Australia
Old 02-28-2013, 07:11 PM   #1
PME46
My Ride: E46 M3, YZF-R6
E46 LED Angel Eyes - Australian Parking Lights
Hey again guys
Got a question regarding aftermarket angel eye installation on Australian E46s.
I've read a lot of threads regarding the installation but 99% are for US delivered E46s which do not have conventional "parking lights" like we do; their front indicators act as parking lights. Therefore the install is fairly simple because there is no issue with bulb check lights.
When I purchased my car it had the wedge bulb parking lights in the high beam reflector removed and had cathode tube angel eyes wired into that circuit. This worked perfectly and did not have any issues with bulb checks. It also ment the angel eyes could be turned on and off just like OEM ones do on E90s. Perfect.
With my new LED ones, it obviously throws a check light if I install it this way due to the lower current draw. It also lights up the front indicator with the bulb check on.
If I was to install them as DRLs with the supplied relay it still won't solve the problem since nothing is wired up to the factory parking lights. Once again bulb check and indicator light on.
So how do we guys here in Aus do it?
Do you just run load resistors in series on each side of the parking lights and it fixes it? Or do you run a relay and wire the parking light wiring on each side as a trigger for the relay (not sure if this would actually work correctly though?)
If I have overlooked a simple thing please let me know haha.
Thanks guys
Phil
PME46 is offline   Reply With Quote
Old 02-28-2013, 07:14 PM   #2
02PRUV
My Ride: E46 M3 Turbo
I just wired them in as daytime running lights and still have park globes in place. I did put the silver coated park light globes in so it looks like the same colour as the angel eyes.
Rides:
BMW E46 M3 Turbo 570rwhp @18psi (old setup)
BMW E46 M3 LSX 427ci 800hp N/A
Ultima GTR LSX 440ci 800hp N/A
VY SS Ute Turbo 1004.6rwhp @ 28psi E85
Ford Escort Mk2 2JZGTE 600rwhp @14 psi
04 Yamaha R1 154.3rwhp
ISUZU FZR550 tilt tray (GT35 Turbo)
02PRUV is offline   Reply With Quote
Old 02-28-2013, 07:24 PM   #3
ating
My Ride: 2004 M3
Sorry, probably can't help you but I have a question of my own. I recently got my hands on the EAS Aurora 60 LED AEs. Have been looking for these for a while. Anyway, the way they're wired up is a direct wire tap to the power line (so they are always on when the car is on), and also to the remote wire (so they fade in/out when the car is locked/unlocked). Will I get the same problems with bulb light checks?
Evolve CSL airbox w/Alpha-N tune | KW v2 | Vorshlag Camber Plates | WORK Equip 18x10/12 | Dixis Ti exhaust
ating is offline   Reply With Quote
Old 02-28-2013, 07:25 PM   #4
PME46
Yeah figured a lot of people would have done it that way. If mine had them in there it would be an option
If you keep your factory parkers in the reflector housing like 02PRUV has, than you won't have an issue. Mine is only an issue as the previous owner removed the factory parkers and had the cathode angel eyes wired into their circuit.
Old 02-28-2013, 07:42 PM   #5
Tiag46
My Ride: e46
I did the same, as per 90% of most install out there, I tapped the wire in the ECU box
except I added a switch so I can turn on/off whenever I like.
Nope. Mmm EAS aurora's, do want.
*Wrecking* - Heaps of parts available.
http://forum.e46fanatics.com/showthread.php?t=1103190
Tiag46 is offline   Reply With Quote
Old 02-28-2013, 07:46 PM   #6
[SeN]
My Ride: 2002 M3 Imola Red
Make sure your LEDs are CANBus ones so they wont throw error codes.
I'm using some cheapo ones from ebay with 2 leds on them so they arent bright at all. No error codes ftw.
Bilstein PSS10 /// Vorshlag Camber Plates /// Turner Motorsports RSM /// Rogue Engineering Octane SSK w. ZHP gear knob /// Dice MediaBridge 1500
[SeN] is offline   Reply With Quote
Old 02-28-2013, 08:11 PM   #7
PME46
I think i'll have to try the load resistor. I have some at work so worth a shot. I just don't like how hot load resistors can get.
Old 02-28-2013, 08:46 PM   #8
CortinaD
My Ride: lots
Just code out the bulb check warnings with ncs expert or nav coder
CortinaD is offline   Reply With Quote
Old 02-28-2013, 08:53 PM   #9
PME46
I suppose that could be an option aswell (didn't actually think of that!). I don't have those though so I suppose I could ask the guys at the dealership nicely.
Old 03-01-2013, 05:05 AM   #10
fgin
My Ride: e46 facelift
where are you located ? if youre around SE melb then im happy to code them out.
fgin is offline   Reply With Quote
Old 03-01-2013, 05:50 AM   #11
PME46
Really appreciate the offer man but im in North QLD.
Been looking into this NCS expert thing and maybe thats the best option. Found a company in the Uk BMTecniks that sell the cable and software for much cheaper than I thought. Seemes you can program some pretty cool things with it aswell!
Old 03-01-2013, 12:45 PM   #12
shannon1
shannon1's Avatar
My Ride: 2001, 318i
I've got my AE's wired in as DRL's so they're always on and I just removed my parker globes and spliced in a couple of load resistors to stop the bulb out warnings.
Shannon.
shannon1 is offline   Reply With Quote
Old 03-01-2013, 10:50 PM   #13
N4NOOK
My Ride: 323ci
ooh ooh ooh could you please do mine one day sir?
Also need codes read, think fuel pumps on the way out :/
will send PM
N4NOOK is offline   Reply With Quote
Old 03-02-2013, 06:33 PM   #14
fgin
will send PM
sure .. PM replied
Old 03-03-2013, 09:14 PM   #15
PME46
I ordered the cable and NCS expert so will give that a go when it arrives. Will chuck up some photos when i'm done.
Old 03-04-2013, 01:53 AM   #16
Tiag46
My Ride: e46
Link to where you ordered it from?
Old 03-04-2013, 02:24 AM   #17
PME46
http://bmtechnic.co.uk/bmw-diagnostic-cable/
Old 03-04-2013, 04:24 PM   #18
CortinaD
My Ride: lots
You can also break your car up so be very careful.
Old 03-04-2013, 08:20 PM   #19
PME46
Definetely will be!
Old 03-04-2013, 08:35 PM   #20
Jall
My Ride: 328Ci
This is what I did.
Also happy to help those in SE suburbs with coding.
Jall is offline   Reply With Quote
