Sponsored by BAVSOUND
Old 07-10-2003, 02:30 PM   #1
mysimonj
My Ride: 2001 Bmw 325i
Alpine IVA D900 Noise Problem!
I recently installed Alpine IVA D900 on my 2001 325i. I now have a high pitched noise, sounds like dentist's drilling noise, whenever the system is on and i step on the gas. It's driving me crazy and i found out that it's 'cause the factory amp is not fully compatible w/ the Alpine headunit (2 channel vs. 4 channel?). Does anyone have suggestions to rectifiy this problem?? Thanks.
Name:	bmw after 018.jpg
mysimonj is offline   Reply With Quote
Old 07-10-2003, 02:36 PM   #2
Ron@Streeteffectz
What did you use to install the unit, a wire harness? And where did you mount the brain?
Ron@Streeteffectz is offline   Reply With Quote
Old 07-10-2003, 02:37 PM   #3
mysimonj
i had someone do it and i believe the it was a wire harness and mounted under the seat.
Old 07-10-2003, 02:40 PM   #4
Ron@Streeteffectz
You really shouldn't get noise from just changing the headunit. My suggestion would be to add a filter on the IGNITION wire going to the brain, unless the installer can reroute his wiring.
Old 07-10-2003, 02:43 PM   #5
mysimonj
hmm... suggestions i heard was to 1) unplug the factory amplifier and go w/ the headunit amp 2) run separate wires for speakers or 3) get an Alpine amp installed. I may have to try a filter then...Darn!!
Old 07-10-2003, 03:42 PM   #6
tas
My Ride: Y2K AA SC 323i
I don't have a problem with mine. I just had it installed.
tas is offline   Reply With Quote
Old 07-10-2003, 04:12 PM   #7
///M_TEEJ
My Ride: 05 MB E55, 03 BMW M3
Send a message via AIM to ///M_TEEJ Send a message via Yahoo to ///M_TEEJ
Thumbs Up
mines fine and it's a bad a$$ unit
///M_TEEJ is offline   Reply With Quote
Old 07-10-2003, 04:14 PM   #8
mysimonj
man, looks like my installer was a quack...
Old 07-10-2003, 05:26 PM   #9
StreetTrixE4six
E46Fanatic
My Ride: 08' 328i E92
all u should need is the filter. i have the same problem w/ my pioneer and i'm waiting to have the filter put in
08' BMW 328i coupe
07' Audi A4 2.0T Quattro S-Line
04' 325Ci
StreetTrixE4six is offline   Reply With Quote
Old 07-11-2003, 09:24 AM   #10
jason634
My Ride: 2002 m3
which installer, let us know so we can avoid!
thanks
jason634 is offline   Reply With Quote
