Miscellaneous
Old 03-14-2013, 05:29 PM   #1
erich330ci
My Ride: 2004 330ci
WTB: 32mm Spanner Wrench & Fan Pulley Holder
Replacing water pump & thermostat on automatic. Hoping to do it only once, so I'd rather not have to spend $50 or so for these two tools if I can avoid it. Any kind soul out there have a wrench & holder that you don't want / need / plan on ever using again that you'd be willing to let go for cheap?
Eric H.
erich330ci is offline   Reply With Quote
Old 03-15-2013, 02:56 PM   #2
mcr_driver
My Ride: my favorite two feet
try amazon I've seen them for as cheap as 30$
mcr_driver is offline   Reply With Quote
Old 03-16-2013, 12:17 AM   #3
latino1ny
My Ride: BSM 335i
you plan on replacing the waterpump and thermostat only ONE time in the entire time you're going to own your car? Are you going to sell it soon or something? Incase you weren't aware, the cooling system is the weak point in the E46, and should be replaced every 60,000-80,000 miles. Preventative maintenance. Unless you don't plan on owning your car for too long, I wouldn't suggest only replacing them ONCE...
as for the tools, go to Northern Tool or another tool store and buy a 32mm wrench (it will fit, nothing special) then go to Lowe's and buy a piece of flat bar, 1/8" x 1" x 36" and drill a 7/16" hole near the bottom. This bar in combination with a 32mm wrench, will work as your fan tool.
Link to aluminum flat bar from Lowes:
http://www.lowes.com/pd_215885-37672...7C1&facetInfo=
Link to 32mm Wrench from Northern Tool:
http://www.northerntool.com/shop/too...3312_200313312
If you need more detail just let me know and I can take pictures of my flat bar so you'll understand better.
'08 BSM E92 335i 6MT/KW V1s/matte black grills/blacked out side markers/complete LED interior kit/DCI/M-aero front lip/Alcantara shift boot/Clutch stop/CDV delete/LED reverse lights/muffler delete/Cyba scoops/3.8" Cyba tips
latino1ny is offline   Reply With Quote
Old 03-16-2013, 10:56 AM   #4
erich330ci
My Ride: 2004 330ci
Good ideas. Thanks.
Eric H.
