Old 03-04-2013, 06:25 PM   #1
Bmwguy321
My Ride: 2005 Bmw 330ci ZHP
Need help identifying something..
So my differential is making a ticking noise and I found out what was causing it but idk what that part is exactly. So can someone look at the picture and tell me what's rubbing against the big gear? And would the carrier with the spider gears need to be changed? It's a 3.64 diff off a 05 330ci.. There was metal grindings when I changed my diff oil...
Bmwguy321 is offline   Reply With Quote
Old 03-04-2013, 09:43 PM   #2
Blocked Out
My Ride: Imola 330i M-Sport
You can not buy individual parts for the diff. Rebuilding the diff at a shop will cost you over 500$ . Go to your local salvage yard and pick up a new used diff.
3.64 gear is not a very common ratio so you would need to search a bit to get one.
Or ,for your automatic trans you could just upgrade to a more common ratio,which is 3.67 i believe ,from an x3
Sent from my X10a using Bimmer App
Original BMW Teile ///
Original BMW Parts for Sale - DISA, MAF, SAP, Coils, MS43 much more PM ME
IMG_1725
Old 03-04-2013, 11:41 PM   #3
Bmwguy321
Would the 3.67 be better or at least the same as the 3.64? Performance wise?
Old 03-04-2013, 11:49 PM   #4
My Ride: 2016 Lexus
you should have a 3.07 unless you have an auto? i believe the X3 uses a 4.10
Old 03-04-2013, 11:52 PM   #5
Bmwguy321
Yeah I have an auto. 3.64
Old 03-08-2013, 01:00 PM   #6
Blocked Out
3.67 wouldnt be any dfferent,not that you will ever notice.
You can go upto 4.44 out of same x3 and then you will notice an improvement
Crap,i got all my numbers wrong. Anyway,look at this link and see which ratio you like best.
http://www.bokchoys.com/differential/GearRatios.htm
IMG_1725
