Old 03-04-2013, 10:49 AM   #1
AC Yate
My Ride: BMW E46
Does this look like I need a new radiator to you?
Coolant residue at the upper hose connection to the radiator. Is this a common leak point for coolant?
AC Yate is offline   Reply With Quote
Old 03-04-2013, 10:53 AM   #2
My Ride: Lexus
You need a new everything. If you have to ask, the answer is always yes. (when it comes to the cooling system)
Old 03-04-2013, 10:53 AM   #3
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
It will be your upper hose or it could be your radiator. Look under the mount that presses the radiator at that point. The plastic gets weak , leaks and then fails.
I did have an upper hose leak a little there because the inner plastic ring was damaged. The plastic ring holds the orings in.
Your best bet is to check everything and replace those parts that may need replacing from weakness or aging. Like doing hoses, WP, thermostat and belts all at once.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 03-04-2013, 11:05 AM   #4
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Yeah, OP, if you can't diagnose the leak, replacing it all is best.
But, if the hose was reused at one or more points in the car's life, that hose's 0-rings might be shot.
Remove hose and look at neck of radiator for cracks. They used to fail there...my e36 had that...but that seems rarer than the typical radiator failure of leaking between black sidepod and alum fins...which would be a controlled/stable leak and give you warning.
If doing radiator (they'll last a while--mine leaked at 185K miles. Others go at 150K. So if you're over 120K it's a reasonable prophylactic measure to take...and at that point, do the whole rest of the system anyway.
If you don't know 'status' of wp or therm...cheap insurance. Again, Mango is right; a new system will only help you. With a manual, $300 gets you a system...$450 with radiator (more for automatic trans). But, you could possibly just replace the hose or O-rings, clean up the radiator neck of residue, and go on fine for months...maybe years.
Monitor your coolant levels until you fix this...and check that neck before you drive it...so I'd suggest you at least get the upper hose for now.
The checking of the neck itself might be enough to cause that hose to fail 100%, then you couldn't drive the car at all. Now, it's just risky to drive until you know what's going on.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 03-04-2013, 11:37 AM   #5
Jesse M
My Ride: 05' ZHP
Top her off, start it up and squeeze the pipes. While the car is running, it is being pressurized. Adding more force will only increase the pressure, forcing coolant out of the path of least resistance - a failed part.
But your best bet would be to just replace the hoses first .. cheap enough and if the leak goes away, you're done. If not, then back to the drawing board.
Jesse M is offline   Reply With Quote
Old 03-04-2013, 05:05 PM   #6
AC Yate
My Ride: BMW E46
It's hard to tell by looking at it if it's the radiator neck or the hose. I'll wipe it off and see what happens. The car has over 150k miles on it and it's the original radiator. so it's probably the radiator.
When they replaced the expansion tank, the shop wrote a comment that once the cooling system are exposed to air then other parts of the cooling system are prone to failure. Anyone know if this is true?
Old 03-04-2013, 05:07 PM   #7
Dave1027
My Ride: '06 IR zhp coupe
Mongo, maybe he should simply replace the entire vehicle?
Old 03-04-2013, 06:42 PM   #8
BMWCaptain
Originally Posted by AC Yate View Post
I
That is the first time I have heard that. That is just NOT true. I think it is just a way for them to escape any responsibility if something else breaks after you drive off.
BMWCaptainE46.com
Old 03-04-2013, 07:36 PM   #9
dmax
dmax's Avatar
Whatever he was telling you, I think he must have either thought you were a moron, or he himself is one.
When you remove a hose, you might damage the o-ring so it doesn't seal again, but if you're filling up the system afterwards, the only exposure to air that isn't good, is when it's in your system after you've filled it...and don't 'top' it off...fill to between min and max level...except for after you've drained the entire system...then you need to fill it up.
In any case, if you're doing radiator, you'll need to replace upper hose...read up on the diy a few times in a few different threads...until you puke!
Mangofy your E46!
