2000 323ci cam position sensor code. - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-24-2013, 12:55 PM   #21
mcquadefrank
My Ride: 2000 323ci
It did it again. After being warmed up
mcquadefrank is offline   Reply With Quote
Old 03-24-2013, 08:20 PM   #22
lszlszx
My Ride: 1.8T, XC70
Does the car drive OK? Like I said at least you could swap coils/plug to rule those out.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 03-24-2013, 09:01 PM   #23
mcquadefrank
My Ride: 2000 323ci
It misses pretty bad when it does it. Won't get up to speed. Won't even spin the tires on Ice. I'll swap them tomorrow if it does it again. It stopped after I shut it off for about 5 mins
Old 03-25-2013, 10:26 AM   #24
NumbaOneNewb
My Ride: 2003 330CI Silver
did you recently have to deal with leaking valve cover gasket? If so check your spark plugs. If gunked up with oil that's your problem. Also try disconnecting your maf sensor and see if it helps
Sent from my SPH-L710 using Bimmer App
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 03-25-2013, 10:29 AM   #25
NumbaOneNewb
actually check and see if your gas cap clicks when you go to tighten it. Make sure its sealing up right. Lol I don't know I'm just throwing simple things you can check to eliminate possibilities
Old 03-25-2013, 10:01 PM   #26
mcquadefrank
My Ride: 2000 323ci
Yeah I just replaced the cam cover gasket but wouldn't it miss all the time if it was sucking on air? Just not random? I just don't get why it is so random
Old 03-25-2013, 11:15 PM   #27
NumbaOneNewb
when I had the issue it was totally at random and never happened during cold starts. the car felt great in the morning but once it got up to temperature, oh boy. you're lucky. my car was actually stalling, mainly if I was going fast, then hit the brakes while cornering fairly quick. it was practically a guaranteed stall under those conditions. my car couldn't find a spot to idle at, constantly moving up and down. although when I did stall, it would start right back up no problem.
