Old 03-03-2013, 11:39 PM   #81
Akonion
My Ride: Mercedes C230
Nice car!
Do not let the high mileage get you down, maintain it and it will last you forever!
2007 W203 C230 Kompressor <---- SOON TO BE RID OF
2006 E46 330Ci or R171 SLK <---- MUST ACQUIRE
Akonion is offline   Reply With Quote
Old 03-04-2013, 01:30 AM   #82
mitfa911
My Ride: 2001 330 CIc
Don't listen to the haters. Great car to start with. Learn the car, drive it, enjoy it and you can always upgrade to a newer one later on. A lot of people on here don't like the 323. They are as good as any other e46.
mitfa911 is offline   Reply With Quote
Old 03-04-2013, 12:25 PM   #83
wildirish317
My Ride: 2004 325Ci vert
Originally Posted by Kells427 View Post
...plastic housing that clips together midpoint...
Post a pic. I just looked at my engine and couldn't figure out what you are talking about. We prob have different layouts though (99 323 vs. 04 325). A lot of things get moved around the engine compartment over the years.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 03-04-2013, 03:10 PM   #84
Alex323Ci
My Ride: M3 & 323Ci (sold)
right now I'm searching to figure out what something is on the car...I didnt want to open it because the plastic can be so brittle in the cold....its black, round, and it sits next to the coolant tank...plastic housing that clips together midpoint...I'll take a picture tomorrow and post if I cant find it online tonight...I found all the other filters and this thing isn't bolted in so I'm quite curious
well two things come to mind. 1) it's the power steering fluid reservoir. or 2) you have mistakenly thought the windshield washer fluid tank is the radiator fill tank. Which means you're not missing an expansion tank cap, but the washer cap.(makes more sense). And the round black plastic thing you're talking about is the SAP (secondary air pump).
Old 03-04-2013, 03:35 PM   #85
wildirish317
If Alex is correct, then I suggest that your first (and fastest) purchase be this:
Which you can find here:
http://forum.e46fanatics.com/forumdisplay.php?f=38
It will help you sort out what's where and why in the engine bay, along with the rest of the car.
Last edited by wildirish317; 03-04-2013 at 05:29 PM. Reason: fixed broken link (maybe)...
Old 03-04-2013, 03:43 PM   #86
Kells427
My Ride: 323i
o lord duh.... yes I was talking about the windshield tank ...the blue stuff...ay ay ay....brain was more rattled about the "SAP" if that it what it is....it looks like the bolts have broke off and its just sitting in its place
ID:	493730   Click image for larger version
ID:	493731   Click image for larger version
Kells427 is offline   Reply With Quote
Old 03-04-2013, 07:11 PM   #87
glhx
My Ride: 2002 330ci
I've heard that the synthetic oil is for the vanos assembly. If you look at why besian puts the anti rattle kit in there. It's because of wear on the gear. While it isn't cost effective to replace the gear....they came up with the ring with closer tolerances to fix the rattling. On mine there wasnt any rattle I could hear. When I did the vanos piston test I could see the axial play. When doing the seals I could see the wear pattern. I could have let it slide and not put the $150 into the vanos. But then I'd be doing another $80 valve cover gasket.
Don't put cheap oil in the m54 engine. Regular oil would not fit the profile for the closer tolerances that cars running synthetic need. The vanos shows this
If we were talking about a 98 dodge ram or Chevy cavalier.Then yeah....cheap is fine. I can agree with jfoj on the fuel use. If your not driving fast you probably don need the detonation protection. You could run 89 octane. Keep this in mind though. Higher octane fuels usually use less ethanol. Some brands like shell and chevron put cleaner in the gas
I use techron fuel system cleaner around every 5000 miles. With that many miles on yours I do not know if that would be a good idea because it might dislodge any clogging n make it worse. Seafoam has been said to do that.
Techron.....anyone chime in on that
This isn't the car you can be cheap on. If your husband that mentality. He needs a Honda or a Toyota. Bmw demands maintenance. The problem is.....if you don't maintain it. The part you didn't maintain causes something expensive to break. Like the guibo.....$50 for the guibo.....maybe $50 for the support bearing......but if they go......$500 for the dive shaft....and still$100 for the other 2.
My girlfriend used to buy cheap tires. And let them get bald. Last November she flipped her car because of it.....it cost her more financially than 5 sets of good tires. That's my experience with my 330.
The Bentley repair manual is cool to have. But there is enough info here that I haven't needed it
glhx is offline   Reply With Quote
Old 03-04-2013, 07:16 PM   #88
wildirish317
Don't feel bad. The first time I opened the hood of a BMW (E36), I wasn't sure about half the stuff I was looking at. It happens to all of us. BTW, the Bentley was my first purchase for my E46. They are indispensable.
