Old 03-06-2013, 12:21 AM   #1
EmDeeAr
My Ride: 330i ZHP
Cloudy Headlights
Hey guys,
First post concerning my new car (I'll post up some pics when I get a chance).
Anyway, my headlights are a little cloudy. The haze is only slight, so maybe I could pull out the lens and clean it from the inside? Is that where the haze is, or is it from the outside? I can't tell by looking at it.
I'm also considering replacing the lenses completely. Are there any quality alternatives to the OEM units (which I believe are supplied by Bosch)?. The OEM units are pricey, and I'd obvsiously like to avoid this expense if there are quality alternatives that you all use. If not, I'll just go OEM in the near future.
Thanks in advance,
-Michael
EmDeeAr is offline   Reply With Quote
Old 03-06-2013, 12:29 AM   #2
Akonion
My Ride: Mercedes C230
Originally Posted by EmDeeAr View Post
Hey guys,
Thanks in advance,
-Michael
Over time headlights can get a hazy look just from sand and other debris in the air. You can buy a kit to restore the exterior for $20-$35, or you can (as you said) replace the lenses. I would opt more for replacing the lenses than just using a buffing kit, nearly half the cost and for the most part is a temporary fix.
A lot of people eon this forums seem to have success with this product:
http://www.khoalty.com/headlight-lens-replacement.html
The bonus is that they are OEM units and are really well priced! However, make sure before you order that those lenses will fit you car.
Besides that, congratulations on your new car! Hope to see some pics of it soon!
2007 W203 C230 Kompressor <---- SOON TO BE RID OF
2006 E46 330Ci or R171 SLK <---- MUST ACQUIRE
Akonion is offline   Reply With Quote
Old 03-06-2013, 12:31 AM   #3
t5contradiction
Banned User
My Ride: M5e39 m3e90 325cie46
tutlewax headlights restoration. Under $10 at your advance auto. Follow directions :/
t5contradiction is offline   Reply With Quote
Old 03-06-2013, 01:01 AM   #4
TallSkinnyMatt
My Ride: E92 M3 ZCP
Do this! Excellent product!! Here is my video before and after the lenses were installed.
TallSkinnyMatt is offline   Reply With Quote
Old 03-06-2013, 01:49 AM   #5
Zell
Zell's Avatar
My Ride: so turbo wow
Even though the facelift 2-door doesn't have lenses that are easy to disassemble, it'd be nice of someone offered them. I'd buy them.
Old 03-06-2013, 01:57 AM   #6
Akonion
>_< There are no OEM suppliers of the Face-lift lenses? Damn... Might have to get a protective film put over my headlights when I buy mine...
Old 03-06-2013, 02:01 AM   #7
Stinger9
My Ride: '04 330Ci
Had LaminX on mine for the last eight years. Look close to new.
Old 03-06-2013, 02:05 AM   #8
Blind_Shooter
My Ride: is your sister
wet sand and buff, anyone telling you to spend $72+shipping on new lenses either works for the company or is sers lazy.
http://www.lamin-x.com/3M-Headlight-...it-p/tl117.htm
smells like crayons
Blind_Shooter is offline   Reply With Quote
Old 03-06-2013, 02:14 AM   #9
Akonion
Not necessarily, just think it is worth permanently solving the issue than buying a temporary solution. Besides, $72 is not a lot for what this can do to improve the appearance of your vehicle.
Old 03-06-2013, 02:17 AM   #10
EmDeeAr
My Ride: 330i ZHP
Thanks for all the info guys. I will look into each suggestion.
Is the cloudiness actually on the inside of the lens, or the outside?
Old 03-06-2013, 02:18 AM   #11
Zell
Zell's Avatar
I've been trying to find the manufacturer of them. There is a logo on the bottom-left of the headlight, I can't remember what it says. It's like JTL or JKL or something like that. Maybe someone can figure it out and contact the manufacturer?
Old 03-06-2013, 08:19 AM   #12
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
Cloudiness is on the outside.
Old 03-06-2013, 08:30 AM   #13
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
I would just buy the new lenses from khoalty.
Btw, you're NOT supposed to clean the inside of the lenses. The material is more fragile on the inside and prone to scratches.
Old 03-06-2013, 08:34 AM   #14
Adionik
My Ride: Bavarian Panzer
Don't waste your time with buffing new headlights. It will come back eventually so just buy new lenses.
Adionik is offline   Reply With Quote
Old 03-06-2013, 08:46 AM   #15
caryalon
My Ride: 2001 325i
It will happen to new lenses eventually, also.
OP, check if you have Bosch or ZKW headlights - the lenses are different, and ZKW replacements are significantly more expensive.
My headlights were really badly frosted. I used the Meguiars kit that includes LaminX. The kit worked great, and the headlights are still clear and look new after 6 months. Reapplying the LaminX is recommended periodically.
caryalon is offline   Reply With Quote
Old 03-06-2013, 08:51 AM   #16
Adionik
Sure will, years from now when i've bought another car.
Old 03-06-2013, 10:04 AM   #17
Zell
Zell's Avatar
Also use headlight sealant every few months. One small spray bottle of it will last you forever and keep the cloudiness away.
Old 03-06-2013, 10:27 AM   #18
tailspnr
My Ride: 03 325i Manual
I successfully buff headlights back to clear with a decent cleaner wax and a buffer all the time. I work in the used auto industry and this almost standard practice for us! If they are really bad, wet sand them first with 2000 grit sandpaper then follow with a buffer. But this method will only last a few months. A better long term solution might be to follow some of the recommendations mentioned above.
tailspnr is offline   Reply With Quote
Old 03-06-2013, 10:37 AM   #19
Gasturbine
My Ride: 2005 330ci Cabrio
$2 polishing disk on your cordless drill, and some toothpaste. You can even do it by hand. Dont waste your money on those "dedicated" products.
Gasturbine is offline   Reply With Quote
Old 03-06-2013, 10:40 AM   #20
My Ride: Lexus
You can try the cheap way first but you likely won't be happy with the results. if you have pitting, you need to get aggressive with the sandpaper. all comes down to removing material. sometimes it's not worth the effort/time. my vote is buy new
