E46 Xi Forum
Old 03-02-2013, 09:42 PM   #41
jmo69
My Ride: 03 325xi 98 328is
It sure feels great when you finally get an issue resolved. Would have been nice if you didn't have to spend $1000to do it.
HERSHIS
2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
Old 03-02-2013, 09:58 PM   #42
White_Knuckles
My Ride: 2003 325xi
Congratulations and welcome to "beat the man" club. That's right! Contestants research here and have an opportunity to cheat the dealer or shop. Avoid high service prices and get things done right the first time - by you.
Cheers
Old 03-02-2013, 10:11 PM   #43
tomjohnson
My Ride: 325xi
Yes, jmo, it certainly does feel great. The sun is shining and the flowers are in bloom. lol.
Actually, I've only got about $200.00 into the resolution of the CEL. Most of that cost was the OBDII reader that I had to buy to clear and read the codes. A very valuable tool at any rate. I've got over a grand in control arms, bushings and ball joints though.
Thank you White Knuckles! I'm glad to be part of that club and will give back to the community as often as I can. I really owe you guys a great deal of gratitude because the stealer wanted over $100.00 just to diagnose the issue and then who knows how much they would have charged me.
One thing I will say about this dealer here in Columbus, Ohio is that they were very nice and even directed me to talk to a service specialist who tried to decipher some of the codes and gave me some advice. Honestly though, the advice I get from this forum has been far superior.
I think I'm going to put this car up for sale and I'd like to get a 330Ci Coupe with a manual shift and sport package. That's what I'd really like to have if I am lucky enough to find one.
tomjohnson is offline   Reply With Quote
Old 03-04-2013, 08:54 PM   #44
basketthis
My Ride: state to state
Do you mind posting a picture of the part that was bad on yours? I'm going through a similar issue. I thought I had thoroughly checked all the vacuum lines, but now I'm second guessing myself and would love to know if I've looked over something or need to check another piece. It would be much appreciated!
basketthis is offline   Reply With Quote
Old 03-04-2013, 10:01 PM   #45
tomjohnson
My Ride: 325xi
Hi basketthis. Sure thing. I've uploaded a pic for you to look at. This was a tear or break that occurred on the bottom boot. I know you said that you thoroughly checked the intake boots but then again, so did I. It wasn't until I actually removed them from the car that I was actually able to see the tear in the small boot.
I have an aftermarket air filter and I think what happened in my case was that because the air filter wasn't firmly secured to the car, the vibration caused the tear in the boot.
Did you actually get the boots off the car yet?
Old 03-04-2013, 10:13 PM   #46
basketthis
Thanks for the quick reply and thanks for delivering!
I'm trying to figure out which boot that is exactly... I didn't completely remove my boot to make sure but felt around really good (I know, thorough lol). I did replace it approx a year ago. Is that the lower intake boot or another boot?
This is the one I replaced. As well as the top boot.
Old 03-04-2013, 10:19 PM   #47
tomjohnson
My Ride: 325xi
Sure Basket, I'm glad to help if I can.
OK, I know what you mean about feeling around the boots but even though you may not be up to removing them, you absolutely must do it. You're not going to be able to see a slight tear or feel it for that matter.
All you need to remove these boots is a 10mm and a 6mm socket. The entire thing from start to finish took me about 30 minutes. That was removing the old ones and replacing them with the new ones.
The boot that was bad on my car was the lower boot.
Take my word for it, if you're getting p0171 and p0174 codes, these boots will likely be the issue. Have you read the error codes yet? Can you post them? If you don't already have them, AutoZone will read and print them out for you for free.
EDIT:
I just went to realoem and saw the boot you were referring to. Go to http://www.turnermotorsport.com/BMW-...-silicone.aspx and the top two images are what you need.
Old 03-04-2013, 10:22 PM   #48
basketthis
240,2,39,3104,Misfire Cyl 3
243,2,39,3104,Misfire Cyl 6
238,1,37,3264,Misfire Cyl 1
239,1,37,3264,Misfire Cyl 2
228,4,40,2304,Mixture Deviation Bank 2
227,4,40,2304,Mixture Deviation Bank 1
90,0,0,0,Exhaust Temperature Pre Cat Conv - Bank 1
91,0,0,0,Exhaust Temperature Pre Cat Conv - Bank 2
93,0,0,0,Exhaust Temperature Post Cat Conv - Bank 2
The last scan (couple days before this scan) included the cyl 3 and cyl 6 codes along with the exhaust codes. The others are new (today).
