Go Back   E46Fanatics > Tuning & Tech > Bavarian Soundwerks' Mobile Electronics Forum
Sponsored by Bavarian Soundwerks
Old 02-24-2013, 06:27 PM   #1
nukem22
My Ride: E46 TiAg Coupe
2000 Coupe System Done!
FINALLY! After 3 weeks I'm finally done. Well not quite because I have some tuning to do. But the install is done. Everything was original except I had 2 JL 8W3's and an old Kenwood KAC921 on them.
First things first. Get the GPS off of the windshield suction cup. I customized another GPS bracket to mount the GPS to the left of the gauges. Fits nicely between the cluster and pillar. It's hard-wired so the wire is totally hidden once it goes in beside the pillar.
nukem22 is offline   Reply With Quote
Old 02-24-2013, 06:37 PM   #2
nukem22
Now on the the head unit. I kept the Business CD because I didn't really want to change the factory look too much. I'm thinking a Dynavin is down the road, but not yet. So I added a Kenwood KOS A300 so I can just plug in a USB thumbdrive. Colors match the factory display perfectly. USB plug is next to DSC. Since Aux is rarely used, it's in the glovebox.
ID:	492280   Click image for larger version
Old 02-24-2013, 06:45 PM   #3
nukem22
On to the speakers. I started in the back. I used some Alpine Type S 6-1/2" two-ways. They are really not needed, but I always liked having a little rear fill. After removing the stock speakers, I gutted them to use the frame as mounts for the Alpines.
Name:	BMW e46 rear - 01.gif
ID:	492284   Click image for larger version
Name:	BMW e46 rear - 05.gif
ID:	492285   Click image for larger version
Name:	BMW e46 rear - 09.gif
ID:	492286   Click image for larger version
Name:	BMW e46 rear - 12.gif
Name:	BMW e46 rear - 14.gif
ID:	492288   Click image for larger version
Name:	BMW e46 rear - 17.gif
Old 02-24-2013, 07:02 PM   #4
nukem22
After reading what others on this forum have done, I figured I couldn't go wrong if I did what was suggested in this thread... How to properly install a speaker in the door... http://forum.e46fanatics.com/showthread.php?t=317339
It wasn't easy, but talk about mid-bass out the wah-zoo. I went with some Polk components. First I had to run the wire, cut the door around the window track and build the pod.
ID:	492290   Click image for larger version
ID:	492291   Click image for larger version
ID:	492292   Click image for larger version
ID:	492294   Click image for larger version
Old 02-24-2013, 07:09 PM   #5
nukem22
I made the tweeter mounts out of craft wood. Once my 6-1/2" pods dried, I sealed them with silicone and mounted the universal mounting rings to them. I mounted the pods to the door using rope caulk to fill all gaps.
ID:	492297   Click image for larger version
ID:	492298   Click image for larger version
ID:	492299   Click image for larger version
Old 02-24-2013, 07:26 PM   #6
nukem22
Next, I cut out the ski pass. This was a pain. Once I got the ski pass cut out, I built my subwoofer box with a removable shroud. The sub is a Image Dynamics IDMax 12 in a sealed 1.6 cu. ft. (internal volume) enclosure. I wanted the shroud removable just in case my sub failed and had to remove it from the box. The shroud is sealed to the box and ski pass so all of the subs output goes into the cabin.
ID:	492304   Click image for larger version
ID:	492305   Click image for larger version
ID:	492306   Click image for larger version
ID:	492308   Click image for larger version
Old 02-24-2013, 07:32 PM   #7
nukem22
Once everything fit, I added carpet to the box and shroud. The grill is made from some soft fabric like you put in the bottom of a tool box to keep the tools from sliding around. I couldn't see the outline of the frame until I took the picture. Normally you don't see it.
ID:	492310   Click image for larger version
ID:	492311   Click image for larger version
ID:	492312   Click image for larger version
Old 02-24-2013, 07:38 PM   #8
nukem22
With the hard stuff done, now it's time to get the easy work done. I bridged the Alpine MRP-F300 into 2 channels @ 150W per channel to power those Polk Components.
ID:	492314   Click image for larger version
ID:	492315   Click image for larger version
Old 02-24-2013, 07:50 PM   #9
nukem22
On the other side, I installed the Alpine MRP-M1000 and a Tsunami 1.2 farad cap for the IDMax.
Unfortunately, I only have one battery and the stock alternator. On the bright side, it leaves room for upgrades.
Finally, I finished my trim panels.
ID:	492318   Click image for larger version
Old 02-24-2013, 08:28 PM   #10
nukem22
There are a couple other things that I did that I didn't take pics of. One was install a Kicker DX125.2 to power my rear deck speakers. I figured for what I wanted 30w x 2 would be enough. I installed it behind the MRP-M1000 where the factory amp used to be. Second, I hard-wired my radar detector so no cords are visible, and mounted it above the visor without using the suction cup to the windshield.
