Go Back   E46Fanatics > Tuning & Tech > Forced Induction Forum Sponsored by Active Autowerke
Old 02-28-2013, 06:37 PM   #1
luke@maximumpsi
My Ride: 750hp E36 NickG Tune
Official Release - Maximum PSI E46 M3 Turbo Kit
Hey guys,
We are ready to officially release the Maximum PSI E46 Stage One Turbo Kit!
Our kit represents a true bolt on option. It comes with every nut, bolt, widget, and thing-a-majig you need to bolt it in. You can buy our turbo kit, install it over the weekend, and in turn have a 600+ whp capable E46 on the stock DME!
Here is what is included with the kit:
  • Technique Tuning turbo software utilizing the stock DME!!!
  • Maximum PSI twin scroll tubular exhaust manifold (ceramic coated)
  • Precision 6266 Twin Scroll Turbo
  • Maximum PSI aluminum intake manifold
  • Tial MVR wastegate
  • Synapse Diverter Valve
  • High flow front mount intercooler
  • Intercooler mounting hardware
  • Maf Sensor
  • Maf Harness
  • Air temp sensor
  • Spark Plugs
  • Injectors
  • Injector Connectors
  • Fuel Rail Hardware
  • Aeromotive fuel pump assembly
  • Intake pipe
  • 3" K&N air filter
  • 2.5" stainless steel hot side charge piping
  • 3" Stainless steel cold side charge piping
  • All silicone couplers and clamps needed for the kit
  • Check valve for the evap system
  • Turbo oil feed assembly
  • Turbo oil drain assembly
  • Oil pan drill bit and tap
  • Oil pan tap template
  • Full 3" Stainless Steel downpipe with optional catted or catless exhaust
  • Stainless steel wastegate tube with mounting hardware
  • Turbo mounting hardware
  • Turbo gasket
  • Header mounting hardware
  • Header Gaskets
  • Valve cover breather hose and clamps
  • Motor mount arm
  • Motor mount arm hardware
  • Motor mount
  • Intake manifold brace and hardware
  • Oil pan vent plug hardware
  • IVC hose, clamps, and fittings
  • Washer bottle pump tank, and assembly with hardware
  • SMG relocation kit and hardware (if necessary)
  • Brake duct block and hardware
  • Vacuum hose
  • Vacuum fittings
  • Wiring supplies
  • Zip Ties
  • ECU Shipping Bag
  • Bumper Weather stripping
  • Step-by-step installation guide with lots of pictures!
Power gains:
93 Octane, catted down pipe with stock exhaust - 477 WHP and 368 WTQ
93 Octane, catless down pipe with stock exhaust - 484 WHP and 367 WTQ
103 Octane, catted down pipe with stock exhaust - 550 WHP and 417 WQ!!!
These numbers were recorded using a Dynojet 224x. Here is the dyno file:
The following graph shows the same exact dyno runs on our Superflow Autodyn30 recorded the same day. We see numbers 6-7% lower than any dyno jet. (This is pump catless and 103 catted)
Benefits when comparing to our competitors:
  • Stock MSS54 ECU tuning
  • Single Bank 02 sensor Conversion (More info on the benefits of that here: http://forum.e46fanatics.com/showthread.php?t=967056)
  • No fault codes stored or hidden
  • Utilization of the the "Check Engine" light (it will only illuminate if there is a real fault in the system)
  • All factory diagnostic checks are functional
  • The catted version will be able to pass all OBDII readiness tests without any "trickery"
  • OEM int
  • The catless version will have no CEL illuminated, however it will not pass the OBDII readiness test for cats and 02 sensors.
  • Our kit produces more power across the entire power band pre pound of boost when compered to any other bolt on turbo or supercharger kit without methanol injection
  • A cheaper more powerful turbo option
  • Our kit utilizes a tubular stainless steel manifold
  • Hand fabricated parts made and quality tested in the good ole' USA
  • The power gains we show are made with the bolt on kit through a full stock exhaust; nothing else is required to reach these numbers!
  • More gains are to be had with additional exhaust modification
Dyno Comparisons:
Maximum PSI Pump
Catless through stock exhaust
VS.
