Go Back   E46Fanatics > E46 BMW > Regional Forums > Australia
Australia
Old 03-05-2013, 07:19 PM   #1
ating
My Ride: 2004 M3
Adjustable rear camber arms
Hi All,
Anyone had experience with aftermarket rear camber arms?
Thinking of the Turner Motorsport ones.
Thanks!
Evolve CSL airbox w/Alpha-N tune | KW v2 | Vorshlag Camber Plates | Rogue Engineering RSMs | BBS LM 19x9.5 19x11 | Dixis Ti exhaust | EAS Aurora 60 LED AEs
ating is offline   Reply With Quote
Old 03-05-2013, 07:28 PM   #2
SC_M3
My Ride: Carbon Schwartz M3
if you want to share sipping ill get a pair also mate.
Dyno - http://www.youtube.com/watch?v=WayLD...uE3r0g&index=1 308.6 RWKW pump gas
ESS VT2-550 Supercharger - Okada Plasma coils - PWR Radiator - 55deg Thermostat - KW V3 - Vorshlag camber plates - TMS adjustable Front/Rear sway bar's -
- ADJ Sway End Links - Brembo GT BBK - Supersprint front pipe & middle pipe - Eisenmann Race muffler - Linea Corse LC818 -
SC_M3 is offline   Reply With Quote
Old 03-05-2013, 08:04 PM   #3
Davconelectric
My Ride: 330
I have a tms set installed in my car at the moment. Qualities good. Easily adjusted. Click image for larger version
Davconelectric is offline   Reply With Quote
Old 03-05-2013, 08:56 PM   #4
ating
My Ride: 2004 M3
Oh? I'm in Adelaide though. So will have to be shipped Melb -> Adl aswell. Could still work out cheaper tho. I'll find out how much shipping is.
Originally Posted by Davconelectric View Post
I have a tms set installed in my car at the moment. Qualities good. Easily adjusted. Attachment 494008
Cool. How much camber you running? Did you install it yourself? Heard it's a bit tricky around the diff.
Old 03-05-2013, 09:16 PM   #5
niiCk
My Ride: E90
I do, i had them in my E46. Installed the myself, and yes its tricky as the diff is in the way.
People say you have to drop the diff, Shook installed his using shorter bolts. I was able to install it myself without having to drop the diff, did it under an hr.
niiCk is offline   Reply With Quote
Old 03-05-2013, 09:22 PM   #6
Davconelectric
My Ride: 330
I'm running 2 degrees which will change soon. It's a pretty straightforward job. You will have to back the diff out a few cm's. Click image for larger version
Old 03-05-2013, 09:52 PM   #7
ating
My Ride: 2004 M3
Thanks guys. ^ more neg camber to come?
Old 03-05-2013, 11:21 PM   #8
Davconelectric
My Ride: 330
Less I'm thinking, it's not really the look I'm after.
The tms arms can go out to neg 4 degrees if needed.
Old 03-05-2013, 11:41 PM   #9
Alexander13
My Ride: 328ci
I'm looking into the GC version along with the rose joint toe bushes.
Alexander13 is offline   Reply With Quote
Old 03-05-2013, 11:49 PM   #10
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
There's still hope for some
E46 Coupe is online now   Reply With Quote
