translate anything you do not understand.
We ran a purge of air for the hydraulic system, like a 30 min process that finished correctly. No luck
Also attached is a video of what the car does when I try to turn it on.
Very specifically, when the car does not want to turn on, if I send the shifter into gear, it will sound like it is engaging gear, but the dash will still show N.
In this video I open the switch and try to crank. No go. Then move the shifter into 1st and that's when N blinks, will not show 1 on the dash. Back to N. Close the switch, try again. All the time, the dash shows N.
And some pics of my car. Only 28k miles.
http://www.flickr.com/photos/9231767...7632542261046/
Old 03-11-2013, 09:25 PM   #27
Mike@speedkraft
My Ride: e46 M3 Convertible
das9125,
Were you able to find the problem? I am having the exact same problem with my wife's 2005 M3.
Mike
Mike@speedkraft is offline   Reply With Quote
Old 03-14-2013, 02:30 AM   #28
mango79
My Ride: E46
Hello das , did you find the problem please share the solution bc I have similar problem too
mango79 is offline   Reply With Quote
Old 03-14-2013, 08:06 AM   #29
$ilent ///M
My Ride: 03.5 M3 smg lsb
Have you tried looking in to the clutch actuator or the gear position sensor
$ilent ///M is offline   Reply With Quote
Old 03-14-2013, 01:13 PM   #30
Mike@speedkraft
I have not looked into either of those. Will these sensors fail when hot? I think the problem is something heat related. I can start and shut off the car and restart it over and over as long as it's not warmed up yet. If I go for a short trip and the car is able to warm up I cannot restart it after shutting it off. Once the car sits for 40 min to an hour it will start. Sometimes the SMG light will come on after it starts. Once the car sits for several hours or overnight the SMG light will go out.
Mike
Old 03-14-2013, 04:37 PM   #31
kiwami
My Ride: 04 ///M3 SMG
You can see the SMG gear light is on. So there most be something wrong on the transmission side. Bad pump, bad accumulator, low pressure, bad gear actuator bad gear position sensor or broken electrical wire! Can you shift it into 1st gear and get a solid 1 ?
kiwami is offline   Reply With Quote
Old 03-14-2013, 05:06 PM   #32
Mike@speedkraft
When the car actually does start after about 45 min and the SMG light is on everything works perfectly fine. I can shift into all the gears without any issues. If the car sits for several hours or overnight the SMG light goes out and everything works great until you shut the car off for a few minutes and try to to restart it. When the car won't start I cannot get a solid 1 if I put it in gear, it remains in N.
Sure seems to me that something gets hot and fails not allowing me to start it. Once it cools off everything is fine.
Mike
Old 03-14-2013, 08:54 PM   #33
kiwami
Mike
After turning it off & trying to restart it do you hear the pump turn on?
And when the SMG gear light is on. Which error code do you get?
Old 03-14-2013, 11:50 PM   #34
$ilent ///M
Have you tried the temp sensor resistor fix yet
Old 03-15-2013, 07:25 AM   #35
Mike@speedkraft
Yes, the pump turns on.
I just ordered a scan tool so I can read the codes.
Old 02-06-2017, 02:05 PM   #36
Vilius
My Ride: 528i 97'/325i 03'
Hello, guys, I recently have bought 325i 2003y with SSG (or SMGI) gearbox. Sadly, it has problem: sometimes gearbox works as normal and sometimes it feels like clutch is slipping- try to drive, but the engine revs is jumping between 2000 and 4000 and the car is barely moving (if you "torture" the car, you can smell the clutch at this situation), as well in this situation slipping is feeling in all gears. At this point you turn off/turn (remove the key) on engine and for a while gearbox is working quite fine. These symptoms mostly appears while driving in a city with more stop/go intervals, at long journey gearbox works quite fine. Which part of gearbox problem it could be? Last owner had told that clutch is changed not many times ago (there are all bills- clutch, labor, reset). Could it be SMG relay- but as I found in other topics, relay symptoms are different, in mine car the pump is working, engine starts every time, no COG lights (just several times there were DSC/ABS/Brake lights up, but after a while they gone), INPA don't show any error. If any of You have similar experience, please let me know how do You solve it. Cheers
Vilius is offline   Reply With Quote
Old 02-06-2017, 05:10 PM   #37
M3an M3
My Ride: 2004 OG e46 M3
EDIT: (because somehow it wasn't clear)- This post is in reference to OP and his issues.
Originally sounded like the EWS, but it's starting to sound like the Actuator is not holding pressure. Hook your car back up to DIS/GT1, test the SMG accumulator pressure. That is a quick way to find out if it is holding pressure or not. It will at least cross one more thing off your differential diagnosis. If you need a new accumulator ($500), you can buy one from ECS or Burkhart-Engineering. If it is the SMG electric motor and/or Temp sensor, (which is what tends to be the thing that goes out on "broken" pumps), Burkhart-Engineering sells a rebuild kit ($600).
EDIT: Sorry Vilius, I know nothing about the 325i or the SSG, so I can't help you there. It looks like maybe domibln might be able to assist you.
2004 E46 ///M3 - Oxford Green Metallic II + Cinnamon SMG
M3an M3 is offline   Reply With Quote
Old 02-08-2017, 10:32 AM   #38
domibln
My Ride: E46 325Ci SMG
Originally Posted by M3an M3 View Post
Originally sounded like the EWS, but it sounds like the Actuator is not holding pressure. Hook your car back up to DIS/GT1, test the SMG accumulator pressure. That is a quick way to findout if it is holding pressure or not. If you need a new accumulator ($500), you can buy one from ECS or Burkhart-Engineering. If it is the SMG electric motor and/or Temp sensor, (which is what tends to be the thing that goes out on "broken" pumps), Burkhart-Engineering sells a rebuild kit ($600).
Man, you're writing about a completely different system. Vilius mentioned the Non-M SMG (often referenced as SSG) which has nothing in common with the M3 SMG II mentioned by you. All the faults and links you posted apply only to the SMG II.
However Vilius posted in the wrong forum and in the wrong topic.
domibln is offline   Reply With Quote
Old 02-08-2017, 10:36 AM   #39
domibln
@Vilius:
According to your description your pump and the relay are ok.
I often heard about this problem and never anybody mentioned a solution.
I would suggest you to check the clutch actuator (slave cylinder) if leaking as it is really the most common issue with the Non-M SMGs. Furthermore it could be a problem with solenoid valves.
Old 02-08-2017, 11:51 AM   #40
M3an M3
Except I was replying to the OP, about his M3 which has an SMG...You know, the guy that started the thread and all. Not all the other thread hijackers. I referenced GT1/DIS, because OP posted pictures of using that program to run diagnostics, but it is in Spanish, so I wasn't sure if he already ran the Accumulator Pressure Test. If he has solved his problem, than maybe I read-over that and just missed it. Up until reading your comment, I did not even see the post by Vilius. No where did I reference or quote Vilius's post. Maybe don't be so quick to assume, huh.
