Old 03-03-2013, 03:45 PM   #1
hitmanre
My Ride: 2000 BMW 328i
Motor oil
http://m.advanceautoparts.com/mt/sho...267-_-10711125
That okay or na?
hitmanre is offline   Reply With Quote
Old 03-03-2013, 03:46 PM   #2
hitmanre
Promo code dow9 takes 30% off and there's a 5$ rebate so it's 12$
Old 03-03-2013, 04:24 PM   #3
sprintman
My Ride: Ex 325CI owner
Far better choice than 99.999% of owners have in their E46. Go for it!
sprintman is offline   Reply With Quote
Old 03-03-2013, 04:53 PM   #4
Stinger9
My Ride: '04 330Ci
Totally good if you do 7500 mile changes.
http://www.bobistheoilguy.com/forums...Number=2462219
Old 03-03-2013, 06:57 PM   #5
hitmanre
sweet thanks ima buy one now
Old 03-03-2013, 07:01 PM   #6
Zell
Zell's Avatar
My Ride: so turbo wow
I personally recommend a heavier weight oil such as 5w40 because of the age of our cars, as I've had much less oil consumption using it. That's just my opinion, though, and that might not even be the reason why I see less oil usage. Just what I noticed.
Old 03-03-2013, 07:33 PM   #7
Stinger9
My Ride: '04 330Ci
Clickee the link again. It is 5W-40
And BTW, I still use the 5W-30 not LL01 @ 97K miles that everyone says is too thin for our engines. Burn less than 1/2 quart in 9000 miles.
And OP, better buy two. Our engines take seven quarts.
Old 03-03-2013, 07:57 PM   #8
sunsetcoast
My Ride: '99 323i & '00 323iT
API Service Category: CJ4
I normally stay away from Oil threads, but...
Read the specs. This is diesel engine oil. It does not carry the "For Gasoline Engines" designation, nor does is have an API Sx rating.
sunsetcoast is offline   Reply With Quote
Old 03-03-2013, 08:10 PM   #9
Danl4560
My Ride: 330
I run Rotella T6 in both my BMW and my motorcycle (Honda cbr). I don't burn much oil in either. I ride my bike hard, spend very little time below 8000rpm, and after 26000 miles it still runs like new.
Danl4560 is offline   Reply With Quote
Old 03-03-2013, 10:55 PM   #10
pawelgawel
My Ride: 330CI
this is ment for diesel engines, it won't kill your car, but its not for gas engine performance. it may have an effect on your cats. I don't see why it wouldn't be ok though, as it's European approved.
pawelgawel is offline   Reply With Quote
Old 03-04-2013, 03:17 AM   #11
sprintman
And BTW, I still use the 5W-30 not LL011 @ 97K miles that everyone says is too thin for our engines. Burn less than 1/2 quart in 9000 miles.
And the viscosity might be thicker than LL01 spec oil. What is the viscosity of this oil at operating temperature?
Old 03-04-2013, 07:46 AM   #12
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
Why would anyone pay $24 (you'll need 2 jugs) to put the wrong oil in their engine?
Old 03-04-2013, 08:15 AM   #13
bimer21
My Ride: stick 325i
My engine has around 150K and I'm still using BMW OEM 5w-10, i got a leak in the rear main seal but i only need to add 1qt every 3k miles so far and i dint burn to much oil, or nothing like that. What is the good side to switch to this oil? I want to learn
bimer21 is offline   Reply With Quote
Old 03-04-2013, 08:27 AM   #14
Adionik
My Ride: Bavarian Panzer
Oil preferences can get worst than religion and politics...
Adionik is offline   Reply With Quote
Old 03-04-2013, 08:31 AM   #15
sfcjetjr
My Ride: 2002 BMW 325i
I have just gone over 138,000 and never have to add oil between changes. It doesn't even change level on the stick, I check it at every fill up. Was running 5/40 but changed to amsoil 20/50.
sfcjetjr is offline   Reply With Quote
Old 03-04-2013, 09:11 AM   #16
hitmanre
Crap I'm getting a refund. Ima just stick with Mobil 1 from Walmart. 5 gal 25$. Same ****
Old 03-04-2013, 09:42 AM   #17
taibinhvuong
My Ride: E46 99' 328i
Hey, I use Mobil 5w-30 all the way and never need to add any oil between change, my car is now 136k+ and I'm the OO, and I just had 2 round trips from S.F. to L.A for the last two consecutive weekends. It handles and drives super strong and smooth for a 14 yrs. auto tranny cars, and I treat it to the way that in and out it looks pretty much like a new car, I am very happy with it as the way it handles and the way it looks.
taibinhvuong is offline   Reply With Quote
Old 03-04-2013, 10:05 AM   #18
lcoleman
My Ride: '79 Massey Ferguson
That stuff has a good reputation, especially in high temp applications (turbo Miatas and the like). I would change at 7500 as suggested, and not worry about it.
Old 03-04-2013, 10:24 AM   #19
scarede46er
My Ride: 2001 BMW 325i ZSP
Mobil 1 is not BMW spec. I would recommend you stick with the T6, or go with Castrol Euro
Old 03-04-2013, 10:37 AM   #20
pawelgawel
My Ride: 330CI
I hate you guys... US always gets a steal on items like this. That promo code doesnt seem to work, but they offer 15%off for the first $50 anyways..
Id wouldnt hesitate to use this.
Sent from my SGH-I727R using Bimmer App
