Australia
Thread Tools Search this Thread Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
Old 05-10-2011, 06:23 AM   #1
rgj1985
My Ride: 2001 BMW 325i
Dynavin v5 Question - how to get BMW logo to appear on startup?
Just throwing it out there to some other Dynavin v5 owners, I recently installed the Dynavin v5 unit which is a great investment, best $640 I have spent and makes my 325i look way more upmarket. Thanks Jason
Only issue is, I don't know how to get the BMW logo to appear on startup? It currently displays the dynavin logo but I've been told you can set the BMW logo to appear instead.
I've gone thru all the setting menu's and instruction manual, and searched the net but can't seem to work it out. Can anyone help?
Cheers, RJ.
rgj1985 is offline   Reply With Quote
Old 05-10-2011, 06:34 AM   #2
aar0n_91
My Ride: 04 BMW325CI///MSport
would love this as well. closest thing i know of is with the nav that daroz uploaded for us a bmw logo is on the loading screen of the NAV only instead of the igo8 logo that comes with the dynavin
BMW 325 CI ///M-SPORT INDIVIDUAL
aar0n_91 is offline   Reply With Quote
Old 05-10-2011, 07:02 AM   #3
shannon1
shannon1's Avatar
My Ride: 2001, 318i
Have you checked out dynavin free forum? I'm pretty sure there was a thread over there all about this issue, I'm just not sure what version unit it was or if still worked for all units.
Shannon.
shannon1 is offline   Reply With Quote
Old 05-10-2011, 07:03 AM   #4
Scotty_89
My Ride: 2007 335i Coupe
There is an update for the unit, that must be installed along with the TV tuner update.
It only changes the start up screen - the rest of the UI is still as fugly as all hell. Not sure how it makes your BMW 'more upmarket'...
Scotty_89 is offline   Reply With Quote
Old 05-10-2011, 07:14 AM   #5
Darkoz
My Ride: E46 325Ci
There's a firmware update for the V5 Dynavin that also gives you the BMW logo at startup.
Download - http://dynavin.freeforums.org/download/file.php?id=218
Info -
About this firmware update:
Release date 20.10.2010.a.
BMW logo loading screen
English language
New features:
Controlling iPod from steering wheel buttons
Fixed problems:
RDS info is now displayed correctly
Important!
1. This update is only for V5 (sunplus chip) Dynavin devices for E46 and E39. This firmware is for the radio part of the unit.
2. Never turn the unit off or start the car while updating!
3. If you have a external Dynavin DVB-T box, then you need to update it first! Otherwise you will loose DTV controls. Scroll down for the new DVB-T box firmware if you need it, you will find it in post #5 in this thread.
4. This update is delivered in two parts (zh_mcu.bin and zh8202t.bin), you need to update with both files in the order explained below.
Updating...
How to update in 10 steps:
1. Unrar the "Dynavin V5 (sunplus) firmware BMW logo 201010.rar" on your PC. You should find 2 files (zh_mcu.bin and zh8202t.bin) and this How_to_update.txt
2. Connect a USB memory stick to your PC, delete everything from USB memory stick.
3. Put the zh_mcu.bin file in root of USB memory stick.
4. Turn off Dynavin and connect the USB memory stick to DVD-USB cable on your Dynavin.
5. Dynavin should turn on and update should start automatically, now just wait until the system turns off (should take about one minute).
6. Remove the USB memory stick and go back to your PC.
7. Delete the zh_mcu.bin file from USB memory stick and put zh8202t.bin on USB memory stick.
8. Dynavin should still be off, connect the USB memory stick to DVD-USB cable on your Dynavin again.
9. Dynavin should turn on and update should start automatically, now just wait until the screen turns off (Dynavin won't turn off completely this time, just the display will go black, this should take also about one minute).
10. Turn Dynavin off by holding the power button for a few seconds, then remove the USB memory stick and you are done.
This info and download was taken from this thread at Dynavin Free Forums, hope it helps.
http://dynavin.freeforums.org/dynavi...2010-t452.html
Darkoz is offline   Reply With Quote
Old 05-10-2011, 08:17 AM   #6
aar0n_91
worked just now. took 5 mins from reading this post to having the process completed
Old 05-10-2011, 08:24 AM   #7
Sherweeeny
My Ride: BMW Civic
Darkoz + Aaron = <3
Sherweeeny is offline   Reply With Quote
Old 05-10-2011, 09:08 AM   #8
Darkoz
My Ride: E46 325Ci
Nah, I heard he's got small t!ts
Old 05-10-2011, 09:25 AM   #9
Sherweeeny
My Ride: BMW Civic
Probs a good thing considering aarons gender
Old 05-10-2011, 07:24 PM   #10
aar0n_91
yeeeeeee not sure how thats an insult?? =)
Old 05-11-2011, 06:40 PM   #11
rgj1985
Like aar0n_91, I performed the update last night, only took 5mins! Quick and painless and I now have the BMW Logo on startup.
Cheers Darkoz for finding that firmware update and instructions, champion!
Old 11-08-2011, 09:58 AM   #12
hksupreme2003
My Ride: E90 320i
does it work on E90 V5? Thanks..the steering wheel control still working ? beacsue my one is Dynavin logo in startup.. how can i check my verison ? Thanks
hksupreme2003 is offline   Reply With Quote
Old 03-20-2013, 11:23 AM   #13
Junglas
My Ride: e46 330cd
Sorry to ressurect this from the grave...
The patch is for Dynavin V5. Any chance to have this on the later D99+ ?
Junglas is offline   Reply With Quote
Old 03-20-2013, 08:19 PM   #14
fgin
My Ride: e46 facelift
You want the BMW logo on your D99?
select AUX-IN as the source and press '9' on your remote control
OR
go to settings > system and tap the top right corner of the screen
either way you get to the menu where you can change your logo.
Hope this helps.
fgin is offline   Reply With Quote
Old 03-21-2013, 08:05 AM   #15
Junglas
My Ride: e46 330cd
OR
Hope this helps.
Thanks fgin!
I'll try this later when I get home and post feedback!
Old 03-21-2013, 04:11 PM   #16
Junglas
My Ride: e46 330cd
OR
Hope this helps.
Worked perfectly!
Many thanks!
Old 03-21-2013, 07:45 PM   #17
fgin
Worked perfectly!
Many thanks!
glad to hear
