Old 03-04-2013, 12:16 PM   #1
mcquadefrank
My Ride: 2000 323ci
2000 323ci cam position sensor code.
I replaced my cps when my cel came on. I had it checked and said it was the intake. After replacing it still ran the same. I replaced all of my plugs because they were extremely bad and the car ran great. I drove it to the parts store today to get a radiator and it started running bad like before and the cel came on again. It wont always rev all the way up and sometimes you can go more then 10 mph. Any help would be greatly appreciated.
mcquadefrank is offline   Reply With Quote
Old 03-04-2013, 05:17 PM   #2
lszlszx
My Ride: 1.8T, XC70
Check for codes again, you need to post more info.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 03-04-2013, 06:01 PM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Welcome to the forum! Two things, which code did you get exactly when you scanned your car and what brand sensor did you buy? For sensors such as that ONLY OEM is allowed.
Old 03-04-2013, 06:43 PM   #4
mcquadefrank
My Ride: 2000 323ci
Im not 100% sure of the code from just the cheap obd reader but i think it was 0340. When I brought it into the shop this is what they found(see picture). And the one I bought I got at o Riley's part store it was an "import direct". Thanks for the fast response!!
Old 03-04-2013, 06:44 PM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
Yea, it's your intake camshaft sensor. "import direct" is probably aftermarket. How much you paid for it?
Old 03-04-2013, 06:44 PM   #6
mcquadefrank
My Ride: 2000 323ci
ID:	493803Click image for larger version
Old 03-04-2013, 06:46 PM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
Get this
http://www.ecstuning.com/BMW-E46-323...shaft/ES28830/
Old 03-04-2013, 06:57 PM   #8
mcquadefrank
My Ride: 2000 323ci
I paid $120 i think. So you think that the sensor could just be bad? On the box it says oe replacment
Old 03-04-2013, 06:58 PM   #9
Solidjake
Zero. Leaks.
Solidjake's Avatar
Hmm, if you paid 120 it should be oem. Can you link me where you bought it? Did it have any bmw logo on it?
Old 03-04-2013, 07:06 PM   #10
mcquadefrank
My Ride: 2000 323ci
I guess i payed a little less http://m.oreillyauto.com/mt/www.orei...2806&ppt=C0033
Old 03-04-2013, 07:14 PM   #11
Solidjake
Zero. Leaks.
Solidjake's Avatar
Yea, looks like what you bought is aftermarket afterall. Look at that part at oreilly's versus the ecs one. The "import direct" one has a weird sensor end with some small cut at the end. I bought an OEM one when I had to replace mine and it's exactly like the ecs oem one which has a smooth rounded sensor.
Old 03-04-2013, 07:19 PM   #12
mcquadefrank
My Ride: 2000 323ci
So you think that the sensor i bought is probably just bad? Is there anything else that would throw up that code? Or is there anything that keeps making them faulty?
Old 03-04-2013, 07:20 PM   #13
Solidjake
Zero. Leaks.
Solidjake's Avatar
Personally I think it is and you got ripped off.
Get the car scanned one more time and see what codes are showing now.
Old 03-04-2013, 07:25 PM   #14
mcquadefrank
My Ride: 2000 323ci
Thank you for all the help I will tomorrow!!
Old 03-04-2013, 07:33 PM   #15
Solidjake
Zero. Leaks.
Solidjake's Avatar
No problem!
Old 03-06-2013, 10:24 AM   #16
mcquadefrank
My Ride: 2000 323ci
Well i read the code again and it was the same as before.. so buy the one off the link you sent me you think?
Old 03-23-2013, 02:45 PM   #17
mcquadefrank
My Ride: 2000 323ci
Need help! Replaced the cps with a BMW OEM one. Ran great for a week. Now thru up the same code and misfire on cylinder 5. It was 4 last week before I put the new cps in. I'm moving 1000 miles in 3 days and need to figure this out asap. Please any help would be great
Old 03-23-2013, 04:59 PM   #18
lszlszx
My Ride: 1.8T, XC70
Swap the 5th coil (with the coil boot) with another cylinder and see if that
moves the problem.
Old 03-23-2013, 09:45 PM   #19
mcquadefrank
My Ride: 2000 323ci
I went out and drove it until it got up to running temp then the cel turned off and it ran great again. What gives?
Old 03-23-2013, 10:27 PM   #20
lszlszx
My Ride: 1.8T, XC70
It could be a bad contact somewhere, you should be OK.
