Old 02-24-2013, 04:51 PM   #1
slvrM
My Ride: 2003 M3
Stuck in second gear
Hello all
I have an 03 M with 85k miles and no prior issues. I decided to go for a drive today as I hadn't taken the car out in a while. When I decided to get on it and shifted from second to third at around 7k, something happened and the car would not go into third and the shifter only stayed in the neutral position. I quickly pulled over and found that I could not shift into any other gear, nor could I get it into neutral. The clutch still engaged and disengaged properly and I was able to get get the car home in second gear. It is a regular 6mt not SMG.
I'm not sure what the problem could be. My shifter is factory, and has a LOT of slop due to the worn bushings. I had just had my tranny fluid replaced by a reputable shop, but would that even have anything to do with it? Could it be my shifter linkage broke? Any help would be appreciated. Thanks!
slvrM is offline   Reply With Quote
Old 02-27-2013, 06:10 AM   #2
Weste46
My Ride: 2001 330ci
Could be that your slave/master cylinders lost pressure. Possibly an internal hydraulic leak there? Unless you can hear your TOB coming in and out, that would be my first thought.
Sent from my DROID RAZR MAXX
Rule of Thirds: Three Pedals, Three Liters, Three Series.
Weste46 is offline   Reply With Quote
Old 02-27-2013, 04:52 PM   #3
lszlszx
My Ride: 2000 328i
Unless the linkage is disconnected, unfortunately that sounds
like an internal transmission failure, like a broken shift fork.
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 03-07-2013, 11:35 PM   #4
bmwm3beast
My Ride: m3
Dont mean to steal OP but I'm having same issue i just bought a new tranny im thinking i jus t spended money i shouldn't have too... ;( but my question is if i take out my tranny can i replace the shift fork or is too much of a pain in the a$$?
bmwm3beast is offline   Reply With Quote
