///M3 Forum
Old 02-27-2013, 10:28 AM   #1
Chaz.T
My Ride: '03 SC'd M3
3.4l Stroker Motor
Sooo, I have an 03 M with an Active stage 1 supercharger kit. Has been ridiculous fun. Recently it started idling weird and blowing oil from the vent hose on the valve cover. Took it to the local performance shop and found out I have damage in cylinders 1 and 5 and will need a motor. The shop quoted me for a built 3.4l stroker setup and I was wondering if anyone had any experience with this sort of animal? From what I was reading I could expect much more torque. The shop said this thing should stand up fine to the 9-10 psi of boost I'm running. Any complaints, comments, warnings? I drive the hell out of this car and will probably put somewhere around 15-20k miles on it a year if I keep it. Just want to make sure I don't go drop some major coin on this and have the blower destroy everything again.
Chaz.T is offline   Reply With Quote
Old 02-27-2013, 11:54 AM   #2
DSilk56
My Ride: M-3 Convertible
The only concern that I would have about a stroker engine for the M3 would be piston velocities at redline. Longer stroke equals higher piston speeds at any given rpm. Higher peak velocity equals greater wear and greater stress on connecting rods. You already have forced induction, and this will add additional stresses. If the builder is both experienced and reputable you should be okay, but I would consider everything carefully.
DSilk56 is offline   Reply With Quote
Old 02-27-2013, 12:32 PM   #3
M3RAUDER
My Ride: 2003 M3 SMG Coupe
If you decide to go back to N/a lmk about your AA kit. I'm also in VA.
M3RAUDER is offline   Reply With Quote
Old 02-27-2013, 03:19 PM   #4
illestminimike
My Ride: Project Drama
There was a thread on m3forum about a guy who did it but I think he stayed NA. Ask on there. What shop is going to do it?
Old 02-27-2013, 08:44 PM   #5
Chaz.T
Thanks for the info. RRT in Dulles, Va has the car now. Not sure if I'm gonna have them do the work though. I've asked around and seems like they are a bit over priced.
Old 02-27-2013, 08:59 PM   #6
Snik
Snik's Avatar
My Ride: IR M3 Vert.
If it ain't a VAC build I would t do it. They've been stroking S54s long enough to know how to do it right.
This engine already has crank bearing and connecting rod pots goal "issues" already, can't imagine stroking AND boosting it will make these things any better. So the build MUST be done right.
Do you ride a sportbike?
Old 02-28-2013, 01:22 PM   #7
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
if not redone with some AA's help how about http://forum.e46fanatics.com/showthr...e+motor+repair(maybe enquire about)
I could see this happen to alot of us boosted owners, I hope you get it back on the road, stronger and better.
"Player-haters turning bitch like they have vaginas ‘Cause we see them dollar signs and let the cash blind us.
Money'll brainwash you and leave your ass mindless..When snakes slither in the grass spineless.."
MachRc is offline   Reply With Quote
