Strange heater behavior - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-03-2013, 11:36 PM   #1
gumanov
My Ride: 2001 325Ci 5-speed
Hi all,
I'm having a weird issue with my 2004 330Ci cabin heat.
Recently replaced the thermostat since it was stuck open, and engine would never reach normal operating temp. New thermostat fixed that, but I'm still having a problem with low cabin heat.
At idle, using the AUTO mode, I'm not getting any heat at all, its all cool air, with engine at normal operating temp.
If i set the blower motor to manual low setting, i do get hot air out of the vents.. but no heat on max setting.
I'm using the BMW DIS diagnostic software to read the heater core temp sensor values.
Blower fan on manual MAX (full) setting - 20C
Blower fan on manual LOW (2 bars) setting - 70C
Any ideas as to why the heater core temperature falls so low when the blower fan is at MAX?
2001 325Ci 5spd
2004 330Ci ZHP 6spd :)
gumanov is offline   Reply With Quote
Old 03-04-2013, 12:49 PM   #2
gumanov
bump; Anyone?
2001 325Ci 5spd
Old 03-04-2013, 06:14 PM   #3
taibinhvuong
My Ride: E46 99' 328i
Set the heat setting to max and report back the heat status.
taibinhvuong is offline   Reply With Quote
Old 03-04-2013, 08:59 PM   #4
gumanov
Heat settings at max (91F and blower motor at max speed) no hot air from vents. Air is cool...
Engine is at normal running temp, centered on gauge.
If set the blower motor to lowest speed, while still having temp set for 91F...I get hot air from the vents.
2001 325Ci 5spd
Old 03-04-2013, 09:48 PM   #5
taibinhvuong
Put your hand on two hoses which connected to the Heater Control Valve locates below the airbox, both should be equally hot when set at max heat setting and at operating temperature, report back.
Old 03-04-2013, 10:12 PM   #6
TurnersInOz
My Ride: 2004 325i
In short, you most likely need to bleed the system.
TurnersInOz is offline   Reply With Quote
