Sponsored by BimmerWorld
Old 02-27-2013, 07:10 PM   #1
rekreb
My Ride: Bmw 323i touring
Question DSC Problem Help!!
I always turn off the dsc during dry weather conditions the other day I went out of gas on highway. Right after I put gas into tank I started the engine and dsc light was already on . I wanted to turned dsc on in order to see if the light goes off but unfortunately it didnt go off. I checked the dsc fuses they all seem good . What else it could be it was working totally fine right before It went out of gas . Any Idea?
rekreb is offline   Reply With Quote
Old 02-27-2013, 09:05 PM   #2
hitmanre
My Ride: 2000 BMW 328i
Limp mode?
hitmanre is offline   Reply With Quote
Old 02-27-2013, 09:12 PM   #3
Mf3st
My Ride: e46M3
I would disconnect the battery for some time. Then drive the car around and see what happens, and let us know!
Mf3st is offline   Reply With Quote
Old 02-28-2013, 02:33 AM   #4
rekreb
Originally Posted by hitmanre View Post
Limp mode?
I guess It did put itself in limp mode because there was star sign where you see you are shifting on the dashboard. Does it mean it was in limp mode?
Old 02-28-2013, 02:34 AM   #5
rekreb
That's what I was thinking to do. I am going to it tomorrow then lets see what happens. I will inform you all. Thanks
Old 03-01-2013, 05:58 PM   #6
rekreb
Hey dude disconnecting the battery didn't help at all. Dsc light is still on beside that ses light came on right after I connected the battery. I probably take care the ses light by running the codes but for dsc light I dont know what to do. Does autozone read the dsc codes?
Old 03-01-2013, 07:08 PM   #7
glhx
My Ride: 2002 330ci
Bmw scanner 1.4.0 from xcar360.com for reading those codes.
Autozone can't.
glhx is offline   Reply With Quote
Old 03-01-2013, 09:12 PM   #8
rekreb
Autozone can't.
Do you have one? Are you satisfied with it?
Old 03-15-2013, 06:41 PM   #9
glhx
My Ride: 2002 330ci
I have one. And I'm satisfied with it. It does other things. Like opening all windows and sunroof. With key fob....
One push door lock and unlock for both sides
Mirror doesn't turn down on reverse.
For the price why not.
The other software is easy to get but not easy to use.
1.4.0 is bmw specific codes. Plus recoding capability. Autozone has nothing compared to it.
Inpa is better i don have mine yet.....but it cost$45.... Not a user friendly.
Make sure you read this. http://forum.e46fanatics.com/showthread.php?t=967204
Old 03-20-2013, 10:20 PM   #10
xcar360
Past Site Sponsor
My Ride: BMW 318i
only need a BMW Scanner 1.4.0
xcar360 is offline   Reply With Quote
Old 03-20-2013, 10:28 PM   #11
glhx
My Ride: 2002 330ci
I have only heard that it does. NO ONE has been able to recode a used module. I talked to a guy who had actual pa soft with pa soft support. He said he was able to with a new computer board in his module for $1000.
NSC expert is used to recode used modules. The problem with our modules is actually getting them open to the computer board. They have to be cut open
Old 03-21-2013, 02:10 PM   #12
rekreb
I just purchased one. I am running windows 7 32bit. I have installed the drivers and software correctly but whenever i plug it to the car i am getting "connection error with ike" problem. I have read about it some say you need to bridge pins 7and8 which I checked it was already bridged and some say any model under 2001 need 20pin plug because you need to plug it the one under the hood not the one under the dashboard . i am really confused .do you all have any idea about it?