ESS VT2-550
Euro Headers
Highflow Cats
3" Section 2 aftermarket muffler
Our E46 M3 turbo kit vs HPF stage 1/stage 2 turbo kit on pump gas. Our two runs were with the catted and catless downpipes through the stock section 2 and muffler:
Pricing:
  • Six Speed non-catted downpipe: $9800
  • Six speed catted downpipe: $10,000
  • SMG non-catted down pipe: $10,000
  • SMG catted downpipe: $10,200
  • Installation: $2,200
We are ready to accept all years and all models (six speed and SMG) for in house installs. The six speed kits are ready for commercial shipment. We would like to get one more SMG install done in house prior to being ready for commercial shipment. Please call us if you are interested for an in house install as positions are filling up quickly!
We have stock pile of parts that are ready for new homes on your car!!
Additional Pictures:
Final Exhaust Hardware (Twin Scroll Goodness):
Aluminum Intake Manifold:
Catted second section of the downpipe:
Install Instructions:
Call or email us for info or to place an order!
Luke King - Sales@maximumpsi.com
908-290-3571
Last edited by luke@maximumpsi; 05-02-2013 at 11:16 AM. Reason: Auto-save 1367511390
luke@maximumpsi is offline   Reply With Quote
Old 02-28-2013, 06:46 PM   #2
Commanderwiggin
My Ride: 800rwhp Turbo M3
Looks like a very impressive kit...had this been out a few years ago I know the decision would've been very clear. Excited to drive one of these in the future.
Commanderwiggin is online now   Reply With Quote
Old 02-28-2013, 06:59 PM   #3
BDUB328I
My Ride: bmw 328i sedan (E46)
Install looks as ez as reading a picture book
CHECK OUT MY M3 SEDAN SWAP!!
http://forum.e46fanatics.com/showthr...978&highlight=
AND MY 328I PARTS FOR SALE
http://forum.e46fanatics.com/showthr...057&highlight=
SPONSORS: |Good 'N Plenty Restaurant, 150 Eastbrook Road Smoketown, PA| |http://www.thebmwpartstore.com/ | | http://www.advancedclutch.com/ |
BDUB328I is offline   Reply With Quote
Old 02-28-2013, 07:17 PM   #4
MotivatedPY
My Ride: 04 M3
This is awesome guys! Did u do any comparison between the 6266 and 6466 with this kit by chance?
MotivatedPY is online now   Reply With Quote
Old 02-28-2013, 07:23 PM   #5
luke@maximumpsi
We compared the 6266 and 6766 and chose to stick with the 62. We have a built motor car getting the 6466.
908-290-3571
Old 02-28-2013, 07:42 PM   #6
M3PTGSC
My Ride: M3
What about stage 2 or 3? How much power can the stock ECU handle? Or should I say how big injectors can it run? I'm sure everyone is wondering about upgrading and price for let's say to make 700 rwhp,would the stock ECU handle it or would the customer be required to buy standalone?
I'm sorry if its been answered already,haven't been on here lately,
Thanks!!
09 SL63 AMG Designo,pano and whole nine yards lol
07 S550 P2 4matic-
03-M3-6766 DBB..Tubular manifold...
97-M3-
95-M3 SC stage 2-Widebody...
08 Gix 1k 08 ZX10R
M3PTGSC is offline   Reply With Quote
Old 02-28-2013, 07:45 PM   #7
MarcusLSB
My Ride: BMW's
Well done!
youtube.com/marcuslsb -- Photography by Gheybe!
Old 02-28-2013, 07:47 PM   #8
MarcusLSB
My Ride: BMW's
Thanks!!
I think going up to 700rwhp on a kit like this takes away from the whole point of the kit. Simplicity and drive-ability. Obviously the HPF cars for the most part drive like stock, when I say drive-ability I mean, no check engine lights, no massive 4" exhaust, etc.. just a real well put together kit. You start getting into stand-alone territory and the prices are going to jump up real fast.. wiring harnesses, the ecu, etc, etc.. now you're looking at the same price as the HPF Turbo kit.
Old 02-28-2013, 08:00 PM   #9
luke@maximumpsi
I made 750 whp with my E36 on a stock ecu with NickG behind the keyboard and mike making the hardware. I used to daily drive the car with the same benefits of a 500whp car...then I got speed hungry and gutted it.
