Old 02-27-2013, 02:07 PM   #1
jsaklas
My Ride: Chrysler PT Cruiser
Car hasn't run in 15 months Need advise to start it.
I've had a 323i in the garage for 15 months, during which time I have not started it. I rebuilt the front brakes and most all of the front suspension and power steering systems plus some other work and I now I want to see if I can start it.
I'm a novice (retired and the E46 is a retirement project) so please don't get too technical or ask me to take apart the engine, etc.
What advice do any of you have? Change spark plugs, put some oil in the cylinders (via the spark plug hole) etc.
js
jsaklas is offline   Reply With Quote
Old 02-27-2013, 02:08 PM   #2
My Ride: Lexus
i would fill the oil filter housing with oil, let it sit a few minutes, put some fresh gas and start it up!
Old 02-27-2013, 02:28 PM   #3
Adionik
My Ride: Bavarian Panzer
You may need some starter fluid and the battery is likely toast. Also examine the tires from sitting that long as i'm sure they have flat spots.
Adionik is offline   Reply With Quote
Old 02-27-2013, 02:38 PM   #4
lcoleman
My Ride: '79 Massey Ferguson
Might be worth disabling fuel (relay, pump fuse, etc) and cranking the engine over a few times to build pressure. The oil in the plug holes isn't a bad idea, but probably isn't necessary.Really, you should be fine with fresh gas.
Old 02-27-2013, 11:07 PM   #5
jsaklas
Thanks for all the advice.
I bought, but haven't yet installed, a new battery, changed the oil and filter and after bleeding the brakes, I will take care of all your suggestions. Do you all have any hints on how best (and easiest way) to drain the tank? Since the battery is not hooked up the gas gauge can't tell me how much is in the tank.
js
Old 02-27-2013, 11:22 PM   #6
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
There's a drain plug on (I think) the passengers side. Just remove that and it'll all come pouring out. Be ready with a few big oil pans to catch it. You might be able to gauge how much isin there by tapping it. Orby removing the fuel pump under the rear seat and sticking a ruler or something in there. Don't drop it though!
Old 02-27-2013, 11:30 PM   #7
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
No don't make a mess by taking out the plug . Take the fuel pump out from the tank and pump it out with a simple fluid pump available at Harbor Freight or auto parts store. Your fuel pump is on the right side under the rear seat. Use a long screwdriver and a hammer to loosen the ring.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is online now   Reply With Quote
Old 02-27-2013, 11:33 PM   #8
dslboomer
My Ride: 2001 BMW 330I
js
I will not drain the gas tank before giving a try.
All late model cars have well sealed fuel system due to EPA mandate not like old 70s and 80s cars' fuel system.
Pull the all plug out - you may need new ones if they are old or may need to clean up.
Rent a compression gauge from an auto part store and do a compression check for all cylinders. Make sure to pull out the fuel pump relay fuse. It is #3 in the DME fuse carrier. See this guide.
http://www.chitownm.com/forums/showthread.php?t=4284
If they are below 120 psi, pour oil through spark plug holes and wet cylinder wall. You can read last portion of this thread for how much oil to use and how to proceed after adding oil.
http://forum.e46fanatics.com/showthread.php?t=969084
After that, put them all back together and give a try.
Good luck!
dslboomer is offline   Reply With Quote
Old 02-28-2013, 12:27 AM   #9
My Ride: Lexus
I think you're overthinking it OP. it'll start just fine and minimal wear will occur if you have good oil in there like Castrol 0W-30.
Maybe disable the ignition system (unplug all the coils) or unplug the fuel pump fuse and let the engine crank a few times to get the parts wet with oil. that's as far as i'd go. no ceremony needed. just dmax it and annoint your head with brake dust in the shape of a roundel and possibly a dab of ol' blue.
Old 02-28-2013, 10:47 AM   #10
sunsetcoast
My Ride: '99 323i & '00 323iT
Filling the oil filter is a good place to start.
Disabling the fuel relay is another excellent idea. Then remove the plugs, Squirt about 2 tbs of oil in each cylinder. Cover the holes. Crank about 20 secs, 5 secs at a time. This lubricates the dry walls without a gas wash. Replace plugs (new, if needed, since you are already there). Replace relay. Turn the key. Don't be concerned about all the smoke coming out of the tailpipe.
Agreed. If you used Stabil, 15 months is a little long, but should be OK. I've stored a car longer than that (unintentionally: job got in the way of my summer toy) and had no fuel-related problems.
You can always drain the tank, if necessary, but why go through the effort for what is unlikely to be a problem. Just drive gently on the first tank, and use Top Tier high detergent gas for the first few tanks.