Last edited by wildirish317; 03-04-2013 at 09:14 PM. Reason: spelling is not my strong suit
Old 03-04-2013, 07:31 PM   #89
glhx
My Ride: 2002 330ci
Does it have wiring diagrams. I would like some of those
Old 03-04-2013, 07:33 PM   #90
Kells427
My Ride: 323i
Exactly why she's my baby and not his....I have no problem spending money
Old 03-04-2013, 07:41 PM   #91
wildirish317
About 25% of the pages (3" thick book) is wiring diagrams.
Old 03-04-2013, 08:08 PM   #92
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
What is broken on the SAP is the mounts. There are 3x studs with a rubber isolator in the middle. They are $8-$14 a piece at most places or you can order them at RMEuropean for about $2.85 each.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 03-04-2013, 08:11 PM   #93
BMWCaptain
I bet you don't!
BMWCaptainE46.com
Old 03-04-2013, 08:19 PM   #94
Kells427
My Ride: 323i
I'm looking the SAP up now...the whole unit can be picked right up....the mounts are snapped in half....
I bet you don't!
I sure don't when I work like a rockstar.....I completed 4 years of college on track full time, while working full time 50-60hrs a week in retail management at a pharmacy..originally had 2 daughters went through a 3rd prego w school and work ft....went into labor at work...took my finals from my hospital bed that night....
only reason Im outta work now is we just moved cross country and Im getting into my degree field...
Old 03-04-2013, 08:33 PM   #95
BMWCaptain
You have accomplished a lot and under stressful conditions. Congratulations! Great to someone with goals and drive like that. Pun intended.
I did not need your life history and your justifications for spending money. I was merely referring to one of the things women love to do.
You can use several zipties to hold the SAP until you get your new mounts.
BMWCaptainE46.com
Old 03-05-2013, 12:36 AM   #96
Sweetness
My Ride: '01 325i
Take picture of yourself with your car?
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
Old 03-05-2013, 02:10 AM   #97
Akonion
One of the benefeits of being married, no?
Old 03-05-2013, 03:28 AM   #98
Eliott's-BMW
Eliott's-BMW's Avatar
My Ride: E46 3-Pedal Mafia
Good look with the car, and kudos for being a woman and working on your own cars.
Looks like you're not used to german cars, so to me your in for a big adventure.
I highly recommend putting down your novels or girly books and picking up the e46 Bentley Service Manual, it will save you a lot of time, suffering, frustrations and money, and don't believe everything you read on the internets (talking about some clueless peeps around here giving advise )
PS: if the automatic trans ever fails just do a auto to manual swap and cost's about the same $$$ as rebuilding an auto trans (auto trans suck, you never get the full experience of driving a bmw) get a manual, especially if you are used to manual.
Who has the skills?
e30 project
"May GOD grant you DOUBLE the amount you wish upon me!"
Eliott's-BMW is offline   Reply With Quote
Old 03-05-2013, 04:34 AM   #99
Alex323Ci
ah no biggie, we all make mistakes on newly introduced engine bays
one good thing is your car has its expansion tank cap(and thus the cooling system is closed) and only missing the washer fluid cap.
SAP may have been changed once and mounts broken, not hard to fix.
I would check the coolant level and color when cold. Again the expansion tank is like a built-in overflow tank. It is not like the top of a radiator though. So the coolant should NOT be at the top. Read the embossed filler neck label attached(its next to the cap) to see how to read the "bobber" and stalk for coolant.
if you plan to do more DIYs and upkeep I too recommend the Bentley Manual.
Old 03-05-2013, 08:37 AM   #100
miweber929
My Ride: 02 330xi
Social commentary is all, but how many of you would do the "awww shucks, we all make mistakes" and "it's only a high mileage car, it'll be fine" and "good job identifying the washer fluid tank as the expansion tank" comments would you all make if the OP wasn't a female? By looking at other threads on here I'd say not too many!!! Sheesh, leg humpers all around...
OP, you bought a very high mileage car, sounds like you paid a good price but its a good thing you want to work on it yourself because it will be a maintenance whore and not cheap by any means compared to a typical Japanese or American car with similar mileage. Get a manual first thing or there will be far more mis-identified parts and locations that will cause you issues in the long run (ATF reservoir under the hood is the PS fluid, not transmission fill for one) and take what you read here with some hesitation because their are a lot of 17 year old "experts" that have done 1 DIY and suddenly handing out advise all the time; you'll find who the good ones are soon enough. It's an easy car to work on but knowing what to do can be confusing as some look at them as a priceless work of art and replace EVERYTHING, others can't afford the gas and replace nothing; reality is somewhere in the middle.
And find a good Indy shop, you'll need it if nothing else for someone to tell your husband he's wrong and to use BMW fluids in your BMW or for those over-your-head-have-you-seen-this-before items.
miweber929 is offline   Reply With Quote