Old 03-04-2013, 07:47 PM   #10
AC Yate
My Ride: BMW E46
It was a comment they wrote on the invoice. Not a big deal, just something I noticed.
Anyway, I'm just looking to see if this DIY is doable for me. Quick questions - Can this be done w/o jack stands? All the DIYs I'm looking at don't cover removing the bottom plastic cover underneath the engine (I think it's called the front aggragate protective plate). I'm assuming this needs to be removed in order to replace the radiator. How much of a PITA is this to remove/replace? Last time I checked, this piece looks to have ran into a few things down there so I'm not sure how easy it'll come off or if it'll come off in one piece.
Old 03-04-2013, 07:57 PM   #11
My Ride: Lexus
you'll need to remove that to drain the coolant properly
Old 03-04-2013, 07:59 PM   #12
dmax
dmax's Avatar
The underskirt is 6 screws...Phillips head. If you've never removed it, clean it up if for not other reason than that you can get it back on easily and get the screws tight...not crazy tight.
Easy. No problem doing that at all.
Only thing with draining the coolant from block, which you should do if you don't know if it's been done. Use OE coolant and distilled water.
Read the diys until you puke...at least get nauseous!
Mangofy your E46!
Old 03-04-2013, 08:11 PM   #13
wildirish317
My Ride: 2004 325Ci vert
If you don't know the history, do as Mango says. Spend $45 on a set of ramps to get the front end off the ground. It's a fairly easy DIY. Make sure you get some radiator hose grease to put everything back together. The expansion tank to its mounting bracket is a bitch if it's not lubricated.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 03-05-2013, 12:48 AM   #14
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
The 6 screws on mine are quarter turn quick-lock screws. If you tightened them crazy tight, what would happen?
/// MODS
Old 03-05-2013, 06:03 PM   #15
AC Yate
My Ride: BMW E46
I've been reading several DIYs on replacing the radiator and none of them mention needing to raise the car. I also looked at a few youtube videos and it looks like the car is at ground level. Are jackstands or ramps a must for this DIY? I know it would be nice to have for this and future DIYs, but I'm justing renting out a garage for several DIYs and I have no room for any jackstands or ramps at my place. If I buy them, I'd have to get rid of them after the job.
Old 03-05-2013, 06:04 PM   #16
My Ride: Lexus
it's not a must. just increases your chance for success. the higher your expansion tank (bleed point) is, the easier air will come out
Old 03-05-2013, 06:12 PM   #17
Nerdy46
My Ride: 328i
Replace the upper hose first and see if that fixes the leak. If not order a rad.
Daily: 1999 328i (202k)- Sport and winter package, 5speed, Jet Black, hellbeige, e60 Short throw, cross drilled rotors, koni, H&R, ASA AR1, Vibrant stealth, basslink
Track: 1995 Mustang GT (230k)- 306ci, 5 speed, MGW shifter, Trickflow Heads, Trickflow intake, street cam, shaved and tucked engine bay, slammed, 1 3/4'' long tubes, tuned with moates.
On the Water: 7' Boneyard Retro Quad Fish
Nerdy46 is offline   Reply With Quote
Old 03-05-2013, 06:25 PM   #18
AC Yate
My Ride: BMW E46
I was looking at it more closely today and I saw some coolant traces along the top of the side seam where the metal joins with the plastic on the radiator. From what I've read, this side seam is a common failure point. It was dripping along the expansion tank holder and it didn't look like it was coming from the bottom of the upper hose.
Old 03-05-2013, 07:04 PM   #19
POLMafia
My Ride: 2000 323I
It is not the hose, "upper hose" connects to bottom of expansion tank, rad is gone, if you let the car overheat once, you will warp the head and your $200 DIY becomes a $5000 nightmare. You have three quick disconnects and a few bolts. If you have minimal mech skills youl be fine, no need for ramps or jacks.
Sent from my Amazon Kindle Fire2 using Bimmer App
POLMafia is offline   Reply With Quote
Old 03-05-2013, 08:23 PM   #20
wildirish317
True, but getting the front end off the ground a bit makes the job easier.