Also, I have a Bmw-aux Auxiliary input adapter installed where the CD changer would normally be in the trunk. This allows me to select CD- on the Business CD, which then uses the Kenwood KOS-A300 output. Like I said before, 99% of the time I listen to music from a thumbdrive using the USB port although it is iPod compatible. Believe it or not, I don't own an iPod.
Old 02-25-2013, 12:25 AM   #11
jbaikw
My Ride: 2000 328i
very nicely done! i might look into doing this for myself instead of purchasing a dynavin or clone
jbaikw is offline   Reply With Quote
Old 02-25-2013, 08:47 AM   #12
nukem22
I do intend to get a Dynavin 99+ if it meets my needs. The Dynavin thread is 146 pages so I have some reading to do. My concerns for the Dynavin is two-fold. I read a while back that the display was a little hard to see on an angle during the day. And I'm unclear if Google maps can be loaded/updated.
Old 02-26-2013, 07:59 AM   #13
nukem22
With everything installed, I decided to power up without the sub first. All I can say is Wow! I've never had 6-1/2's sound like that. The midbass is incredible. It was well worth the time to mount them to the doors properly. The first high pass setting I used for the doors and rear deck was 100Hz, and powered up the sub, low pass set at 80Hz. The low end sounds really clean. I'll need do some more tweaking with the crossover points once I get the amps set. Currently, the amps are basically turned all the way down until I can get access to an o-scope. I have a portable one at work. Can't wait to get that IDMax broken in to see what it can do.
Old 02-26-2013, 09:00 AM   #14
hey808
My Ride: '01 325ci/'92 S13-sr
Looks great! How does the sub sound firing into the armrest? Do you drive with the armrest down?
Bob
'01 325ci
'01 330i
Too many E30's...
hey808 is offline   Reply With Quote
Old 02-26-2013, 10:28 AM   #15
nukem22
I usually keep the armrest down. I'll flip it up when I'm parked where someone walking by may get curious.
Old 04-25-2013, 11:22 AM   #16
Ivan22
My Ride: 2001 E46 Convertible
Originally Posted by nukem22 View Post
... Once my 6-1/2" pods dried, I sealed them with silicone and mounted the universal mounting rings to them. I mounted the pods to the door using rope caulk to fill all gaps.
Amazing work. I am in the process of doing this mod.
Would you please help out with a few ?? :
What type of silicone did you decide to use? (White coating)
Did you have to trim the door panel plastic behind the speaker grill?
Why did you use the black trim ring on top of MDF rings? Was it possible to mount speaker directly onto the top MDF ring?
How did you center the speaker to the door, and avoid having fitment issues when mounting the door panel back to the door?
I installed RF free air 10" in my girlffriend's E46 vert, and I have to say it is plenty. I can only imagine the bass you produce! Awesome.
Ivan22 is offline   Reply With Quote
Old 04-26-2013, 12:35 PM   #17
Grande D
My Ride: zhpppppp (o-m-g!)
That's a very pro job. Props to you.
Old 04-30-2013, 03:37 PM   #18
nukem22
Good luck. One suggestion.... be patient. Done correctly, it is well worth the effort.
I used the GE Silicon II. Got it from Lowes.
Yes. Since the midbass was a 6-1/2" I had to trim it down with a dremel to get it to fit. Otherwise the door panel wouldn't snap back on.
I used the trim because I felt it would give me a better mounting surface than screwing directly to the MDF. I guess I could have screwed directly to MDF, but I thought over the long haul the screws would pull out. If I had used wood (oak or birch), I would have screwed directly to it.
Now that was a pain in the ass on the first one. One, because I didn't trim initially trim the plastic behind the grill. Two, because I miscalculated and didn't take into account for the foam between the speaker and the door panel.
To get the speakers aligned in the right place, I did this: 1. With the door panel on, I outlined the door panel with electrical tape onto the door since it would easily come off the paint. 2. Removed the door panel, leaving the electrical tape on the door. 3. Took measurements from the outside of the door panel to the edge of the inside speaker trim. 4. Took those same measurements and went from the electrical tape on the door to my speaker pod. It worked for me.
Well, it's clean and tight but it doesn't have the output I'm looking for. I was going to buy another IDMax and go IB, but I've never sealed a trunk and don't want to waste my time "hoping" to get it right. So now I'm about to build a 4th order bandpass after a conversation with Image Dynamics. I've built 4th orders before, so I feel comfortable doing that. Don't get me wrong. The one 12" is plenty normally, but I'm comparing to my other vehicle with four RF 10's (ported) powered by a RF Power 1000.
'00 Titanium Silver 328Ci
Beyern ~ Eibach ~ Alpine ~ Polk ~ IDMax
