oil drain plug broken inside the oil pan!!!!! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Closed Thread
Old 03-04-2013, 08:44 PM   #1
brokensmile209
My Ride: 2001 BMW 325ci
hi guys, i was so jinx today and what a bad luck day i have. Right now i feel like **** big mistake happen in a few second. I know ya going to say wt* and this guys doesn't know how to do an oil change, no this isn't my first time doing an oil change on my bmw. Long story short, my oil drain plug is broken inside the oil pan, i can't get it out, half of it is stuck into the oil pan. Check the photo i posted up and give me some advice. Please be positive, do i have to drop the oil pan and take it to the shop to take the oil drain plug out? or can i just take it to a shop and they can do what they do best to remove it and i'll get a new oil drain plug. Any DIY on dropping the oil pan, level of difficulty?
Thank You
brokensmile209 is offline
Old 03-04-2013, 08:51 PM   #2
HBizzo88
My Ride: 2002 bmw 330ci
This is why you use a torque wrench.
I've done the same thing before. The piece that was broken inside was rigid enough that I was able to use a flat head screw driver to twist it out.
Try that first. Put some shoulder into it and twist that fvcker out!
... That's exactly how mine looked btw.
HBizzo88 is offline
Old 03-04-2013, 09:00 PM   #3
brokensmile209
Thank you bro, you ease my pain, ill try that tmr because it too dark now....do I have to used the oem drain plug or I can used anyone? What the different between oem n other drain plug? The drain plug that was inside the oil pan has a hole small enough for a flat head screw driver, or can I used a machine tool to twist it out?
Sent from my SGH-T999 using Bimmer App
Old 03-04-2013, 09:02 PM   #4
mxchris727
My Ride: E39, E93 335
Send a message via ICQ to mxchris727 Send a message via AIM to mxchris727 Send a message via MSN to mxchris727
What?
-Chris
I have a computer set up with DIS, TIS, SSS Progman, INPA, NCS Expert, WinKFP, and Tool32 with an EDIABAS interface; PM me if you want to stop by and code your car.
ISTA/P & /D is up and running!
mxchris727 is offline
Old 03-04-2013, 09:07 PM   #5
HBizzo88
Honestly I used some random bolt I found to replace it, and bought an oem one later on, but I wouldn't recommend it. I'm sure a local dealer has one you can get for a few bucks. The piece that is stuck inside is already lubed since its an oil drain plug, so it twists out quite easily. A little pressure from a screw driver should get it out fine. If not, a machine tool should surely work.
HBizzo88 is offline
Old 03-04-2013, 09:09 PM   #6
HBizzo88
And make sure you torque it to spec this time. It's easy to go too tight with those.
HBizzo88 is offline
Old 03-04-2013, 09:52 PM   #7
mitfa911
My Ride: 2001 330 CIc
You can also use a bolt extractor that looks like a drill bid and has a reversed thread to pull it out. Will make the job a lot easier. Google bolt extractor so you can get an idea how it looks like.
mitfa911 is offline
Old 03-04-2013, 10:15 PM   #8
brokensmile209
Thank you guys, I think ill be able to close my eyes and fall sleep tonight, early when it first broke i was worried that i have to take the car to the shop, hopefully everything work out tmr, what the part number for the oem drain plug anyone know?
Old 03-04-2013, 10:24 PM   #9
My Ride: Lexus
Take a sharp chisel to it and bang it counter clockwise.
btw, replace your oil pan bolts as PM
Mango is offline
Old 03-04-2013, 10:30 PM   #10
HBizzo88
11131273093
HBizzo88 is offline
Old 03-04-2013, 10:47 PM   #11
brokensmile209
Ill try flat head screw driver first, ill tey that options also, AutoZone has bolt extractor too, well look it up
Old 03-04-2013, 10:53 PM   #12
brokensmile209
Don't have any shark chisel laying around...will try the other options first
Old 03-04-2013, 10:53 PM   #13
brokensmile209
11131273093
Thnks
Old 03-04-2013, 11:05 PM   #14
SilverThreeTwoFive
My Ride: 2002 BMW 325i
On the upside it looks like you were still able to drain the oil...
SilverThreeTwoFive is offline
Old 03-05-2013, 12:44 AM   #15
brokensmile209
Yes the oil got all drain out when the drain plug broken into two pieces
Old 03-05-2013, 03:52 AM   #16
Alex323Ci
My Ride: M3 & 323Ci (sold)
The plug is designed to break away before stripping the aluminum pan threads.
You are not the first to post this happening and I'm sure not the last this quarter.
people seem to be able to extract it using any of the three methods mentioned. I'm sure you will be successful
Alex323Ci is offline
Old 03-05-2013, 05:17 AM   #17
Chris C
My Ride: 2001 325Ci
No worries OP. As others have written you should be okay. Good luck.
Chris C is offline
Old 03-05-2013, 05:32 AM   #18
Breyton-BMW
Breyton-BMW's Avatar
My Ride: Ti
Send a message via AIM to Breyton-BMW Send a message via Yahoo to Breyton-BMW
An easy out should do the trick.
Breyton-BMW is offline
Old 03-05-2013, 05:43 AM   #19
jayb328i
My Ride: E46 2000 328i
Since the drain plug is designed to break exactly the way it did, when you put too much torque on it, the answer is clear----BUY a OE part from the dealer. What is the consideration---it only cost a few dollars.
I have removed this type of bolt before, and you may want to have an bolt extractor ready to go. A chisel is a good start if you have a rough surface to get a bite onto it. Also, I have found that a old (throw away) screw driver sometimes works well with the tiny head. I would star with that and taping along the very edges to get it to move.
PS---here is a story from my pre BMW days. Took my Ford into a gas station for an oil change and spotted the guy use a power air gun to put the drain plug back in. He then had the nerve to tell me that the plug was defective and that is why its treads stripped. I can tell you more, similar, oil change stories about Jiffy Lube. None of these guys have seen me for over 20 years.
GOOD LUCK---you will get it fixed (and never do that again)---be happy that the plug is well engineered to break as it did instead of the alternative.
jayb328i is offline
Old 03-05-2013, 06:17 AM   #20
Zell
Zell's Avatar
My Ride: so turbo wow
Oil change kits come with a new bolt as well
Zell is offline
Closed Thread
