E46 Xi Forum
Old 02-25-2013, 09:57 AM   #1
beemteam
My Ride: 325xi
Tranfer case fluid?
Hello everyone this is my first ever post. I wanted to change my trans fluid and transfer case fluid and i had a question,......is the transfer case fluid the same fluid used in the transmission or is it a different fluid? Thanks ahead
Sent from my N860 using Bimmer App
beemteam is offline   Reply With Quote
Old 02-25-2013, 10:03 AM   #2
SamDoe1
My Ride: 4cyl of fury
Same if you have a manual, different if you have an automatic.
Use MTL in the transfer case.
Old 02-25-2013, 10:26 AM   #3
beemteam
My Ride: 325xi
Thanks samdoe1
Old 03-04-2013, 12:11 AM   #4
jmo69
My Ride: 03 325xi 98 328is
What's the favorite brand for the T-case, Redline MT90?
Hers His
2003 325xi StahlGrau metalic almost modless, just lots of new parts, wife's DD. 1998 328is lowered, X-brace, Sparco strut brace, HIDs, AEs, almost everything blacked out, my DD.
jmo69 is offline   Reply With Quote
Old 03-04-2013, 11:55 AM   #5
SamDoe1
Yes.
Old 03-04-2013, 12:48 PM   #6
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Our fluid of choice for the E46 transfer case is RedLine D4, also when changing the fluids in the case it's suggested to also replace the drain and fill plugs as well as the washers on them, I have a kit available HERE which makes it a one stop shop.
Old 03-04-2013, 07:27 PM   #7
GCoop
My Ride: '04 325xi
Gears deserve a gear oil so Redline MTL every change here. Even if it is a tad more viscous than the OE fill. I do it about every third oil change (30K) for cheap insurance.
Whatever you guys do CHANGE IT. I'd venture to say motor oil would be even be better than leaving the original fill in there a mile past 60k
GCoop is offline   Reply With Quote
Old 04-13-2013, 05:39 PM   #8
jmo69
Finally did this today, got 5 ounces of black $hit out and replaced it with some nice clean Pentosin MTF. Got to be better than before.
Hers His
Old 04-13-2013, 07:18 PM   #9
Kubica
My Ride: 2003 325xi
I use D4 in the TC and mix D4/MTL in the MT.
Old 04-14-2013, 12:15 PM   #10
jmo69
I've got some D4ATF, I might try a mixture the next time, maybe next oil change. I also have some Transyn that we use in the heavy duty Allison automatic transmissions in our redi-mix trucks. The transfer cases use a 50 weight synthetic oil that would probably work too.
Hers His
Old 04-14-2013, 09:32 PM   #11
SeattleLSB
My Ride: 2003 330XI, 2003 M3
is it really worth replacing the drain and fill plugs like ECS Says?
2003 LSB/BLK M3/SMG/Premium/Cold Weather/Nav
2003 AW/BLK 330XI/AT/Sport/Premium/Cold Weather
SeattleLSB is offline   Reply With Quote
Old 04-14-2013, 09:54 PM   #12
djbradle
My Ride: 2002 325 xit
Nope. Just get the new crush washer though. Use a pick to remove them from old plug if they're on there tight.
djbradle is offline   Reply With Quote