Old 03-04-2013, 10:31 PM   #49
tomjohnson
My Ride: 325xi
OK, you've got a few in there that I didn't have. The misfires on my car went away after I changed out the boots. For that matter, all of the other codes disappeared as well. I'm not a mechanic or anything like that but it seemed to me that the bad boots on my car were causing other things to error out as well.
Can you remove the bottom boot and look at it? It'll only take you about 20 mins.
Old 03-04-2013, 10:41 PM   #50
tomjohnson
My Ride: 325xi
Basket, have a look at this video. At the 1:30 mark, you can see the guy removing the boots. Are these the same boots you changed out? How new are they?
Old 03-04-2013, 11:52 PM   #51
basketthis
Yep. Less than 2 years old... I'll pull them out and check just to be sure.
I will report back. I'm also guessing I might have a bad O2 sensor or something going on... But my symptoms are the same as yours. This is why I asked. Thanks again! Will report back (hopefully with some evidence/pics!! )
Old 03-05-2013, 12:10 AM   #52
White_Knuckles
My Ride: 2003 325xi
The thing about codes is they can cascade from a common source. Never assume anything like there may be a bad pre-cat sensor. A torn boot can run the car excessively lean sucking air. The resulting air/gas mixture is crazy creating misfiring as well emission sensor errors.
Correcting one problem often clears the series.
Old 03-05-2013, 12:10 AM   #53
tomjohnson
My Ride: 325xi
OK, thanks. I'm very curious myself. I think you'll be surprised. At least I hope you will be anyhow.
While you have the boots off the car, buy yourself a can of CRC air intake cleaner and clean the DISA and MAF really well. That's the time to do that. I'm happy to help if I can.
Also, SamDoe1 and WhiteKnuckles are the guys that really seem to have a lot of experience with this sort of thing. I'm basically just parroting them as they've really helped me immensely; as well as others of course.
Old 03-05-2013, 12:17 AM   #54
tomjohnson
My Ride: 325xi
I have to admit, when you told me this, White Knuckles, I was very skeptical but I have to reiterate what you are saying is absolutely right on the money. After I changed my intake boots, all of the other issues went away!
This is really good advice.
Now, I think I've found myself a new ride.
Can I get an opionin on this car? He's asking 4k with 200k miles on it. It's got the sport pkg and manual shift which is what I really want.
What would ya'll offer for this car?
http://columbus.craigslist.org/cto/3649019614.html
Old 03-05-2013, 12:18 AM   #55
basketthis
Yes. This seems to be the thing with BMW lol. I'm going to double check on those boots and report back. Hoping to get somewhere with this issue this time around.
I have recently cleaned my MAF. DISA is in perfect condition. Just bought a replacement gasket in hopes that it will help. Just need to get around to replacing it at this point. The spark plugs and ignition coils are new (within the past 2 years) as well. Hopefully that gives a little more insight into what I'm dealing with.
Old 03-05-2013, 12:20 AM   #56
basketthis
You can get a replacement engine for under 1k. Offer 2500 and see if they take it. Looks like you will have some cleaning to do in your future.
Old 03-05-2013, 12:24 AM   #57
tomjohnson
My Ride: 325xi
I think you're right Basket. I was thinking like $2800.00 but I like $2500.00 better! The only thing that worries me is that it may have rust on it. In Ohio, they use a lot of salt and it just eats these cars up. This is the main reason why I always borrow someone else's car when there is snow on the ground.
Old 03-05-2013, 12:26 AM   #58
basketthis
LOL. Do it! (also look at my post before the last one )
Old 03-05-2013, 12:29 AM   #59
tomjohnson
My Ride: 325xi
Thanks Basket, you've convinced me! (Actually, it wouldn't have taken a lot )
I'll post back tomorrow and let you know what I find out with that car. I imagine it probably has some pretty decent things wrong with it; namely the control arms. Sheesh! Here we go again!!
Oh yeah, that's true, the motors arn't bad as far as price goes. Thanks. Do you have a place to get them?
Old 03-05-2013, 01:18 AM   #60
White_Knuckles
My Ride: 2003 325xi
These cars can indeed be a problem in the 200K range like ANY high-mile car. If you don't want your yard to resemble Sanford and Son's think about your wish ride. Detail your XI, sell it and find a 100K, 330I with a manual and NO rust. That would be an $11000 car in my region but they show up in the $8-9K range sometimes. Used engines on the Left Coast run $2-3K and may include a scary history. Maybe things are different in the East but these parts fetch a premium.
Messing around swapping front end parts, engines etc. is dandy if you're a good wrench with lots-O-tools, time and a shop. These guys often win bringing back a car performing all the work. A basic owner needing shop services to do the needs often render themselves - upside down. The car is worth less than what's invested. You gotta really love the car for that one. Think hard and long Jedi.
