E46 Xi Forum
Old 02-24-2013, 06:42 PM   #1
merkme19
My Ride: 2003 bmw 325xi
Idle problem
Hi guys I need help with something. Whenever I pull up to a stop sign or am coming off of the highway and push in the clutch, my car idles at around 500rpm then will continuously bounce up and down up to like 2000rpm. What could be causing this? Please help
merkme19 is offline   Reply With Quote
Old 02-24-2013, 07:16 PM   #2
White_Knuckles
My Ride: 2003 325xi
Your ICV or idle control valve may be sticking. Bouncing up to 2000 seems high for that issue. You may have a vacuum leak or something else playing into this.
Usually a good cleaning of the ICV removes goo and deposits and brings them back to life. Not too expensive should it have failed. Servicing it is slightly involved as several steps are needed just to get to it. Use the "Search" feature and read about others with your symptom and the procedure. You may search the General Forum and read several pages of owners talking about this. The 325I is the same engine, nothing unique with our XI's.
Old 02-24-2013, 07:23 PM   #3
merkme19
Okay and I don't know if I was exaggerating about 2000 it may have been lower I was just giving a general idea but I will look into that. I thought it would have something to do with the ICV so ill see what I come up with thank you.
Old 02-26-2013, 10:28 AM   #4
TR4G-
My Ride: '01 325xi, '90 325iC
Is it normal for our cars (manual xi) to dip down to 500 when you step on the clutch and don't press on the gas? Say at a stop light: you're playing with the clutch and gas moving the tiniest bit forward. Then you step on the clutch (without the gas pedal depressed) and the Rpms dip ever so slightly below normal idle and you feel the smallest of shudders. Is that normal?
Not trying to thread jack, just trying to keep the board clean and this is a similar title.
TR4G- is offline   Reply With Quote
Old 02-26-2013, 10:37 AM   #5
diM3tri
My Ride: 330ci + stg2 Scoobie
The same thing happens to me. It may have to do with the MAF sensor
Current Cars:
'99 Big Turbo B5 A4 (the red one) ^^^
'13 GLI
'91 Ford F150 v8 5spd
Previous Cars:
'05 stg 2 scoobie wagon
'82 VW rabbit vert
'01 330ci
'84 633csi
diM3tri is offline   Reply With Quote
Old 02-26-2013, 10:48 AM   #6
2002topasblueM3
My Ride: 2002 M3
It could be spark plugs. My m3 would do the same thing and when I changed my spark plugs it stopped
2002topasblueM3 is offline   Reply With Quote
Old 02-26-2013, 11:14 AM   #7
SamDoe1
My Ride: 4cyl of fury
Mine doesn't shudder but the idle does drop down. I think it's the car allowing you more control over your start. If you try it in the summer, the AC will actually disengage when you press the clutch in to start to help you get going and then reengage when you get going.