Depending on what was done (and how long ago) before it was put away, I'd closely inspect rubber parts, at least belts and hoses. Doubly so if you live where ozone is a problem.
Tires may seem a bit flat-spotted, and may have become more than a bit low. With proper inflation and gentle driving, modern tires will be fine within 5~10 miles.
I also typically lubricate everything that I can find before I drive after winter storage.
sunsetcoast is offline   Reply With Quote
Old 03-03-2013, 12:07 PM   #11
jsaklas
Thanks to all responders.
Before carrying out your suggestions, I thought I would try to find the fuel filter opening on top of the tank - I was thinking that changing the filter sounded like a good idea.
I removed the seat but I don't see the tank. Am I supposed to remove the rubber covering - see attached photos.
Lastly, in the attached photos there is a wire with a connector on the end that is not connected to anything - is this something I should be worried about.
Thanks again
Name:	Rear Seat 1a.jpg
ID:	493456   Click image for larger version
Name:	Rear Seat3a.jpg
Old 03-03-2013, 12:34 PM   #12
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Under the seat is where the fuel pump is, not the filter...that's above a panel that's under your seat...under the car.
TL...dr...if you ever need to get to the fuel pump, that's where it is...rt side is pump, left side is sending unit.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 03-03-2013, 01:15 PM   #13
BMWCaptain
Fuel filter is under the car, by frame rail directly under driver door. Remove panel to access fuel filter.
I have no idea where it is for a PT Cruiser.
BMWCaptainE46.com
Old 03-03-2013, 01:47 PM   #14
Brevik
My Ride: Tiag M3
If it were me I would just put the battery in, turn the key a few times to make sure you have fuel pressure and give it a shot. It is not like it has never ran before, it should be just fine, don't over think it. If you are unable to start it after a few trys, then start to dig deeper.
Brevik is offline   Reply With Quote
Old 03-03-2013, 02:25 PM   #15
sgoetz628
My Ride: 2002 330 CiC
Thanks again
It's a good thing you didn't go any further. In case your tank is more than 3/4 full (or maybe it's only half), when you take the pump out you'll be swimming in gasoline. Check other threads or maybe someone else can enlighten further.
I'm putting a new fuel pump in just as soon as it warms up a bit. Since I stored it in December with a full tank of gas, I'll have to drive around a good bit to burn off gas before starting the procedure.
I love my car as much today as the day I bought it
sgoetz628 is offline   Reply With Quote
Old 03-17-2013, 02:10 PM   #16
jsaklas
Sweet success!!!!!
http://s1.e46fanatics.com/forum/imag...icon_thank.gif
Thanks much to all of you. After I finished the brake bleeding, I dropped the car off the jack stands. I removed the plugs, removed the 20 AMP fuse for the fuel pump relay (this was the hardest part of the whole task, surely BMW could design a better fuse box), put about 1- 1.5 tablespoons of oil down the spark plug holes. connected a brand new battery (the old was stone dead) and cranked it 4 times for about 4 seconds each time. Then I put new NGK plugs (the Bosch that were in there looked decent, but since I had them out I replaced them), replaced the 20 AMP fuse, I got behind the wheel and WHAM, after 16 dead months, it fired up after cranking only a second or two. Hey for a 65 year old guy, I almost got a hard you-know-what.
I had the garage door open, but it still made it smell like a diesel truck warehouse - I immediately backed it out, let it idle turned the steering lock to lock (I had changed ALL steering hoses) added some ATF fluid and took off. I kept the RPM below 2500 as I drove through the subdivision. It seemed to run well. There was a scrapping sound at first in the passenger side rear, but it went away (rusting brakes, I assume) and there may be some clicking near the engine rear (valve?, knocking?)
I'm glad I didn't need to change the gas - tank was more than 3/4 full.
It's back in the garage now. I need to change at least one headlight assembly and, if I can, I need a rear end boot - look for me on some new threads.
Again, THANKS
Old 03-17-2013, 02:50 PM   #17
David McMahon
My Ride: '99 E38 740iL
Congratulations
David McMahon is offline   Reply With Quote
Old 03-18-2013, 12:59 AM   #18
BMWCaptain
That is the best way to do it. Nice and simple.
BMWCaptainE46.com
Old 03-18-2013, 01:04 PM   #19
sunsetcoast
Congratulations! Except for the battery, 16 months isn't *that* long for a car to sit.
One thing I have learned is that you can coat the rotors with a very light layer of vegetable oil to prevent rusting. You have to be careful not to saturate the pads. Of course, you also have to remove it when you want to drive it again.
May be more trouble than its worth for many, though.
