Old 02-25-2013, 09:12 PM   #1
infbp22
My Ride: 2004 E46 SULEV
M56 transmission compatibility?
Hi guys, I have a question for you transmission gurus...
I blew out the front pump in my 2004 325i SULEV. We are looking for the cheapest route just to get it going again so it can be sold.
RealOEM shows two different part numbers for the 5HP-19 for an M54 e46 and the M56 e46. Do I have to use the transmission specifically for the M56 or will a regular 5HP-19 bolt up and operate correctly? The M56 part number is obviously harder to come by. Also, do you guys have a good reference for used transmissions in the So Cali region? Thanks for your time
Steve
infbp22 is offline   Reply With Quote
Old 02-25-2013, 10:57 PM   #2
TerraPhantm
My Ride: M3 & ZHP
I think any ZF transmission should work. Worst case you might have to reflash the tranny computer with m54 software.
Old 02-26-2013, 04:02 PM   #3
briangl92
My Ride: VQ37VHR
From what I've read, the M56 came with the same ZF transmission as the M54. The only difference is that they didn't get the GM transmission for whatever reason.
briangl92 is offline   Reply With Quote
Old 02-26-2013, 04:04 PM   #4
briangl92
My Ride: VQ37VHR
You might also want to check my SULEV thread (linked in my signature). Some parts of the transmission are covered under the 15/150k warranty.
Old 01-25-2016, 08:47 PM   #5
SiVaE46
My Ride: 2003 325i
Did anyone take a transmission from an M54 325i and put in the in M56 ? I see the same ZF & BMW part number for rebuilt transmissions from 2001-2003 (at least) model cars - at least compatible across the 325i family (not Xi). But ZF catalog is a bit confusing - they list the following models with the same transmission (but no 325i sedan is mentioned from 03/02 on ... hopefully that is just an omission). RealOEMParts.com lists the same A5S325z-TT part for the '01 and '03. (type TT I think is the key (or 1060 000 009 is the ZF code stamped on the green tag on the transmission itself). 330i, 323i etc. definitely has different part numbers.
BMW 325Ci E46 Convertible 2000 – BMW TT 24 00 1 423 930 -ZF 1060 000 009
BMW 325Ci E46 Coupe 2000 – BMW TT 24 00 1 423 930 - ZF 1060 000 009
BMW 325i E46 Sedan 2000 – – BMW 03/02 TT 24 00 1 423 930 - ZF 1060 000 009
BMW 325i E46 Touring 2001 – 03/01 – BMW TT 24 00 1 423 930 - ZF 1060 000 009
BMW 525i E39 Sedan (M52) 2001 – 03/01 – TT 24 00 1 423 930 1060 000 009
BMW 525i E39 Touring (M52) 2001 – 03/01 – TT 24 00 1 423 930 1060 000 009
SiVaE46 is offline   Reply With Quote