We have a current built motor kit e46 that will test the limits of the 6466 utilizing the stock ecu.
Our name is MAXIMUM psi
908-290-3571
Old 02-28-2013, 08:07 PM   #10
M3PTGSC
My Ride: M3
That is true....but Nick G did his magic on E36 cars and you could drive 650rwhp E36 M3 and had same driveablity like the 400rwhp one just a lot faster,but I wasn't sure about E46 ECU since active tried it and it didn't work...
I'm looking forward to see it perform!! I know Mike wont stop pushing it
07 S550 P2 4matic-
97-M3-
08 Gix 1k 08 ZX10R
Old 02-28-2013, 08:10 PM   #11
Think0rz
My Ride: 05 AW M3
Maximum PSI's turbo kit
that you will
Think0rz is online now   Reply With Quote
Old 02-28-2013, 09:00 PM   #12
NickG
My Ride: 2001 330ci turbo
Supporting 700rwhp should be no problem for the factory ECU.
Nick
2001 330ci Turbo
NickG is offline   Reply With Quote
Old 02-28-2013, 10:05 PM   #13
dan avoN7
My Ride: A car
Nice looking kit! Also very competitive pricing, should lead to a lot of sales
dan avoN7 is online now   Reply With Quote
Old 02-28-2013, 10:13 PM   #14
MarcusLSB
My Ride: BMW's
Awesome! Can't wait to see it! If someone's looking for pistons and rods for their Maximum PSI 700rwhp S54.. let me know.. I got some for sale for cheap (see sig).
Old 02-28-2013, 10:16 PM   #15
sheefo2k
sheefo2k's Avatar
My Ride: vrm psh - 02 325ci
My tune on my E46 was a NickG tune and never had one problem in all the years I used it!
Performance BMW car
Sponsored by :
www.euro-spec.net
www.bimmian.com
BMW Motorwerks
support:
www.vmwerks.com
www.esstuning.com
www.my330i.com
sheefo2k is offline   Reply With Quote
Old 02-28-2013, 10:16 PM   #16
sheefo2k
sheefo2k's Avatar
Another reason to sell my E39 M5 and look for a E46 M3.
Performance BMW car
Sponsored by :
www.euro-spec.net
www.bimmian.com
BMW Motorwerks
support:
www.vmwerks.com
www.esstuning.com
www.my330i.com
Old 03-01-2013, 07:23 AM   #17
z3speed4me
My Ride: 99 M Coupe
Amazing work as usual gentlemen.
Can't wait to see that 6466 shine on a built car!
~Ken~ {M coupe} 623 whp 516 wtq; 21 psi; Precision 6466, Maximum PSI Twin Scroll Manifold, 3.5" exhaust, Nick G. 60lb Tune; Randy Forbes kit in the back...
z3speed4me is offline   Reply With Quote
Old 03-01-2013, 07:55 AM   #18
luke@maximumpsi
The E39 M5 has the same ECU as these cars
908-290-3571
Old 03-01-2013, 08:42 AM   #19
MaverickM3
My Ride: gets Badge
Great job MaximumPSI/NickG.
Photobucket Pictures, Images and Photos
MaverickM3 is offline   Reply With Quote
Old 03-01-2013, 11:18 AM   #20
normcaldwell
My Ride: 2006 M3 Coupe 6MT
I'm excited to see this product come to market!
What a great combo; high quality hardware via Mike and team, plus the best in the land at tuning, and noteably in the turbo-charged arena, NickG.
Even though I have a centri-kit now; I'm mighty tempted . . .
Does anyone have pics of the underbody with the current kit configuration?
I'd like to see how much, if any, of the piping is below stock underbody clearance.
2006 M3 Coupe | 6MT | Carbon Black Metallic | Cinnamon | No Sunroof | OE CSL Bootlid | 3.91 Diff | TCK | DrVanos | RAC | Volk
ESS Hardware | Evolve Software | StopTech | Supersprint | Bimmerworld | BSW | TMS | Carbon Dynamics | Vorsteiner | Hoen
normcaldwell is offline   Reply With Quote
