Old 03-12-2013, 09:23 PM   #81
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
I think it's your commute. At freeway speeds, you do very little stop and starting. Your commute I would assume has plenty of stops and starts in it. You say your average speed is 50 mph on your commute. Taking your numbers of 12.5 miles in 20 minutes; that's an average of 37.5 mph. If it took you 25 minutes, that would lower the average to 30 mph. And don't forget, you're driving part of your commute with a cold engine so that alone lowers your mpg. If your commute was like mine (27 miles one way), you'd see better mpg. 500 miles of your daily commuting is very different than 500 miles one way of mostly freeway driving. I think the numbers you're seeing are in line with what you should expect.
HacksawMark is offline   Reply With Quote
Old 03-12-2013, 09:27 PM   #82
gselsidi
My Ride: 2005 325i M56
Originally Posted by hacksawmark View Post
I think it's your commute. At freeway speeds, you do very little stop and starting. Your commute I would assume has plenty of stops and starts in it. You say your average speed is 50 mph on your commute. Taking your numbers of 12.5 miles in 20 minutes; that's an average of 37.5 mph. It's your commute.
yeah but would this commute equate to a 50% difference in gas mileage?
gselsidi is offline   Reply With Quote
Old 03-12-2013, 10:07 PM   #83
HacksawMark
In your situation, the answer is yes. Not sure how the automatics work but during my commute, I'm in 5th gear by 40 mph. I think it's just the nature of the beast you're dealing with.
Old 03-12-2013, 10:24 PM   #84
gselsidi
such a wild difference never experienced this with other cars. Going to test if letting the car warm up helps at all.
Old 03-12-2013, 10:46 PM   #85
HacksawMark
Not sure if warming up the car will help. It may actually hurt your mpg. If it gets really cold where you are, maybe a block heater or oil pan heater will help. With a manual, it's better to just get moving and keep your rpms to no more than 2000 before shifting. I also don't run my heater until the car warms up; it seems to warm up faster.
With my Honda gas-electric hybrid, warming the car will result in a big reduction in mpg. But that car also has to be driven right to attain high mpg. I hear of people driving the same car but can't get more than 35 mpg when I can easily attain 45+ mpg. It's all in how they operate the car.
Old 03-12-2013, 11:07 PM   #86
gselsidi
yeah I think it might waste more also, will try to use manual shift mode and experiment with that. Still experimenting with neutral on hills or keep it in drive. I think the cutoff is the same I never went to 0% fuel trim when coasting down hills, I doubt it cuts off all fuel, that never really made much sense to me, I could be wrong but will experiment with neutral only on complete stops. how hard do you accelerate btw? because keeping it under 2k would in my mind mean real slow acceleration.
Old 03-12-2013, 11:43 PM   #87
HacksawMark
I only keep it to 2000 rpm when it's cold. In city driving, I drive very conservatively anyways so I'm always in 5th gear by 40mph. I always coast in gear, never in neutral. I don't recommend it with an automatic either. If I accelerate hard, I'll usually shift from 3rd to 5th. I do downshift from 5th to 4th when changing lanes on the freeway-in-town. Some parts are 35 mph and I'll just put it in 4th gear and set the cruise; it usually cruises at about 40 mpg. I use my cruise-control very liberally since it's better at keeping a steady speed than I am.
Old 03-13-2013, 12:07 AM   #88
gselsidi
so your getting about 40mpg cruising? or you are cruising at 40mph? Yeah I cruise is much better at keeping the speed I noticed it when I had the instant mpg up on the menu, cruise would always go lower then me during acceleration.
Well I will coast in whatever gives me the most mpg, when I didn't use neutral at all I got 20mpg when I used neutral all the time at stops and coasts I got 25mpg, now I am testing coasting in gear and neutral only at lights.
Old 03-13-2013, 12:32 AM   #89
HacksawMark
Possible that you need to work the auto differently than a manual to get optimum mpg. I notice that my mother's 97 Honda Accord gets about 21-23 in the city but up to 34 on the freeway. It a 4 cyl with 4 speed auto. I can attain about 26 in the city but I'm easy on acceleration and coast when coming to a stop. Mom is usually pedal-to-the-metal and at 79, I'm not going to try and stop her LOL!
Old 03-13-2013, 01:09 AM   #90
gselsidi
My old acura was like a hybrid city or highway it would always avg 30mpg lol
Old 03-13-2013, 09:36 AM   #91
HacksawMark
Acuras are great cars. I had a '02 Type S and an '04 TL. Of the two, I liked the '02 better; it was faster and got better mpg. Took it on a road trip from Portland OR to Binghamton NY to Dallas TX and back to Portland. It averaged 35 mpg the entire trip. The '04 could manage only 24 mpg the entire time I had it.
