The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
Old 04-14-2013, 09:04 PM   #61
02PRUV
My Ride: E46 M3 Turbo
Originally Posted by Alexander13 View Post
Did a little bit of this today:
Nice ITB's. I ordered the same brand except the LS7 version with the long runners.
Rides:
BMW E46 M3 Turbo 570rwhp @18psi (old setup)
BMW E46 M3 LSX 427ci 800hp N/A
Ultima GTR LSX 440ci 800hp N/A
VY SS Ute Turbo 1004.6rwhp @ 28psi E85
Ford Escort Mk2 2JZGTE 600rwhp @14 psi
04 Yamaha R1 154.3rwhp
ISUZU FZR550 tilt tray (GT35 Turbo)
02PRUV is offline   Reply With Quote
Old 05-01-2013, 09:16 PM   #62
Alexander13
My Ride: 328ci
Pretty fair over this thing. Still being so young I've been caught up on a no good female. Ruining my life- also turned into a piss head for the month of April. I've done nothing on the car other then buy another set of works vsxx to get widened. One thing I haven't spoke about is my drive line in detail:
Motor:
Ls2 bottom end
230/250 Howard roller cam
Arp cam bolts
Arp head studs
Manley Double row timing chain
Powerbond underdrive balancer.
Genuine new rear main seal
Factory GM 241 heads Decked and acid bathed
11:1 compression
Manley Double valve springs
Manley Titanium retainers.
manley collets and valve stem seals.
manley push rods
Howard roller rockers
Chevrolet rocker covers
Harrop hurricane itb manifold
Moroso 4 stage -12 braided line scavenge dry sump pump.
Canton sump
Peterson 4 gallon dry sump tank -16 feed and return line.
-12 proflow breather/overflow tank.
Remote coil pack in cabin
MoTeC m800
MoTeC back lit sports logger dash.
Tr-6060 gear box from a ve hsv car(stronger internals)
Fuel:
40l cell
Holley black lift pump
Proflow cleanable fuel filter.
2.5L surge tank
2x 044 both with speedflow check valves
2L overflow tank with -4 drain
Feed line is all -8
Return is all -6
All braided line is Teflon to suit exotic fuels
New Bosch 550cc injectors
Areomotive fuel pressure reg.
So this is where I'm at, Myself and father have the month of June off so both rear quarters will get welded into place and my cage will be made. I would like to hope also my engine and gearbox mounts will be finished too.
Alexander13 is offline   Reply With Quote
Old 05-01-2013, 10:10 PM   #63
Ballistic325
My Ride: slow and steady
Haha! You're stuck in the middle... car on one side and a woman on the other. Not a good combo!
Good luck with both
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 05-01-2013, 11:26 PM   #64
Jimmy_46
My Ride: bmw e46 m3
Re: BMW, Nissan & Chev
Did u get any of that off of VPW by any chance
Sent from my HTC_PN071 using BimmerApp mobile app
Jimmy_46 is offline   Reply With Quote
Old 05-02-2013, 12:03 AM   #65
Alexander13
My Ride: 328ci
Nothing at all, I need to though. I need a bucket load of pro flow for my brakes and clutch.
Old 05-02-2013, 01:56 AM   #66
Jimmy_46
My Ride: bmw e46 m3
Well if u want, I'm best friends with the owner so I'm sure I, or one of the salesman can get u done cheap stuff
Old 05-02-2013, 02:18 AM   #67
Alexander13
My Ride: 328ci
I have an abn number which helps but we could be talking!
Old 05-02-2013, 04:43 PM   #68
02PRUV
Wow you have chosen to spend money in some strange places for an LS. You could of saved lots doing things a lot different and researching a bit. LS's are meant to be cheap
Rides:
Old 05-02-2013, 05:03 PM   #69
Jimmy_46
My Ride: bmw e46 m3
Up to u mate, let me no
02pruv
Do u really think that and ls will be better then the m3s?
Old 05-02-2013, 06:19 PM   #70
Alexander13
My Ride: 328ci
02PRUV
Do you get a kick out of coming in here and talking ****? Please tell me how I've spent money in different places? Also you seem to know so much please also inform me how much I've "wasted"
Old 05-02-2013, 06:24 PM   #71
Ballistic325
edit: misread posts.
I can help with
* RTABs
Old 05-02-2013, 07:36 PM   #72
02PRUV
02pruv
Definately in many ways
Rides:
Old 05-02-2013, 07:50 PM   #73
Jimmy_46
My Ride: bmw e46 m3
when ur car was turbo, u would of pretty much chopped any car on the street
Old 05-02-2013, 07:54 PM   #74
02PRUV
02PRUV
I don't know how you think I'm talking sh!t? I never said you wasted anything I just said it was strange. Most people wouldn't bother doing some of the things you have cause you just don't need to.
But if you think you know it all and you think that everything you have done is the right way for you don't worry about what I said then.
Rides:
Old 05-02-2013, 08:02 PM   #75
02PRUV
Pretty much. But will with the LS as well. Will make more power, lots more torque and smoother power delivery.
Rides:
Old 05-02-2013, 08:11 PM   #76
Jimmy_46
My Ride: bmw e46 m3
fair enough bro, sounds like youve done ur research well if u ever want to chuck away ur turbo kit i got dibs lol
Old 05-02-2013, 08:31 PM   #77
ating
My Ride: 2004 M3
^ here you go Jimmy
http://forum.e46fanatics.com/showthr...722&highlight=
Evolve CSL airbox w/Alpha-N tune | KW v2 | Vorshlag Camber Plates | WORK Equip 18x10/12 | Dixis Ti exhaust
ating is offline   Reply With Quote
Old 05-02-2013, 08:59 PM   #78
Jimmy_46
My Ride: bmw e46 m3
i wish they had a HPF in aus
Old 05-02-2013, 09:24 PM   #79
YGOAMG
My Ride: 325Ci ClubSport
Send a message via MSN to YGOAMG
http://www.hp-f.com.au/
no go put a fkn LS2 in your M3!!
Find me on Instagram
@PeterMarquez346
Originally Posted by all4show View Post
who da F done that?
prestige warehouse or who?
YGOAMG is offline   Reply With Quote
Old 05-02-2013, 11:14 PM   #80
02PRUV
It's for sale. Buy it. If it gets to the point of no one wanting it, I will just part it out. Then the only RHD single turbo M3 setup in the world with A/C will be no more.
Rides:
