Australia
Old 03-04-2013, 11:10 PM   #21
PME46
My Ride: E46 M3, YZF-R6
On the topic of coding. Is there particular things you guys would highly recommend doing?
I'm going to do the both door unlock on button press, as doing one at a time annoys me when the missus has to get in on her side.
M track mode seems like it might be a little bit of fun.
Indicator flash on unlock would be nice aswell as mine only flashes on lock.
Any hidden cool things you can code? I've read a couple of threads with big lists of all sorts of things you can change.
PME46 is offline   Reply With Quote
Old 03-05-2013, 12:17 AM   #22
CortinaD
My Ride: lots
Here are some code changes I enjoy most times I use the car. I have done others but will put them in a thread with video later.
Stop rear windows opening on unlock down (or add window close to lock down)
NAV to ece to get rid of accept screen
turn off nav instruction on kombi
mirror dip in reverse custom position
less sensitive auto headlights
airconditioning to remember last setting when pressing auto
don't stop auto window rollup when opening/closing door
CortinaD is offline   Reply With Quote
Old 03-06-2013, 05:14 AM   #23
betik
My Ride: BMW 05 E46 318i
with this would i be able to turn my engine light off?
betik is offline   Reply With Quote
Old 03-07-2013, 01:34 AM   #24
TitanSilverE46
My Ride: 2001 318i & 325i
Regarding the parking lights (original question) I tackled it differently.
I wasn't happy with the yellow look of the parkers against the white of the angel eyes. I fitted white LEDs in the parking light holders but knowing this would throw a code, I did a swifty!
Instead of fitting a load resistor, I spliced in another T10 holder into each parker wiring and inserted the original parking globes, letting them hang loose in the engine bay.
Of course, now that I have PASoft I would code the parkers out and be done with it.
TitanSilverE46 is offline   Reply With Quote
Old 03-07-2013, 09:04 PM   #25
Yaraphon
My Ride: 325ci
How much does it cost to get the warning lights coded off in Sydney? I've sorta solved the problem another way but it would be cleaner to have them coded. When I installed the AEs I also installed an hid kit and tinted the high beam bowl dark metallic black as my high beams mostly come from the hid's shutter. It's still reflective but not much and hard to notice the driving light bulbs at all now compared to the angel eyes and the bowl doesn't get illuminated behind the angel eyes. I also have some chunky heatsinked resistors I was gonna try too but if it's cheap to recode the lights I might still do that... wiring is getting a bit crowded in there as it is.
Yaraphon is offline   Reply With Quote
Old 03-07-2013, 10:29 PM   #26
TitanSilverE46
This is the Coding software/hardware I bought BMW Scanner PASoft 1.4.0
Old 03-08-2013, 07:27 AM   #27
Yaraphon
My Ride: 325ci
OK great. Have you tried it out yet? Does it come with instructions? It mentions that it's never locking in the title and offers an explanation below.. "Good News! Our BMW 1.4.0 will never locking now!" What is this referring to and should it be more confidence inspiring than it sounds?
Old 03-09-2013, 03:54 PM   #28
TitanSilverE46
I have used the BMW Scanner and recoded my indicators to flash when I lock/unlock the car, also only the front windows to drop when I hold the 'open' button for 5 secs.
I also reset the service interval from 24,000km to 12,000km.
I could delete the parking lights from the 'check' that is done on startup but haven't yet.
There are several threads that describes the use better:-
Thread 1
Thread 2
Thread 3
Certainly worth a look.
Old 03-10-2013, 11:40 PM   #29
Yaraphon
My Ride: 325ci
Ok thanks. I've been reading up a bit on it and ordered one today. I could have got the cheaper one on ebay for $29(which is probably exactly the same) but got a $34 one from xcar360 that people seem to have had success with.
Old 03-20-2013, 10:04 PM   #30
xcar360
Past Site Sponsor
My Ride: BMW 318i
you can bought BMW Scanner PASoft 1.4.0
http://www.obd2toolbox.com/auto-diag...0-version.html
xcar360 is offline   Reply With Quote
Old 03-21-2013, 07:14 AM   #31
betik
thisss
Old 03-22-2013, 09:37 PM   #32
Jall
My Ride: 328Ci
Only if you've fixed the problem that caused it to appear in the first place...
Jall is offline   Reply With Quote
Old 03-22-2013, 10:48 PM   #33
Tiag46
My Ride: e46
^can anyone vouch for the above Scanner?
*Wrecking* - Heaps of parts available.
http://forum.e46fanatics.com/showthread.php?t=1103190
Tiag46 is offline   Reply With Quote
Old 03-22-2013, 10:52 PM   #34
Jall
My Ride: 328Ci
I have one and love it, one of the best things I've purchased for the car.
Old 03-22-2013, 11:49 PM   #35
Tiag46
My Ride: e46
Sweet, did you buy it from above sponsor?
Old 04-02-2013, 02:23 AM   #36
PME46
Ended up coding out the bulb check with the NCS Expert software from BM Technics. Thanks for all the help guys.
Will chuck up some photos on my other introduction thread of the angel eyes once I put the new wheels on aswell
Old 04-02-2013, 02:57 AM   #37
CortinaD
My Ride: lots
Good to hear it worked out for you mate, definitely the best solution compared to resistors and what not.
