Old 02-28-2013, 06:53 PM   #1
Twin_Turbo_S54
My Ride: M3
Spool data: 15 psi @ xxxx rpm
Where does a built S54 see 15 psi of boost pressure, in 3rd gear:
with a precision 6768
with a precision 7675
with a precision 7175?
I have 4 M3s all of them twin turbo. Two S54 M3s and Two S50 B32 M3s. All twin charged.
Would like to convert one of them into a single turbo but would like to know the spool.
At which rpm do you see 15 psi at 3rd gear?
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 02-28-2013, 07:03 PM   #2
Twin_Turbo_S54
My Ride: M3
With twin 68 mm 15 psi @ 6100 rpm, 3200 cc engine
With twin 62 mm 15 psi @ 5600 rpm, 3200 cc engine
With twin 62 mm 15 psi @ 5250 rpm, 3500 cc engine
With twin 57 mm 15 psi @ 4700 rpm, 3500 cc engine
Old 02-28-2013, 07:03 PM   #3
Dreikraft
My Ride: slow m3
im assuming you mean on tip in? most guys are now running the 6766 not 68
Dreikraft is offline   Reply With Quote
Old 02-28-2013, 08:04 PM   #4
BDUB328I
My Ride: bmw 328i S54 sedan (
Did u just answer ur own question?
BDUB328I is offline   Reply With Quote
Old 02-28-2013, 08:09 PM   #5
Commanderwiggin
My Ride: 900rwhp Turbo M3
He wants single turbo info.
If I had to guess:
- 6466 15psi@ 4200rpm
- 6766 15psi@ 4400rpm
- 6768 15psi@ 4450rpm
- 7168 15psi@ 4500rpm
Give or take a couple hundred rpm on each...just rough guessing based off dyno sheets running 18-20psi on ~8.5-9CR 3.2L on 91octane Fuel
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 02-28-2013, 08:54 PM   #6
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
On my 7168 on a 3200cc block (9.5:1), on E85.. I see 200kpa at 4500rpm
I do not have a dyno graph of my car on the 7275.. but I was told it spooled slower.
Old 03-01-2013, 02:54 AM   #7
Twin_Turbo_S54
My Ride: M3
If I had to guess:
thank you, but read my below statements.
Old 03-01-2013, 02:57 AM   #8
Twin_Turbo_S54
My Ride: M3
Marcus,
thats very useful information.
3500 cc
11,5:1 compression ratio
E100
68 mm turbo should see 200 KPA @ 3000-3200 rpm.
Do you know the max whp made with a precision 68 mm turbo?
Old 03-01-2013, 04:14 AM   #9
Twin_Turbo_S54
My Ride: M3
If I had to guess:
dyno sheets cant be used unless it is a load type dyno such as dyno Dynamics.
On dyno Dynamics, I was able to play with the ramp rate (Load) and imitate road like boost build.
By using the correct ramp rate I was able to make boost at the same engine speed as I did on the road.
Now when a dyno jet is used, you cant play around load and that means boost build will be different compared to the road boost build.
As a result, if look at dyno graphs, a load type dyno has to be looked at.
Old 03-01-2013, 04:19 AM   #10
MarcusLSB
Marcus,
3500 cc
E100
I don't unfortunately.
I like that E100 on 11.5:1 I bet that thing rips!
DynoJet does have Eddy brakes (not all but the xLC's do.).
Old 03-01-2013, 05:05 AM   #11
Twin_Turbo_S54
My Ride: M3
If I had to guess:
I ve runnig on Alcohol and 11,5:1 compression since 2009.
Transfers S54 into a different engine.
3500 cc
alcohol
11,5:1
9200 rpm
Old 03-01-2013, 05:31 PM   #12
MarcusLSB
3500 cc
alcohol
11,5:1
9200 rpm
I've been on E85 for a little over a year and a half.. and I love it. My compression however has been lower (9.5:1 or 9:1).. but I'm going to raise the compression to 11.5:1.
Old 03-01-2013, 06:05 PM   #13
Twin_Turbo_S54
My Ride: M3
Marcus, you ll love 11,5:1.
It seems as if onlyy you and I are interested in spool data
Old 03-01-2013, 06:53 PM   #14
MaverickM3
My Ride: gets badge
Me to.
MaverickM3 is offline   Reply With Quote
Old 03-03-2013, 05:04 AM   #15
Providence
My Ride: HPF Stage 3 m3
Send a message via MSN to Providence
After the fuel surge kit is installed we can do the runs for spool data but my 7168 is not cea it is just billet we r starting the fst install this week
Providence is offline   Reply With Quote
Old 03-03-2013, 05:06 AM   #16
Twin_Turbo_S54
My Ride: M3
Good luck mate. Let me know if you need anything.
